Murphy's Laws of Tractors
/ Murphy's Laws of Tractors #61
Putting out a marker pole to help avoid hitting an object does not guarantee you won't hit the maker pole.
(Don't ask me why I added that one.)
/ Murphy's Laws of Tractors #62
You will notice a low tire when unloading the tractor miles away from an air compressor...
/ Murphy's Laws of Tractors #63
14 foot door and a B series Bota? Am I missing something? Maybe Horizontally??
/ Murphy's Laws of Tractors #64
I have other equipment, plus I sometimes work on large trucks. It's 18ft wide and I've still almost clipped the frame!
/ Murphy's Laws of Tractors #65
You will always hook up your hydraulics backwards on the first try.
/ Murphy's Laws of Tractors #66
You hop on someones tractor to lend a hand, and end up with soaked underware!
Avenger. Small Coloured tie wraps!
/ Murphy's Laws of Tractors #68
Murphy went on a ride along with me.......
took a fallen limb to the transfer station a mile down the road......flashers, pulling over for traffic...etc. so far so good......
on the way back peaceful, pulling over for traffic........get ready to make left turn to go home.......flashers on left arm fully extended in the horizontal position.......then Murphy helps out........as I began left turn a little gray car 'whips around' heading into a blind curve..........the left fork slices rear passenger door and rear panel........
we pull over.......i walk over to the lady and ask her......."when I had my arm extended to make a left turn did you not see that"??????...
.... was wearing a blue long sleeve UV shirt, so dang it blue against an orange tractor....hard to miss........
ah "no I didn't see your arm"......:banghead:
flippn Houston city folks......"I took my driver test using turn signals".........she was here to take her dad home then she was heading back to Houston.......
maybe it's my fault living in a rural town where EVERYBODY knows tractors are our second vehicles and we all use 4-way flashers and use arm signals for turns......three years and no issues....one city slicker and sliiiiiiice........!!!:mad::mad::mad:
the good news is that the new forks only got the paint slightly scratched....:thumbsup:
But the sun come up tomorrow and it's gonna be a good day....;)
/ Murphy's Laws of Tractors #69
When trying to minimize moves when using a backhoe to dig a trench, you will always pull ahead 6" too far.
I've found with my hoe that pulling forward enough so the rears are where the front tires had just been, is the right distance.
/ Murphy's Laws of Tractors #70
When you enter your tractor supply store, you will always forget your list which contains the quantity and sizes of everything you need.
/ Murphy's Laws of Tractors #71
I bet Murphy never forgot his mask at home and realized it 1/2 way to tractor supply. 🤬
/ Murphy's Laws of Tractors #72
You lose one nut, pull out bolt, go to Tractor Supply. Can not find bolt, I left it on fender of tractor. So I buy 3 nuts of different sizes. Get home, can't find bolt.
/ Murphy's Laws of Tractors #73
Your mower will find the bolt eventuality, no worries :rolleyes:
/ Murphy's Laws of Tractors #74
No, I found it after I went back to Tractor Supply for another one.
/ Murphy's Laws of Tractors #75
Take break from tractor and bird leaves it mark. :rolleyes:
/ Murphy's Laws of Tractors #76
I bet Murphy never forgot his mask at home and realized it 1/2 way to tractor supply. ��
Luckily they have complimentary masks at the door.
Well, the store I go to has them.
/ Murphy's Laws of Tractors #78
You start greasing the loader and the gun runs out of grease.
/ Murphy's Laws of Tractors #79
And when you go to get a new tube of grease you find out that there are NONE (that you can find at the time*)!
* Refer to comments from others about how to locate lost items -go to store and come back home, but first leave home without mask etc..
/ Murphy's Laws of Tractors #80
And shortly after you buy the case of grease the other grease shows up....:magician:
2015 Ford Fusion AWD Sedan (A61569)
2015 Ford Fusion...
2016 Komatsu HM400-5 44 Ton Articulated Dump Truck (A60352)
2016 Komatsu...
2014 SKYTRAK 10054 TELEHANDLER (A58214)
2014 SKYTRAK 10054...
Pallet fork attachment for mini skid steer (A61567)
Pallet fork...
FORD F550 SUPER DUTY SERVICE TRUCK (A52707)
FORD F550 SUPER...
SHOPMADE MANIFOLD TRAILER (A58214)
SHOPMADE MANIFOLD...
