Lag bolts that don't break?
/ Lag bolts that don't break? #1
Muhammad
Administrator
Moderator
San Diego, CA
None currently
I've been renovating my new house for the past few months and I've noticed that all of the lag bolts I've been buying are snapping off at the neck of the bolt. Not all of them obviously but out of 40 bolts today, about 8 of them the snapped.
I also had this happen with different sets of bolts, including galvanized bolts from lowes, and now stainless bolts from home depot as well as galvanized bolts from home depot (maybe they're using the same supplier?).
Anybody have a good lag bolt I can try next time around? 20200919_172911.jpeg
/ Lag bolts that don't break? #2
Are you pre-drilling the holes?
Use a bar of soap and rub the threads on it before you screw it in.
/ Lag bolts that don't break? #4
I had a lot of 1/4 inch lag bolts break. Solved it by changing to 5/16.
Bruce
/ Lag bolts that don't break? #5
I don't buy hardware from Lowes and HD. Try getting what you need from Fastenal or a good fastener distributor. The quality is much better.
/ Lag bolts that don't break? #6
I agree with Fastenal having good quality items. However, looks like the nearest one to him is up in L.A.
/ Lag bolts that don't break? #8
It would be unusual for that many different varieties/suppliers to all have bad bolts. On the other hand, driving a lag into a tight hole creates an awful lot of friction and will surely increase the chances of failure. I am guessing that you're not drilling a large enough hole. I pick a bit that is the same diameter (err on the large side) as the inner diameter of the bolt.
Stainless will be a little weaker but I used a lot of stainless lag bolts on my pier and don't recall any failures.
/ Lag bolts that don't break? #9
GRK Fasteners | Home I haven't used these but have friends who have.
Structural Wood Screws Hidden Fastening Systems Timber Fasteners Look for the LOK line of screws. I have an assortment of these.
GRK uses a Torx driver and Fastenmaster uses a spline drive. I can't speak for the GRK but the LOK are very nice to use. The spline drive does not strip the way a robertson screw driver does in an impact driver. I no longer purchase lag bolts for use in wood.
Edited to add that I just looked through the Fastenmaster web site and it looks like they now use Torx drivers also.
/ Lag bolts that don't break? #10
What are you driving them with?
Are you just using a wrench? Or are you using a power tool?
I've occasionally done projects with lot's of lag bolts and usually used a predrilled hole and then a socket on a 1/2" electric drill. If I was to do it today I'd use my DeWalt 20v Max impact driver to drill the hole and then drive the bolt.
I've bought most of my lag bolts from TSC because they were selling them by the pound.
I'm driving them into studs with an impact driver and I'm being fairly careful to not over-torque. I am pre-drilling but the holes are 1/8 and the bolts are 1/4 at the neck. Some broke off in the middle of driving them in. I guess I'm noticing this because I've done numerous projects before with lag bolts like this and even when I way over torqued them I never broke a bolt.
I have had great luck with construction screws in the past and in reality I probably don't even need the lag bolts for my kitchen shelves.
/ Lag bolts that don't break? #12
/ Lag bolts that don't break? #13
I always predrill a hole if its a long lag bolt or long wood screw. Bar of soap on the threads and away she goes. I use an impact driver.
/ Lag bolts that don't break? #14
I use lag bolts from TSC, drive them with battery impact driver, no pre-drilling. If I break one, it is usually because I drove it too much.
/ Lag bolts that don't break? #15
I would think 1/8" hole for a 1/4" lag is the problem. You can get away with that in some soft wood (if it doesn't split) but not all. I have actually driven lags into soft white pine with no pre-drill at all, but the same technique is hopeless on yellow pine or any harder wood. If it's old wood, hard wood, or aged wood, you really need a large clearance hole. Let the threads bite and don't worry about the wedge effect (it's not a nail after all).
I remember once when renovating an old house, all of a sudden our regular tools seemed useless. Nail guns that worked everywhere else were having problems and basically bouncing off the wood. Construction screws that normally zip right in were struggling to gain a bite. Turns out the wood framing on that old house had gotten extremely hard and tough with age and heat. I realized that when I tried to drive a nail by hand and discovered the wood was hard as a rock.
I have seen the same problem with trusses up in attics. Due to heat, the wood up there gets very hard over time.
Stay away from Phillips head screws, especially when using impact drivers. Long screws you want torque head.
Ron
Yep! Agree completely.
The framing that I was lagging into was likely a contributing factor as it's from the early 80s, and although that's not super old those original studs did seem to be a bit on the hard side.
/ Lag bolts that don't break? #18
Oh yeah, 30-40 years is plenty old for wood to harden up, on the scale of things. It probably depends on the species/origin of the wood and the climate too.
/ Lag bolts that don't break? #19
For more serious applications, I've been using this style.
CTX Construction Lag Screws
Bruce
I've used all of these and they work much better than the Lag screws. Lag screws (or Lag bolts) are made from soft steel and are not as strong as the new screws. There is a lot of improvements in materials, design, and coatings in these new screws. I do not use the actual Lag screws anymore. Some of these may still need a pilot hole drilled, especially if near the end of a board, even thou they are self-drilling.
/ Lag bolts that don't break? #20
GRK all the way!
After using these I’ll never go back to lag bolts!
No pilot holes, just impact driver and go.
New/Unused Wolverine 78in Quick Attach Land Leveler (A65583)
New/Unused...
429835 (A61166)
429835 (A61166)
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
New Quick Attach Power Spreader (A65579)
New Quick Attach...
2005 International 4300 55' Bucket Truck (A62613)
2005 International...
1996 International 4700 (A64127)
1996 International...
