California
Super Star Member
- Joined
- Jan 22, 2004
- Messages
- 16,950
- Location
- An hour north of San Francisco
- Tractor
- Yanmar YM240 Yanmar YM186D
Just in case, buy it someplace that accepts return for exchange.... so this should work on the ym 2000.
Just in case, buy it someplace that accepts return for exchange.![]()
I had it on the non running 186 in my yard. If I buy one it will list the ym2000 as the correct application. But for other people yes buy the correct one.
Ok update time. This time as I probed the alternator the B fat wire in it just has battery voltage. The upper pin in the two pin connector had between 14 and 20 volts depending on rpm. So this tells me the alternator is putting out. But it's just not making it to the battery to charge it. This tells me the regulator is bad. So I swapped in the one I pulled off the 186. It either will not work or it is bad also because there was no difference or if I remember nothing at the same terminal that showed charging voltage with my VR currently on the ym2000.
So what I am going to do is go on eBay or Amazon and buy the cheapest solid state VR money can buy, like any other cheap skate would do! :laughing: I looked at Rock Auto and they only had old school type that are not water proof. There cheap but still just going with a $22 or so solid state.
bmaverick, Most regulators are mounted on the firewall. Is yours not there?
Odd, I'm not seeing 124550-77710 shown in the BOM table on page 14. What item number is it on the page?
Your regulator shows on page 14. If you look at far right hand side you can see the edge of the regulator.
My bad, drawing #14, page 28. I edited last post.
That is a slick firewall. Old age is hampering my abilities. That was a picture of a 2310.
No problem.
If you look at the bottom of the FW, you will see on mine the wire-harness going in the bottom horseshoe cut-out. It then travels back up to behind the dash panel and the VR sits in there. I'll have to browse the JD850/950 manual too. IF the VR sits in the same place, then I know it's a JD requirement that Yanmar didn't typically do. Thus, it makes the Yanmar/JD models more similar than I even thought.
Those two scans are excellent information!Found a neat method to test the VR vs. the Alternator from the John Deere side of things.
What's your source? Is that the Deere version of the IT Shop Manual?
Nice.
So, it does show up in the manual, but not displayed for it's location. Item-9 124550-77710 and the description does have this; TL1Z86 Which in turn is a Ford tractor or old Ford truck VR made by Hitachi. SpareX on Amazon has it for 1/2 the price of Fredricks or Hoye even. AND it looks like the modern solidstate version Fredricks shows on their site.
