My quick hitch is hydraulic
/ My quick hitch is hydraulic #41
What could be added to a QH to make it easily and quickly adaptable/adjustable to any 3PH implement?
Since the implements are mine and I bought them used, I modify them to fit the hitch. I just bought an old Ford 782A back blade I'll have to modify. Typically, it just the upper pin mount or clearance for the top hook. The latter in this case. No big deal if you own a welder and a drill. I also plan to add a hydraulic cylinder for angling the blade. The only other implement I modified was my old 6' Caldwell Barracuda flail mower I got for $35. :dance1:
/ My quick hitch is hydraulic #42
I have the quick hooks on my Branson and I like them much more then the standard quick hitches.
I don't have all the hydraulics on mine but it still works quite well.
/ My quick hitch is hydraulic #43
You meant "easy"? They are NOT quick. Do you also have a hook for the top link? How do you connect that? :cool:
The only time I have to get off my tractor is to connect the PTO shaft. For non driven implements (except drags), I can change in less than 30 seconds from the seat.
/ My quick hitch is hydraulic #44
No I have a standard hydraulic top like that I have to get off and connect I have looked at the hooked hydraulic top links.
Also almost all of my implements have pto's and or hydraulics that have to be connected.
Plus I have to get off and fasten up the support stands anyways.
And yes the lower hooks are QUICK and easy.
/ My quick hitch is hydraulic #45
Hello everyone! By the way, who can say what about these [link removed] valves? I want to open a shop with hydraulic components and I'm trying to understand whether it's worth using them among the product catalog.
SPAM :rolleyes:
/ My quick hitch is hydraulic #46
I have had both "Easy Change" and "Quick Hitch". The Quick Hitch far surpasses the Easy Change for ease of hook up for me. Just back in aiming at the top hook and lift...done.
New pictures of moving the stabilizer bar from the cabin when hitching the implement.
There is a new lever and linkage for the right spring loaded stabilizer bar and the lower link.
Left side locked stabilizer bar and hook latch opening rod.
This is my last video I have. Winter game to us. Hope getting better soon.
Tractor Quick Hooks - YouTube
Markus :tractor:
I made a new Top link for big tractors.
There is no ropes but a lever and links.
You can use it from the cabin.
I do not have JD now so I have to use my small Kubota as model.
For small tractors next is very good.
Markus
(2) Liquor Barrels (A64127)
(2) Liquor Barrels...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
2022 EZ-GO ELITE...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A64279)
2016 CATERPILLAR...
LMC 24 Row Boom Sprayer (A64126)
LMC 24 Row Boom...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
