I need help understanding AC electricity and generators (1/3 phase)
   / I need help understanding AC electricity and generators (1/3 phase) #41
Center tap transformer example
   / I need help understanding AC electricity and generators (1/3 phase) #42
   / I need help understanding AC electricity and generators (1/3 phase) #43
I beg to differ on the 120/240 being out of phase. AGAIN, someone confuses the issue. If they were 180 degrees out of phase, they would cancel each other out. They are simply different taps, or windings, on a single phase.
Or am I totally misinformed? I'm not an electrical engineer and this stuff, the math, has never been my strong point.
Single phase IS single phase. Not suddently two phases! Not on a generator and not in your house panel.
Look at the sine wave coming out of the top of the center transformer. It's rising.
Look at the sine wave coming out of the bottom of the center transformer. It's falling.
They rise and fall towards and away from each other at the same speed.
So when the top one peaks at +120, the bottom one valleys at -120.
That's how you get your 240V difference.
If the 120v legs were in phase, they'd be rising and falling at the same time. They'd never be 240v apart. They'd be overlapping legs.
They are 180 degrees out of phase to each other. ;)
   / I need help understanding AC electricity and generators (1/3 phase) #44
Does any of that help?
   / I need help understanding AC electricity and generators (1/3 phase) #46
I'm not sure this will help, but...
Grab a clean sheet of paper and arrange it horizontally on your desk before you.
With a bold writing tool, draw a horizontal line midway up the sheet On the left most end of the line , label the line ZERO.
. On the RIGHT end of the horizontal zero line put a horizontal arrow pointing right and the word "time".
About 1 1/2 inches in from the left side of the sheet, draw a bold vertical line. Put a big "Volt" label somewhere above the "zero" label
At the top part of the vertical line put a +V label. at the bottom of the Vertical line put a -V label.
There, you have established a graph space.
Now, at the "origin" or the zero crossing of the Volt and the "time" lines on the left side of the page, midway up. produce a sine curve that goes from the origin, up towards the top of the page, peaks, and then returns to the ZERO time line but does not cross below. Draw one full sine wave cycle. More if you like. where the sine wave contacts the horizontal zero time line the second time, write a small 60hz at the tangent point.
Now grab a different color writing tool.
Again start drawing a sine wave that originates at the intersection of the horizontal and vertical lines. The line proceeds UP and to the right to the same maximum extent as the first sine wave, but in 1/2 the distance to the right (time) and then descends THROUGH the zero line an equal AMPLITUDE below the zero line as it had been ABOVE the zero line only moments before. Turn this new sine wave back up to meet the zero time line at the same point as the first sine wave contacts the zero line.
Clear as mud ;-) But the exercise is worth doing.
Details to note.
120V single phase does NOT CROSS the zero voltage ground. (and it does not matter if you had made the first sine wave below the horizontal zero line)
The Frequency of the applied Voltage is 60 times per second (50 if in the UK etc) That is, the A/C voltage rises from zero to a maximum and back to zero in one cycle.
The actual AMPLITUDE ( maximum voltage) does not effect wave form or cycle time. If viewed on an o-scope, Both 240 and 120 wave forms could be made to appear identical with a tweak of a pair of adjustment knobs. In fact, under heavy service load, both 120 and 240 Volt supplies will SAG, that is the voltage will "droop" to a less than peak value.
240 V single phase CROSSES the zero voltage line with TWICE the total AMPLITUDE of the sine wave in exactly the same time. 1/60 th of a second. Half that time the voltage will be one sign (+) relative to ground, and the other half the time the voltage will be the opposite sign. (-) The PEak Voltage for 240V systems is measured "leg to leg". No ground required!
One Cycle for both 120 and 240 single phase is the time (horizontal distance on the graph you made) And that is constant for both. Entirely based on engine speed for an IC engine powered generator. (Inverter units are MAGIC)
   / I need help understanding AC electricity and generators (1/3 phase) #47
I know what exercise is worth doing... a video of an oscilloscope measuring 480/3ph and compare/contrast with 240 split phase. I'll make the video tomorrow and post it here even if I'm wrong.
   / I need help understanding AC electricity and generators (1/3 phase) #48
Think about it...
Out of phase:
If L1 is going up while L2 is going down. When they reach +120 and -120, they are 240 apart.
In phase:
If L1 is going up while L2 is going up, L1 would reach +120 when L2 hit 0 and L2 would hit -120 when L1 hit 0. They could never get 240 apart if they were in phase.
Make sense?
   / I need help understanding AC electricity and generators (1/3 phase) #49
Great!
Please show the variation between any leg to ground/neutral, and Leg to Leg.
It is always a difficulty to visualize that 120 degrees phase difference between legs 3 phase BECOMES 180 phase difference between any TWO legs.
Magic again... ;-)
   / I need help understanding AC electricity and generators (1/3 phase) #50
If 480 3 ph behaved similar to 120/240 it would be 240/480 and it is not, it is 480 any phase to phase but 277 to ground or 277/480.
43023 (A59228)
43023 (A59228)
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
2006 Dodge Ram Pickup (A56858)
2006 Dodge Ram...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
PICKUP TOOLBOX (A58214)
PICKUP TOOLBOX...
