On my B2650 the battery terminals or to loose even with the clamp tighten all the way. How does one fix the issue?
Do it the right way with a battery post shims.
Sold on amazon.com and available most places batteries are sold.
You do not want to put another reactive material like aluminum in the sandwich as it will just accelerate corrosion.
Try to find lead ones but if not available then copper
Dave M7040
I just went to the auto store and bought them.
Is this the normal way kubota does this? There is no nut on the end like the - - terminal, i have to bend it to be able to turn it.
View attachment 675041View attachment 675042
Look more closely at your second photo. See how the flats of the nut are almost hidden by the battery terminal? You have the proper nut on the tightening bolt. The problem is that someone in the past has taken that nut off and put it back on the bolt wrong end first. Unscrew it and turn it around. You will then be able to tighten the clamp properly.
You have all the proper parts right there, and the terminals are not showing enough corrosion to need replacing. Just turn the nut around.
How do I know that? Well, I made the same mistake on our Kubota & couldn't figure out why it didn't tighten properly....
rScotty
rScotty
Yes, for sure a loose connection would keep the alternator from putting a charge back into the battery, so eventually the battery gets weaker and weaker, without getting charged back up. Lights might also flicker when hitting bumps, or driving over rough ground. Properly tighten both battery terminals, and also re-tighten the other end of both those cables as well. Once everything is tightened up, start the tractor, put a meter across the battery terminals, and you should read around 13.5 to 13.8 or so on the meter, that will tell you the charging circuit is working, and putting juice back into your battery, so it will be ready for the next start.
It's a new battery but it still seems week on a cold start. I have a battery tester and it has the rated CCA,
Anyway scotty was right about the nut being on backwards.![]()
