Another shop light question
   / Another shop light question #1
Bayou
I have a few questions in regards to switching over my shop lights to LED and being able to see lol. My shop is 40x70 with 12' to the trusses with pre existing lights 16 total. They are situated in two rows, every 4th truss. I'm assuming the height of the lights/fixture makes a difference on what style. Everything is already wired so it won't be hard at all and I'm trying to decide or figure out my lighting options. I'm not wanting to put up gold fixtures but I also don't want the cheapest either. I just don't have any idea when it comes to this besides the fact that I want plenty of light. I will also put in a couple extra around the main bench/work area. For those that have did went to LED, please share your experience with different light set ups and what you would do differently if you started over. Also I'm just starting to figure this out so any links or pictures would greatly help. Thanks
1. High loft vs rectangular vs strips---would rather go high loft or rectangular
2. Is a high loft what is called a UFO style
2. Best to hang or fix to the truss
3. When it comes to lumens or watts, what should I be looking at or for
Any other suggestions are welcomed.
   / Another shop light question #2
Friend of mine has a shop about the size of yours, maybe 5' shorter in length. He has (12) LED rectangular fixtures (24-30" in length). Trusses are about same height as yours as well. Lights the interior WAY better than incandescents/flourescents. And no heat generated either.
He hung his from the trusses. They are high enough where you won't bump them, unless you're trying to...
Don't have the specs on lumens or equivalent wattage, but they were significant. He bought them on line.
   / Another shop light question #3
Here in Australia in my 23 x 40 foot shed I put up four of these from Philips, and they do me well. I hang them from the trusses, but they can be mounted in different ways. I don't recall what beam width I chose, our four covers almost all of the floor. You'd obviously need more.
I've linked to the US website, where you can see they come in a range of lumens, colour temperatures and beam widths.
GreenPerform Highbay G3 High-bay - Philips
   / Another shop light question #4
If you have fluorescent lights, 4 or 8 feet long, you may find you can use those fixtures with led bulbs made for that but you must remove the ballast and do some simple rewiring.
We just moved in a year and a half ago and the previous owner has plain light sockets with regular house bulbs. You can imagine what that was like. I changed the bulbs out to LED but it's not much better. It's almost laughable.
   / Another shop light question #6
I just found some 4 foot GE LED T8 tubes at the RESTORE. Two Bucks CDN per. I bought all they had. I'm surprised (and impressed) that I cannot tell the difference from adjacent flourescent tubes. I am a little annoyed that I still have to address some defective Ballast issues in my shop. One, I only use low RFI ballasts which can be misrepresented and always cost more. Ballasts seem foolish for LED tubes if there are ones in the market that you throw the ballast away and put line voltage on the tomb stone connectors.
As far as lighting goes. I am not a fan of spending money on LED fixtures. I think too many fail. I like to keep my options open. So regular screw bases and replacement tubes and bulbs make sense to me, at this time.
Has anyone bought the replacement LED bulbs for those hellishly high temp quartz spot/flood lamps?
   / Another shop light question #8
I have a 40x40 section of my shop lit with the UFO style 150w 19,500k versions from Adiding. I used 8 lights in a grid pattern (didn't put a light above the garage door).
Even with a 16.5" ceiling it is fantastic and very bright, i could have probably gotten by with less but I wanted it like working outside.
I did have an early failure the other day, (little over 2 years old) and after a couple emails they sent out a replacement in a couple days, very good service.
   / Another shop light question #9
I simply converted my 8 existing 8 foot fixtures into non ballast tandem led fixtures with a retrofit kit. The kit contained the tombstones and center plate. Than i swapped out the High Output 110 watt lamps for 5,000k led lamps. Super bright in my 30x40 shop with 12 foot height.
   / Another shop light question #10
Nah, they've got them both ways - use the old ballast or remove it.
I've got about 6,000 sq feet of shops and basements which were primarily lit with Fluorescent tube lights, a mix of 4' and 8'.
Probably over 50 fixtures all put in about 30 years ago.
My prime purpose of going to LED was because of failing ballasts.
The purpose of the fixtures is to get lumens on surfaces as economically as possible.
I've posted here frequently about my efforts and have been pretty happy with 4 foot fixtures sold by costco and the like for about $20@. Until this year.
Amazon has started selling AmazonCommercial 4' LED Shop Light in sets of 8 for prices from about $45 to $200 per 8 pack. Amazon's pricing on these is crazy and like a roller coaster.
https://www.tractorbynet.com/forums/image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAnkAAAIuCAYAAADDgh7uAAAgAElEQVR4Aey9C7AdxXkuqkql8vRxJY7Lx07lJHaOK VyOT6u3FSS6/j4pnJduYkFsWMIjh3DwVgBGzAvAwGDQQYMgYANtsPLPMVLAiwJIYF4GoMEAvRCL4TeIJAEeqAtaQtpI6lvfSP9a/Xu3T3dM9OzZnrtT1VbPdOPv7// 7v9XdMzNmYOcuxT/qoPU2sKPZPnp33z5V9d BAwfU5s2b1dtvvx0katy4cUr/e aZZ9Q777yjbrrppmHxkidIKDNRA9QANZCABv75n/9Z6X/f//731datW9X69euHxUses0kYb/fv36/27dun3tmzR20fGFAbNm5ULy9frhYsXJhdm2Vc9yiHMiiLa8iCTMhGHajL9w9j9 uvv65ee 21Sn QAVmh/8a0fnInCSUJ37GzMR3s3DWYOXGoQ4Xk27lzp9qwYYMaGhrKzS7kTcI33nhDbdu2TV155ZUkebmaYyI1QA2krgEhbxIWJXlovxC9d999V 3Zs0cN7NihNr35plq9Zo1a8NJLat78 WrlqlXZuLpjx86OynCNsRZpyIO8KIOykAFZkBlK8EQwxvyNGzeWJnkoC2JZ5J T5G3fsVPxjzoYrTaAHz979g5lgwQGith/GCA2bdqUkT2s7m3fvl3t3r07GzikrrPPPttK5oT06eH48eOjYxQcDOP3P3VKndIG8m3gW9/6lnXFTkifHp555pnO8Q9EDOMtCNbud95RAzt3Zjsqr7/xhlq1apVavGSpmjt3nnpuzhw1 9nnsj9cIw5pyIO8GKdRFjIgSyd5RfsSP/SxIvfqq68G/SEvyuTV4yJ I0ieTOrbtg orW9vV1u2vT3ib/PWbYp/1EE/2QDsfNv27QedePc7au/evT35GxwczAgeBhCs1K1bt06tWbMm 3v44YfVOeeco4477rjcv9NOO00hr5RjeFB/1AP1QBtI1wamTZumTj75ZHXEEUfk/uHHLvLm9fXq1aszsrZy5Uq1fPlytWzZMrV48WI1b8EC9cKLL6pn58xRs2Y/q56eNSv7wzXikIY8yIsyKAsZIH6QmVdnSNqKFSvUwoUL1Ysvvqief/55NXv27OwP14hDGvKYstauXav0P8wbsg2M7Wz9b4zO/oQlgqG 9NJLasGCBWr /Plq3rx5w/7mzp2r Ecd0AZoA7QB2gBtgDZAG itDQgnAz8DTwNfA28TDqfzuhEkDxmxugAWyX/UADVADVAD1AA1QA1QA 3VAPgaeJsQPR1ph SBAeJAH84F4cAhnuTjP2qAGqAGqAFqgBqgBqiB9moAfA28DfwNPA58Tv4NI3lggTjchwPhTzzxhORhSA1QA9QANUANUAPUADXQQg2Ar4G3gb Zq3nDSB6eGNmxY0d2ABwHufmPGqAGqAFqgBqgBqgBaqC9GgBfw4N74G/gcc6VPCQODAxkT2bMmDGjvS0iMmqAGqAGqAFqgBqgBqgBBb6GJ2rB30jyaBDUADVADVAD1AA1QA30iQZKkbzp06f3SfPZDGqAGqAGqAFqgBqgBvpTA BrhVfySPL60xjYKmqAGqAGqAFqgBroHw2Q5PVPX7Il1AA1QA1QA9QANUANdDRQO8nbunVr9kkNfFqDf9QBbYA2QBugDdAGaAO0geI2gM TgVPpT8h22JzjolaSBzD8Rw1QA9QANUANUAPUADUQRwNbtmwZ8WJjl RaSR5YJ/9RA9QANUANUAPUADVADcTRALjVnj17Rrzc2Ca9VpKH5Vj owaoAWqAGqAGqAFqgBqIowFwq127dmVED58qy/tnI3lbHjhZnfHARjXiixfyMmQUCvlHkheiJeahBqgBaoAaoAaoAWogTAPgVviCBb5Ha36qzJRAkmdqhPfUADVADVAD1AA1QA20VAMgeVh0GxwcrEbyZjzwI/WZqxZmT3LonzWrvpJ3QCnFP qANkAboA3QBmgDtAHagNsGRjJNneSZnyozc4OvPXHBZ9Tl90xUp/0/f6vOmLpBdbZrZ3zr/yXJIxklIacN0AZoA7QB2gBtoBEbMGmbyl5HJyt5oSTv//7GRLVxaChbtOuQPLWAK3luds1fHtQNbYA2QBugDdAGaAN12kAcknf5rAElhDAjed86WY0hyauz4yibAwNtgDZAG6AN0AZoA3k2UA/J wxIHrdr8xTPtNHimE8//XT2CyivvXiMfcyYMWrJkiWFtjQmTpyoxo0bV6hMHo460l5//fWsbdu3b28UZ0g/oP1twVtHX4wmmSH9XbavfeXK nOs/tHr16 Lyve10ycvpA98MphelSvUQ/KyV6jwwYuqnZNffvz48ep3fud3ssegU3SEq6Wn30ox9Vv/Vbv6U 8YlPqDvvvLNRElCHDvHCyQ9 8INe8hY6EGO5/OMf/7j6 7// 0xXIHmnnXaaVW/vf//71cGHnEbaEdJAKvW/D3/4wx05kv4rv/Ir6vd///fV8ccfr/CWdJeOQE6BCfaIv3/5l39RGzZsyPJXnShcddriXW0O7QfI9OH94he/qC655BKnLmy4zH5DnuXLl6vPfvaz6j3veY/62Mc pu6 5hMqum6zhcetHzpHad16bQ/vb1tUsnvnKh/uySj3jxQfjor/7qr6o//uM/DrY7vX792lWfayz2tdMlD/GhfZAnA2kubL5yTJdxvxrJu1YevDC3a/GePDmchkYZCL9548AT 6Q0zKIBATJkwYNjmkYNwgqMCPX3p4KeOTTz6ZkYNp06Yl15YY g4ZiFHPd7/7XfXe9753GMmDLm0Y8ibBvDTI0tNXrVqlvva1r2XkEu9VMuuCb8MOQXzw7qW33npLHXvssepTn/pUlrfKRGHW5bvXcfvyutJ9eMuQPLPfUDf0c84552Q6e ihh9Rv/MZvqDVr1nT0WzVdb18Mvejy2nAdo02 vna101cu1J9d8hGvtw/yXnjhBfWHf/iHGenJK4c0vX792lYubyz2tdMmL2ZcHraY9fS3rGokz/aePJE45pq/OVnN2Kj4CpUanqiZOXNmRpKuvfbabDVAjBSPRuOX36WXXqr 4A/ ICMEcJT7778/GyCwavDVr341GwSkzMKFC9Wf//mfZ5MMVokgG2k33XTTsJUeyP3kJz/ZmYRWrFih/vZv/zZbicNKxG233dZJk8Hh uuvz36Bvu9971NCRkAUgMNcZcJEKCtUqN8lv2gbi ZH3SA2n/vc57K2YbKdNWtW1jZp19lnn63QJugO RFtOf7uhCyKo5wLp0beaDTPNv/vz5WZ ff/75w/Rk5pN7fZKQOAnz0pDHTAc rLb 9Kc/HYEL/QTbkJU7lN 2bVtmU/h8jujsyiuvzPDrtoC8rn5GGspiNfGiiy7KVhSxqgg5SLP9mbglj6nfOXPmZCQLhPnII4/MfAi2KnWiPTa8WKVEGv4 85nPWDFInRLa g02iXbhB47kgy Jfqumi0wJXXqBnaMtWHWRvCDsjz/ ePYEHtKKjCU v7GNB1Lv5MmT1Z/8yZ9kPgRfEt SdDN0tQn59P4W 7PVLWlylODEE0/M lV zLj8VcrBF2GT Lviiis6OtTrBx6XXsw26fe29p1xxhnqqKOOyurJ6zu9fv1al49r31gs7bT5gshy6UivV TY kDkmKEPm TPGz8kz gOhZJ1Q4wvRZ6uXb9 fZYfP ixaCf/xlyz4OAlV/LsE1IVw8PEhFUAbKH92q/9Wrb1A3lCaECoMHCBsGEy fznP5/lxUoBBiTZGsIkg4nrlltuyRz hz/8YXYPB9XxwUkx6Eg5TApYiQPZQT1PPfVURnoeffTRrJw4Nbb5sLqDdOBA/Zj0MHkgXq8DMmVLME9 0TYWzQ9DxmRzwQUXZBixjYy2A6 0CytVaAcGIugQOv2P//iPLA/IK8gD6tUHujxd6/l0ncg10kE2QR4x4OpkWPKYoW2SkDx5achjS8cEA7sTGXr4V3/1Vwp/U6dOHXF8QHRms4W8foZ8KQt7BnGEPWPFC/ak1y/XNtxI0/WLPgORER BTnFkwCR5NryQVWQlz9Vv NEArIIbIWwKPo3rqum6XFy79JJHFOrwG5dO4VsYxzB oH gB/zgNNuh37vahDx6f4sN2eqWNIxhGPvwQwZ2Bhl5/irl8MMU bAjAZ/HjoRZf954orfHvNbbh/aATOF4C8YZ5M3rO739 rVZh28slnbadAdZeTrS6/XJMXHh3ocNeXzjh03u6IsTStYN4dtRSJ6IJMmLS/KwHYYBUX7pgsCdeeaZmePLwCy/TGHQmNBkZQn3mKhlVQ0DEM7 iOGDZIGAYQVG4uCsODsER5c4EBkMQkiTOPyqFRIgTi0DJvIAByZpTNA4YyLlbGGe/KJtLJofE80HPvCBYfgw AOTrV0gNlg11dsB0gy96gNdnq71fLocucZKFlZgcR L5KGf9T 0T rTJxiJw0oFVpvkXg8xMQOjnLHE9i50hTw2nYkt5PWzXla352OOOUadcsopVhw23JCj6xf9i9VE3XaxKmeSPJvtQlYRkufqN6yUQQeQJ394gEbOV1ZNF5kSuvSSRxTq9huxAWCE/YBow8Y2bdqUTd7AJvhtoatNyKv3d579SRp yOHMm74aneevUk63S4yPJ598coZZrz9vPLG1S LQPvFPjJf4UQ3yK3ab13d6/fq1yJbQNxZLO12 kKcjvV6fHMGjhz5syOsbP3R5o/damFg3hG T5GmDb9uMAwMhtkcFF87kgZTA4WwDMwiIbMGiDA7Fg5BJeQxw2IbFCokMKpAj6cgLkoOBWOJuvPHGbDtO7hFiuxbbvrgWp9YHQeCAUy5btiyrx1zJA36Jy5NftI1F89u2qaEXkABbu4AVq1i6LuRaH gQ59K1mU/KI8RDDdCdrHLGInk6qdPrw7VtAgUBERJv5tfv586dqw477LBs0kSf2nQmtpDXz5BpKwt7lC0rvV5c23AjXtev9IFe1kbybLaLMqEkL6/fsFIHoqljwEoeVoYQVzVdl4trl17yiELdfiM2IFjR5n/8x3/MVsQwjsiqmKSboatNyKf3t82GpG5Jww9lnHfTSR7kiK2YY6OU020EP5y/9KUvZf2n1583npht0u/z2od8eX2n169f6/Jx7RuLbe0U3Yksl470ekPkiDwJfdiQzzd wK9lTsORJZE9usIuuZMr DZJXotJHgieGK4ewoiLDsxwJAxgsk2CQQsyIQeOgBUFbEMgn 4YyI9f4nBkicfki8kd93lOjSV2nMnDYXMpixDlZRsyT37RNhbND0KMX806Nrm2tQvtwMAneRBiwsKEoQ90ebrW8 lycI2VK72f9Wtd/2a5vEkiLw1yzHTUA7vDk25mPXjC1yRdYkeLFi3KtYW8fkY9Nn1jlbDKSh7IA9qnt6MOkpfXbzi2gOML8qMGWP7mb/5G4YwtrmGzVdL1tuHa7E9JF9/AtpvEwa/1M3k6kYGdu34wFvUbnSxgd0J2JmBrP/7xj7Nxp6x9oxz8BETbZkNSt6Rh9RA/nnAOV/SQ569STtfNcccdZ13Jy9OL1GULXX0mefP6Tm /fi1lJfSNxbZ2iu4gI09Her0 OYJHD33YkNc3fujyRu 1ULtuCNshyWspycPZD2zVmr84sdXzd3/3d4VJHg6gg3AhxECHQ9YYHPErEfcY8PUHKsRRsEKDrTmsPGCikpUHbF0ij8 p8SQmyqNerBBiaR4rG7KtnCdfBjd9gM2bfIrmBx6QPJzJQx0YyLBVCp3b2oX8WAXACismS0yQOOcIHeoDXZ6u9XyiY1fYy5U84EL7sYIHkqeTAcEHwgIbAi7oC/aAc0PoT jGpjOZKPL6WbcjbHtCNgZ1bOvBD6R PXRNjLp MXngDCVkAitsFj90zO1a075k5RO2gAkdclA3trJsPqLjwrXZbzhjidVRYJCna/VjElXT9frz9IIfccCP9oJkglyWIXlF/UZsADjx5Kj0K2wMKzTAjDSXfl1tQhm9v/Psz0zDijzGQMjI81cph 1T4JUzeRjHzPrz9OJqG2TktU/qcPWd3n79GuXMv7yxWNrp8oU8Hen1 uS49JCHDe3wjR9mW0fnfZfcyRVJnsUR2mIcWB2Qs1k6JkzEOLcxe/bsjKSZTun69Q0ZIDMYUEDo4FSY8LDagVUbfdVIruG8KAcSA2KJCR6kSCZJpPmcGnkwyWKgR33YLpaHOpCWJ78oaSuaH3XjPJ20DYQAekG8rV2Ix4qB/s4z2WrSBzrkc nazIe8rj TLLjyoU lzySU7VZbGoipyJJ0TPjoo29 85ud7WLJo4fYohV9QQ7O7mHiRh6bzvQJPsSOsHIH 0Rf4IC8Xrd LbilvQjRZlO/wAYShUkS26845C/268MLAoR65HwiDohDjo7Ddm32m/kevHvvvXeYjKrpOgaXXpAHK7HQK0g5yCv6pgzJg6wifqPbAMqC2GEcwXiAvhEfcuk3r016f f1p5mGcRTj2bPPPpv1hctfUQ6 gT6F7ky71OvP04urbSiD9skPC9zb/lx9p9evX9tkIM41Fpv6QV6z31w60uv1ycnTgwubtCVv/JA8ozsUatcNSfIcDjW6DcU yFAn1EudNmCbHGLUJ6twIgurymXP7OBMkutMpshnWN5P lm//dy2IjZPPZT3D7 eu ROrkjySPKsvxr9xlSnoVL2aNR/XSQPB/uxRYqtNGxRYiUOxxPK6BirjNhGLlOWZfx 3c/67ee2FbFt6sHvB0X0OTyvULtuSJJHkscJizbQChuoi RhK/DP/uzPRmwNDh8c6xx4KZu6pg3QBnphA11yJ1ckeYlO8PoZiCrOEzKx4qAxDr1WqYdle HgB7KtRDlvRp33Ruehejb9CNvIeFIZ58LwII ZHioX bCFnGK/h4w/RfTAvO2yefZHr/tDqF03JMnrQ5KHw6s4GK87GB52kJciIx6vMcBB9eeff37Ewxt6OUxEOASPhw0QH/reMF2Gfi3vVcPBb/0pRWyB6QfocY3XrEhZ82C6 eBGXrp5qBlGjzbJKyykDltoO/CNA PQg4lX7nFAG7LMem3yY8flTfautsTGEEsebA6v2cHDHfjDOx/1J82r2qINZ8wPpOv4TD9C3XinGr62Al/EVrLuZzZseXGufsfBef3BLF0GXnmDB4jwpCvOKeKslJ6uX u2g4e 8DJheUBJz1f0miSv1ySA9RW10bTyd8mdXJHk9SHJk0f8sdoHA8VAioFZPzCOb0eCrBQdZPWJq6jxg BhssZEinr18vhqBN4dhpcAyx8mPsmDJ/DwCgP9FRR4nUdIuk628Pg nq7UCa/IsIV6WVs64kBEbBNeSFmXzLLxrske8prAU7YdWDkG6YFe0ecgQniBMOxAZFaxRZGhh7AJ AT8B6/KwDYv7FVe9aPnDbn24cMriWxPz4fINvO4 j2P5OE1OfJaEDzZiSdd8WPJlI173XYwruCJZbxKyPYuRVt5V1zR8cclh/Ekb7QB2MDIf9FI3opV6xT Xlm5Vi1bvkrNX7hEPT3rOXXjz24ZWaslBkDs/0a38bo yJy3XYsJEr/O8ag6DB/bOPJ2efmSAr5NiklTBlmsPmGCwwqbToD0ejDhyWoVXigL2XikHS8VRX2YgPEOPZezYXUR21K2dEzmeP fLQ22gVcY6O9tK/KBd5mgoBcQSfkcka0uM07KmvH6fQySh5fD4gEBTLQgofIaHOkf9CFWT8z 0V8PgteH6K8H0THiOq8tvnpc/Szl8F1jYJOX3OKdWrAHPOQAXFgxku1EkB 9D376059mX1nR8cLuYWv6yh0IOnSE98vZbBHlfXo0cUqd EGBbVPzNRYgYvLS7iI6MPHpfoQ64XviSwjRJoSyYo48rvqQFtrvLpKH9qI /YcSSJ/5ahfRj812MIboL8Z26R4ykPbpT386GydQjxBnsR9ZbTzxxBMVxhb9B55gYDi650L2f0j/j2RRRUge Bp4G/gbeBz4nHC7Mb/3oY o7t H1fsEfqdz/wP9R/e99/H1mrJYYkb2QHYosHxAsTEwZBeYkwtjbNScN0AJAg ZUNgoeVMoSyzfkXf/EXWZwMsq6PUpv16KsTIE3YbsK7k7Dagu0eTAa4NvGgLXixM4gc3jOFVRqdTOLdbEJi8Nk2TCCoG3JAHCFXl4lJEqsQIekoi0kFqybY8tPl K5tk5tZpirJA3kFKUAfYXLDu Fwj/bn9Q90Cl1Cj7APtBFkW8iUiTOvLXn15PWzlEN/4EcF8ONP teGC0QCuAUf9IcjBnIvIVan8IcXGNsmfd0WUSZEjzpOqQchsIP0mLYLHeOHUVEdQKaOz/QjpMN 8UUPXJvpefUV6XcXyUOdIF2ykocxBTanv6AZeeRPtx1gBWnDFi9ehI08ebpHGvobeaFfEGmQf4z5Yj wE9g9PqkIMi/1Muz2AXVBXfhtYCS5KkLywNfA28Dffu9DH9Y43UcUSZ42IPo7IsxYMRhicMWgKjJxTs32wldJlxCTJvJhQpBXRmDyxwuWMWGCcOFXvAyy sCKCVpWkszJR5 4MDGAkEmdCDFIm6shiIehYRLFCg4GdKxEoG3yvjKEIKV4tQVIHSYFrPCgLF7WCkx6PUU 8I56QBawild0ewxlgVv/M9tXleRhQte3yUAqUB8m3Lz kRf16vbh2raD7vLakldPXj/byiE/VvV0XPqnxGB/sEm8hBYEwLVNiHywY5AJkFcQItQndqDbIuKK6lHkIPR9IL2oDiBTx2f6EdLzSF5efUX6PY/kycuAxbbxeTFdJ/q1bjs4 oEfn8AvfZyne5B04NDl4QcNbF7sBz8Q8SNPX7nV8/M6bM6gnka7nkjyhg00bXeIvA8y2yYNvT2YtECMMFlg4kcaSAPicNYI52kQJ4MsiJeUx4AsRMasR5 4inyMG1tPmEz0FRl85gkriFKvHuJzQ/JtXPmMmp6OFZnQD7xjgsJqIyYibPflTWZ6HbhGWdGFmSb3VUke5GCSw8MxIDwy6ZorHVKf9M ECROyV4NIPEIfyXO1Jc8O8vrZVk7aouPSSR7i8WPjzDPPzFbp0G49r 1aHtgBEUA/Io9ui1JG6g7Ro5RBCMIDvZsreagLcUV1YOIz/QjpeSQvr74i/e4ieSDXGAMwxsAnsb2OsQHnEYEN/SV2iB9gIX7g0j3qkDEIsvU/sZ/Pf/7zGR6SvOH60XXFa rGbwMkecMGGL/CmjUqEDQMvPJrGXixkgfyY5s09PZgBQ8THc7M6A8FYELFliUmWeSXQbYMySvyMW5MllgBwGQqOEHycAYH95jw9AEeWztC8kB2cCZPn4CLfOBdn6Bw1gurTPIpI8HiCvWyrjxVSR50gr5Cf2PCRV9ggvWRPJB12IeOqw6Sl9fPNvsBLuhNx2WSPMgEYcOKrG6fUgafcNLPeyFe9IKnQnFvkryiepS6EMJfcCYPL03W4 Fv6N iOjDx2fw1j Tl1Vek310kDz csD2rt1WItx4n1z4/yNM9dAocIgsh6oe/i/1gBR/ngnG V8/H62bnIOo/Nf2T5CU1gIAYYasKK1YgOLKihe0P26RhOiSIELZlZVJEOiYWxGGlAPcyyIaSPGx3ygfbQUiwbYNVMpTHQI90nazpmDCJ4Bc7npTEGShs9cqkivOCWJ0TOSAA oobDvGX/cC7OUFhqwiTjnz1AFvV utcdMxmWT1NrquSvLwPf f1D4gJ2iFPoMIuQBarnMmz2UFeP9vwARe227HVCru14YL9ov xDQviLbqUEEcJQLow8QMT5ID4g6ADD/Lptoj7onqUuiSEHuFvkIM65AwszjoW1YGJz aveSQvr74i/e4iefBB6B6rb5CHM3boMzmzKzqR0OcHebpHW7BqiIeusIKI7WYQTKzum/aDHylYxZd6GaZGMoi3WZslyUtu8MBAKB DB6GSCdw2aZjGhQP5si0radiOwSoR5CLOHGQRh4lBtvXMeuQ8kHywHedqBB8mCduqjNSNiRpEDxM1cMmDIUgH4frSl76UndWCHDxsgrqlLOrBE5qY G1PAeal2yYorGaCBKMOEE6cEZO69BBlZdtKQnMFJI/kSRkJcU5Sly/Xrg9/ /oH25jyFCv051vJExwSSlt89bj62VYObdKf/sSKm 2pX5zPBHbRgRmibWJbwAmbg1zJZ9oi4ovoUeToIYgp7B9kGaveOukpqgMdn lHqDOP5CHdVR/SQvvdRfIgAyvH BIIyB78MY9c2XwIMvQ/l 6RB08N6/6L1UjEm/aDH4rw8dCVdr1 Xg/vD pjNOqDJG/YoEQnGI1OMLLNWM1wnRmijYzUV4hOsDqk58MKmTxkI/HYqs8jFpKPYbk gN7ySB71Wl6v1B11104bIMkbNvG0s5PoPL3uF34wO77N4QEXbMVjqw5fFpEnvNG3OIaAlSis6Lpe2dFrG jX kjy4tt2v9oK29UPtkKSR5JnbLHQsfvBsdvXBmzHYSsQ257YkpXtOdgbtumx/YqnLml/7es79gn7hDaQqg2Q5HFSIcmjDdAGaAO0AdoAbaAPbaBGkieiDxw4uB0zMDCg1q9ff gAv6S6Q7wuwv4vVUZN3Pw1SBugDdAGaAO0AdpAr2xgJIsCtwIfGxwczI7KgKO5/uV 8UIKkeT1qjNZDwcO2gBtgDZAG6AN0AbEBoSJdUOSPC5Z9 GStRg8Qw5 tAHaAG2ANjBabKBL7uSKJI8kjySPNkAboA3QBmgDtIHkbUCoXTckyUu U0fLLxS2k7/GaQO0AdoAbYA24LaBLrmTK5I8kjz eqMN0AZoA7QB2gBtIHkbEGrXDUnyku9U/qpx/6qhbqgb2gBtgDZAGxgtNtAld3JFkkeSx19vtAHaAG2ANkAboA0kbwNC7bohSV7ynTpafqGwnfw1ThugDdAGaAO0AbcNdMmdXJHkkeTx1xttgDZAG6AN0AZoA8nbgFC7bkiSl3yn8leN wGcUAwAACAASURBVFcNdUPd0AZoA8Vt4O23t6mJEyeS9HB TMwGuuROrkjyaMSJGXHxAZuTHHVGG4hrA2 88bqaOnVqT8eO67T 3du2dYnRL3wgsvqFtuuUXdfPPNatasZ4blKdP3vSJ5wI9JePLkycMwP/HEE2rJkiVZ3LJlS9Wdd96hbrjhBvXzn/9cbdmyeVhe0cHg4C517bXXZn/XXXeduuuuu9Tq1auzvC /vEzdfvvtmY7mzHkui3vqqac6 aXcww8/nKWZskB4161bqyT 9dfXdzDs2rUzkws9I/2mm27qpInud wYUA8KC68cYb1R133KGWLFncyWOW2blzR5Zn7do1w2RJ/IYNb3RwCG6EvbZHaVu7QqF23ZAkjySv42ztMta4kxLbRn3SBuLZgIvkgUhg0hZdm/cSXzTcvHmzmjlzZkcuykvc vWvqUmTJmX17t49mK3AAV/ROvT8vSB5gh9YXSRv69Yt6tZbb82I3bvvDimQNZAkwSoycK TpQMH9qvXXnstI73QCWQgLwgZyN/GjRs6MkQWSN/KlSuy JGyXs0I18DA9owY3nnnnQp4UNZH8oAFJPHFF1/MSPrmzW8plF zZs2IuvbseSfLu2LFK8Pao8ebbRX8DOHfI/ R5JHkjXB2Oku8yZC6pC770QZATCZNmqimT5 erc5gBQirNLKyAkKh3y9btkzdf//92UrUz372M4WVqv3792VjzzPPPKMQB0K4fPnyLG7btq0ZcRPdzZ49u0MKzDis7gmxxGoPCIWsdi1evCgjOFjhw2ofygL7vffem638CBbkQx6QIawgmSTPhlFwILTVs3Tp0s7qGVYXQXb0MtKmPJKHVau77767oyuUh45EdyID8SYxA4kCoXv11XXq4Ycf6tT9/PNz1IIF8zv3KAsiiHoEoy5LMCMdhBordY8//rh67rmDK4I kof2mVvfaMOMGTMyDFLXvn3vqilTpqh58 bmxpttFXwMSfKGGTUNgpMvbYA2QBsoZwOYuEGQNm3aqN55Z3dndchcuZN75JcVKUzqIFnLl7 sNm7cqO65556MZLz55qaMBOpEA/2DexBKITauOMgHyQSJQZ633npTTZgwISNsqBMysIIlWLBKhnisjD322KNqaGiveuWVVzJsOsnLw iqBytusnqGOkBeQASR38QPPK6VPOT9xS ezLZr0S5gtslAHOoRko0QW7ZYzQOhggwp99JLC9Wzzz7buUf8QeK3oBMHWbLtCv2DKOJ/a3sxB9ftttt3VWB7FVLhiknNQHsvv44491ZCMePwJAQKUMbOnRRx9VP//5/Z18wGCLlzJmPVLf6A65ktcxoNFtCOUGduqMeqMN0AZgAyAm hkobKWuXr0qW7nC5Cx2opM8PT/OmWF7EKtwWCHC5I7tPKwoSVkJQVRctfDou3xSH/9u3bM3kgZlit0skM6sIWI7BPm/ZAR95DD83onF0DdmDWSZ4Po62euXNfHHY2ECRJVq6AU8fvI3nIj5VNnKUDsXrhhecz7LoM5NGJGe6xCgiiCZKVR/KgExBdtBPlRJZOGEGoUJ9eBwgxzgPivF1Vkoe6sNoIHFhJ1TGY8XqajhE/OAT/6A1J8mgE3J6mDdAGaAMVbaAqyQPxeOqpX2T9gBU6EAhsaeIBA3OCxiqQOYHrcSCGOjnE1uqiRS8p24oVZJskDyRCPx9mkjyUycNoq2fhwoVq9uxZnbbgoQWdWOr40TacKdTbDdKMlU6sRmLVS9JwNg0PYGDVUZeBdJ2ASX6sli1atMiyXdtdtYOuzIdVdFmoCyuiwKHHow48TIGyeSQP ja3a0EQUVZwY2sfOoYuQEyx7Y66bPF****5th cJHkdZxEnYGgzFMbRLmgDtAG3DbhIHlZicLBetlzlHk9jYvKWLVKsAIHE4KA/tukwoctWIEgFdA/ihmuTAJlxOKSPp06RH QAK4PAd/CA/x3Z6h7SsJKI1a2iJM FEZiB01YP2ibbmVL3ggUHiZWJH/cgSVgJxaoatpRxPhD6WLVqZbbNjJVFnFkDWQS5waqbqReTgIE4Iy8eloB84Ow eHFw1Qv9hIcgkEe3d1MWtp hPzMeq3jYUs0jeagDW/LdBy82Z3WivajTlAk9oT937epuGSOfxEOeWUbHPrqvSfKGGfLoNgb3AE69UDe0AdpAng24SB62R7H6AkKB8nKP7VmsKmFbFqQAB/excgPigq1YkASQQKwqoRzIIEgMzpOBHOhYbHFYTZIHJ bOPXhwH2UgD2QLZEcO9BcleTaMIDcgR4LLVg IHlbA0F60Ee1Ffht YMI5RazSgRCB3IlsrAqCLCMNOgFhtskA8dG3L6FvWaEEFqxQQs/yChXIB0E2n1pGvI1EAR8eoDFX0IBPJ3k6BlyDxOuvUIF9gOTLDwFbXdjafvrpp0fUhXg88GErI/oa3SFJXsdxRrchcAJj/9MGaAO9swGTFIbqftq0aSNWmWxxofLakC8G/hgymtIFVitB/GS7vikc/VkvSV4uycPZiv7s N4N5tQfdU0boA2YNlCW5JlyeN8/toVtavZn7P4kycs1qnHjxuWm0yBjGyTl0aZoA7QB2gBtgDYQxwZI8qwkDucSTjrpJDV27Fj17W f3HmEG4 dg/gdccQR6txzzx32hBc y3LiiSeqI488Ul1wwffU1q1bO7Lz0uJ0JB2CeqQN0AZoA7QB2gBtQLcBkrwOEdMN44QTTsgeb8cLHnFQ9vTTT1dr1qxWX/nKV7InwBB/9dVXqwsvvDArjwO0Rx99dHamAAdAr7nmGnXFFVd40/Q6ea0bJq9pD7QB2gBtgDZAG6hmAyR5VpJ3 OGHdz6Dg0fwx48fn72dXN7jA6VjdU62c/FI/de//vWOLDzt9OUvfzm7z0ur1nk0fuqPNkAboA3QBmgDtAGXDZDkdYiZbiTnnfdddfnllw/bctXTcY2XOWLFDtd44/gZZ5zRkYWVPmz14t1FeWmmTN67DJXxtA3aAG2ANkAboA0UswGSvA4x0xWHd/hcddVV2dm7yy67bATZW7VqlTrmmGM6q32zZs1SZ511VkcWnhICycPWbV6aXmfeNV48yT/qgDZAG6AN0AZoA VsIG O7d80krwOMbN1Mt4w/qMf/VCdeuqpnXx4qSe2Zhcu7H4GxrVaB7KXl2arE3EgiLY/V/42x69evbqjuzbjdGEj/uZ/ObMPmu0D6r9Z/WNsYh9U6wMQY9cY39/xJHkjOh6rdPrnYbDlethhhylswWJlDk/d6h93hoHgoQys7Imx6Gfy8tIkvy EgYL0 fK1MZ2DU7XBqWqfpq5/tD/1NhA/fWC0 3HTPkCS1yV769atUwMDA2pwEJ8JHFIHDsA/7f/ 2/v u/rdD/wP9b4P/pH6vQ99WP3ehz7S RsjRSAAgiB0/fr1avr06ZKUGwKI/V 9A8aGDRuybVo8WAGCN2PG9OzJWXzKBq9Nuf/0eQLTxdi9U9 eYinrzFCiAcOy8t1PFJ8urt87x aHpwysMWkpY6frQx9TYQf3P 2w/20w9taNoHSPK6bGrUkzw41COPzFTHHntstnqGd9 B8OF7ibYtVGzHogyMCKt88p48fEAa8b40yZMXkuQ1N0k0PTjl2UVIWur40cbU20D8zflvP9hPP7ShaR8gySPJ6xAymThxng7vy5P7JkOSvOYmiaYHp6p2lzp tD/1NhB/c/7bD/bTD21o2gdI8kjyrGRuy5bN1viqE2/R8iR5zU0STQ9ORW3FzJ86frQn9TYQf3P 2w/20w9taNoHSPJI8lpB5swJWu5J8pqbJJoenMQGyoap40e7U28D8Tfnv03ZzzcmHqNsf LHtrTQOJHRpjAUO/I1gZskjySvEcMLNXaSvOYmCU7Qzele/IN90GwfUP/F9e8iPWLTrvSQeJHRpjAEt RpAjdJHkkeSd6hh0RiOyAniOITRMw SF3/0EXqbSD 0ecDJqHx3ft8HjZkyvCV6WW6D1vT EnySPJI8kjyrDbACbrZCZokj/qvSlaa8GGT9PjufW1smiT58JntM/M3jZ8kjyTPOsGbhtrUPbdrm5vompggYtpZ6vihi9TbQPzN W9T9mOSHt 9z dhQ6YMX5lepvuwNY2fJI8kjySPK3lWG AE3ewE3dQkHXOCpA0dtCEhAiFh6vqXNko7fPeSzxU2TZJcuCTebJ/ES6jj9 WVMjFDkjySPOsEH9PIqsjiSl5zRIMTdHO6F59hHzTbB7H0L5N7SCh9HyOMhb8IFmmjlPHdSz5XiDaYMlx5m4j3YdPx /LWgZ8krwaSp3/jDN88w7fP8A00fAst5F9TnzWrw8CqyiTJa26Sa2KCqGovevnU8aMtqbeB A/6b8jkHpJHtQ6yb0b7bDd 9rB9pgyvCV6WW6D5veB768deAmyeuyrmifNSPJi0dMSPLi6bLoAKIPTkXLtiF/6vihw9TbQPwkeSaxMe99YwVsqGgZn8yY6T5sug/48sbEJbJI8kjyuF3LM3lWG9AHJxkwUgpTxw9dp94G4ifJM4mNee8bU2BDRcv4ZMZM92HTfcCXNyYukUWSR5JnneDFQJoOuZLHlbyyNqgPrmVlNF0u9TYQP0meSWzMe5 PwYaKlvHJjJnuw6b7gC9vTFwiiySPJI8kjyt5VhvQBycZMFIKU8cPXafeBuInyTOJjXnvG1NgQ0XL GTGTPdh033AlzcmLpFFkkeSZ53gxUCaDrmSx5W8sjaoD65lZTRdLvU2ED9JnklszHufj8GGipbxyYyZ7sOm 4Avb0xcIoskjySPJI8reVYb0AcnGTBSClPHD12n3gbiL07yhAhIWMXnmtC/idt372sf2mDK8JXpZboPm94Hvrx14CbJI8mzTvB1GFsZmVzJ40peGbtBGX1wLSuj6XKpt4H4SfJMYmPe 3wMNlS0jE9mzHQfNt0HfHlj4hJZJHkkeSR5XMmz2oA OMmAkVKYOn7oOvU2EH84yTN9KwYhaEL/Jm7fvdlu8x5tMGWYeZq892HT 0DyStgL3CR5JHnWCb4XxhdSB1fyuJIXYie2PPrgaktPIS71NhA/SZ5JaMx7nx/ChoqW8cmMme7DpvuA5JUwJg6XLJK8Gkje//xfn1Xy98ef/N/qI5/4a/VHH/9L9aGPfKJbW84Vv3jRJTYkeV1duJy4rnh9cKqrjjrlpo4fukm9DcRPkmcSGvPeNwbAhoqW8cmMme7DZvMBX5mY EjyumSryBcvwNfA28DfwOOE0yEco9 Q5FUjKSR51fRXZbCwDU5V5PW6bOr4oa/U20D8JHkmoTHvfeMCbKhoGZ/MmOk bDYf8JWJiY8kjySv1du14gxtCkMd0ObcoWXbkI/4myPY0v/sg2b7IJb ZfySfg0Jy5Qx5cbCb8rNuzdx7zZCENbTBl Mr0Mt2HzdYHvjIx8ZPkkeSR5E08pjOIiPPlhaEOaHPu0LJtyEf8zRIM2AD7oNk iKV/GU K LWUkbBIWckbC7/ICwlNvL57n0y0wZThK9PLdB82Wx/4ysTET5JHktdqktem7dqijmlz7pjOW7cs4m WYKB/2QfN9kEs/RcdO9D3UkbCMv4eC3 Ruk28vnufbLTBlOEr08t0HzZbH/jKxMRPkkeSR5IX AqVoo5pc 6Yzlu3LOJvlmCgf9kHzfZBLP0XHTt0365SNhZ HY/v2sTru/fJQxtMGb4yvUz3YbP1gZRBWDdWkjySvNqNrIoRcyWvuUnONjhV6ctel00dP/SVehuI/6D/yqRexgeqlG1C/yZe371PJ2iDKcNXppfpPmy2PpAyCOvGSpJHkle7kVUxYpI8kryy9mMbXMvKaqpc6m0g/ngkrwwhaEL/QmDEZ3z3ks8Vog2mDFfeJuJ92Fx94CsXqy0keSR5JHncrrXagGtwijX41C0ndfzQT ptIH6SPJPMmPe cQA2VLSMT2bMdB82lw/4ysXCSJJHkmed4GMZWFU5XMnjSl5ZG3INrmXlNVEu9TYQf3WSB7srSwia0L J1Xfv8yu0wZThK9PLdB82Vx/4ysVqA0keSR5JHlfyrDbgGpxiDT51y0kdP/STehuInyTPJDPmvW8cgA0VLeOTGTPdh83lA75ysTCS5JHkWSf4WAZWVQ5X8riSV9aGXINrWXlNlEu9DcRPkmeSGfPe51ewoaJlfDJjpvuwuXzAVy4WRpI8kjySPK7kWW3ANTjFGnzqlpM6fugn9TYQP0meSWbMe984ABsqWsYnM2a6D5vLB6SchDEx6bJI8npE8i79z2vUaWee260t5wof0bX/a25VRzeaXl5zJa 5PncNTr3s/yp1pY4fbU 9DcRPkmeSGPPe5 OwoaJlfDJjpvuwuXxAykkYE5MuiySvy6bArQYGBtTg4KAaGhpSBw7AP 3/PvSRT6g/ vhfqo984q/VH3/yf6v/ b8 2/kbIzczHnlSbdj4pjr93O rZ2Y/p 688267NCOWJK9LbEjyurrQHbcX167BqRd1x6gjdfzQQeptIP64JK8oIWhC/yZG373P19EGU4avTC/Tfdh8feArX7UtJHldghWV5H3uH/9VrX11vVq1Zp36m88fRZIXuCVqGjRJHkmeaROh977BNVROk/lSbwPxk SZJMa89/kXbKhoGZ/MmOk bD4f8JWvipUkryaSd/KZF6htb29XMx97Klvu40peObJCkldOb1UHBpT3DU4x6qhTRur42QfN2b7YZSwbijWRixwzFLxmGAu/KTfvXrBJHt 95HOFaIMpw5W3iXgfNl8f MpXbRNJXk0k76bbJ6rB3bvV1dfe3CF599//825tOVfcru0O7m0keeKU/Raag4lvcDLzt 0 dfzQZ ptIP6DY5mMFVV9ROSYoUtuE/oXbILJdy/5XCHaYMpw5W0i3ofN1we 8lXbRJLXJVtRt2ufefYFtXnLVvWNk8/ukLxJk 7t1pZzRZJHkieO38vQHEx8g5OZv233qeOHPlNvA/HHJXmmj8n4YMbLfRP6NzH57gWrK0QbTBmuvE3E 7D5 sBXvmqbSPK6ZCsayTvupLPUutdeV3MXLMqeysDTGdyu7RK3IkbbppW8IriR1 fcReXVld81yKSC36WX1PGnZEP92gexbMjlYy69hcb75MbCH4oH UxMvnufbLTBlOEr08t0HzZfH0h5CWNjJ8mrgeTdPGGSGtixU0245 ckeSUfuBBDJ8krR45FfyGha3DxDU4hspvMkzp 6C71NhA/V/LM8cW8940RsKGiZXwyY6b7sPl8QMpLGBMbZJHk1UDyFi5elpG8s793KUkeSZ71RcOxHbmKPNfg4hucqtTZi7Kp44eOUm8D8ZPkmeOLee8bC2BDUiYk9MmLnS6YXHJDfcAnxyXfF0 SVwPJ279/f7Zdi9eo4CV63K4tvxrFlbzyuvM5v6S7BpfQwUnktC1MHT/0mXobiL83JK9NPmxi8d37xg3YkMgICX3yYqcLJpfcUB/wyXHJ98WT5NVA8iBy swnsrcjk RVIykkedX05xsAkO4aXEIHp5A6msiTOn7oLPU2ED9Jnjm mPe sSHUhorK9dUbmu6rt2n8JHk1kDz54gVCIXn4PAY kxHyj0/XdokNSV5XF6GDTtF8rkEqdHAqWl v8qeOH3pKvQ3EXy/JE19qkw bWHz30gZXGGpDZj0uebHjffU2jZ8kr8u6oj1dS5IXj5iQ5MXTpWtwcw1SoYOTS27T8anjh/5SbwPxk TJ GKGoeNDqA2J/FC5sfL56i2KX RJWBUnSR5JXqsfDCDJI8krO8iFDq5l5feiXOptIP7ekjyTGDShfxOD3JthqP EtkHkh8qNlc9Xb1H8Ik/CqjhJ8kjySPIqPgHscsJQ53aV71W8azBJBb9LT6njR7tSbwPxk S5/DM0PtSGXONYaD1l8/nqDcVv1i9yJTTTQ 9J8kjyrCTvpZcWWuNDDStWPq7kcSWvrC2VHVzL1ldHudTbQPy9IXlieyYhaEL/JgbBVjYMbUPsekPx uoNxW/WJ3IlNNND70nySPKsZG7cuHHW FDDipWPJI8kr6wtlR1cy9ZXR7nU20D8JHlV/SLUhoQMSVi13tDyvvpC8bvq88l3lZN4kjySvGFkbsWKV9RJJ52kxo4dq7797ZPV2rVrsvTXXntVTZw4UZ1yyilq4cIFw8o8/vhj6hvfOE4deeSR6qKLvq 2b397WDqMbdWqVerwww9X8 bNHZEmxmgLSfJI8mx2ERJXdXANqaPuPKm3gfhJ8qr6SKgNCRmSsGq9oeV99YXid9Xnk 8qJ/EkeSR5w0jXCSecoKZNe0C9885uNWHCBHX66adn6SeeeKK65567MzKnkzyQvy9/ csZiUOZq6Wl1zzTXDZMLYzjjjjIwEkuTVT9rEuUND1yBSdXAKrb ufKnjh15SbwPxk RV9e iNuQaz6ricJX31VcUv1mPT76Z37wnySPJG0bIsNq2ZcvmLG7nzh1q/Pjxw9KxuqeTvDff3KTmz5/fyfPiiy92iKEY28yZD6srrrhCnXrqqVzJq khD9F1mdA1iFQdnMpgiVkmdfzQReptIP5mSJ74dBP6l7pj XLRNsSu39cOX31F8Zv1 eSb c17kjySvA5Bg3Gcd9531eWXX662bt06LF4MxyR5Eo8QpPCyyy7LVgAlfseOAfX1r389k0eS175VPPSTaxCpOjiJDTQVpo4feku9DcRPklfV/4vakGs8q4rDVd5XX1H8Zj0iXw/NPHn3JHkkecPIHEjZVVddpY444oiMsJlkz0XyLrjge9k5PjywAbInRoet2ylTpmT3JHkkeWIXvQirDq69wOirI/U2EH9vSZ7YkxCCJvQvdQuWqmHRNsSu34ffV19R/GZ9Il8PzTx59yR5JHkdQqYbCh6e NGPfphtserxLpKHPIODu9T111 vLr744kzm8uUvZw9x7N /L5jk4YEP2x8chX/16EAGD q3Hv1Sr9Rrr32s1/XpNt5k3cAh9UuoY6vjulf16G0r2g59Dh89111yJ1ej/rNmeAJ20qRJHdK3d 8eddhhh2UPYYhhmCTv9dfXq8WLF3XKvPrqOvXVr341u8fWrY2w3XffvZ38ItcV4lcIZLjS2xwPR2wzPsEmg5TcS5gKfsFrhqnjR3tSbwPxcyXP9Mui90VtSMYzCYvWVzS/r56i PPq99VlK8uVPKF4So16krdhw4Zsm3bJksUKBG/GjOnq6KOPHkZUTJK3dOlS9bWv/Wv2qhU8XXvzzTepCy 8cFgZMTxu13K7VmyhF2HMwbUXeG11pN4G4ifJs9l1kbiyNlSGEBXBJXl99ZTFL/L10FeXnleuSfJI8oYRskcemamOPfbYbPUMr00B4RNjQWiSPMThlSsog3N8OJu3efNbw8pIeZI8kjyxhV6EMQfXXuC11ZF6G4i/WZIHUmCzqzrjyhCRPDxlbSg2DhdGXz1l8dvq89VlK0OSVwPJW7hwocLfggUL1Ny5c9Xs2bPVI488on7yk590a8u5wpKi/V9vSMLQ0F6F9 XZDKbXcdyurb/PXQNHzMGp13aD lLH3w9tSL0PYuF3 VhdfiH1IayrDpdcqduVXjS bB8Ijrp1IPW42lUWv02e1CWhLY8ZR5LXZVNFtmvB18DbwN/A48DnhNuNGRoaUvjbu3evGhwcVFu2bFFr165VU6dO7daWc9U0yYORyLvyTIPp9T1JHkleWZuLObiWxVC1XOptIP5mVvJgd0WIQFU71cvHrresDQkOhDq 2NdSj0tuWfw2eVKXhLY8ZhxJXpdsFSF54GvgbeBv4HHgc8Lt oLkmYbS1D1JHkleWduLObiWxVC1XOptIH6SvCZ9oAgZKovTV0cdPuCrU28LSR5JXq2/cnRjK3NNktc7kicDRz FZWyuTWXqmCB62T7iJ8mram9VbEjGsqoY8sr76qiC31Wvr069HEkeSR5JXk2fGqvDuXXnjXUtA0Y/hrF01JScVGzIpR/ib57kiV 7 ih2fOz6qthQbCw2XfnqqILfVh/ifHXq5UjySPJI8kY5ydMHBP26jsFJl1/ndZFBsE4cVWWn3AdoO/GT5DXpA70YB3x11OEDvjp1nZPkkeSR5JHkWW2gjsFJH3zqvC4yCNaJo6rslPsAbSf 5kie6L/XvhC7vio2JFgkrOqPtvI 2VXw2 pDnNQpoSsf4knySPKsE3ye0fQyDQbKL14cnCh6qXfUVcfg1Ks2hAx vcJSpZ6U yB1G4qJvyl7hP30uu7Y9VXxAcEiYRVfdJX1ya6C31enr26UJ8kjySPJ40qe1QbqGJxcg1bs JDBL3addchLuQ gD Jvz0qe IQZxrZbkR9Lbgwbio1Jb5tPdgz8en36tdQtoZ4m1yR5JHnWCV4MpOmQK3nNrOKh3 scnOq2q7xBr2jdIssMi8opkz/lPkB7iZ8kr4zd62Vi2JD4ri431rVPdgz8LqxSt4S2fCR5JHkkeVzJs9pAnYOTbTCKGZc36BWtR2SZoU2OmUfubXlD4lLuA7SP JsneS47q2qbvZIbw4bqait04JMdA79L1xKfh4EkjyTPOsGL8TQdciWPK3llbFAGvaKhrS6RIWlyXySUskXDXkwQRTEVyU/8JHlF7MWWN4YNmb5qq6dsnMh2lY B3yVb4vMwkOSR5JHkcSXPagO9GJxkkIodyqBXNLThEBmSJvd5oSuvxIeGKfcB2kj8JHmhtu7KF8OGTF911VUmXmS7ysbA75It8XkYSPJqJXlb1bKnXlBLNqb37VoxnqZDruRxJa MDcqgJ6FPRl6 vDSRK3kk9MVLui/sxQThw1AlnfhJ8qrYD8rGtCHTP6tiQ3mfzJj4XXgFg4R6PpK8WknePHXFn52k7niZJE83uiLXJHkkeUXsRfLKYCehxLvCvHx5aSJP8kgo8RK64iXdFfZignDVHSOe NtPNGtCFAAAIABJREFU8srapss YsuLaUOxsUEHPpkx8ft0bsNCkkeSZ92qcxlTr NJ8kjyyticDHYS mTk5ctLE7mSR0KJl9AVL musBcThKvuGPHET5JX1Y5i2lBZP8xrg09mTPx5OJBmw0KSR5JHksczeVYb6OXg5Bu8iqbLYCehr3xevrw0kSt5JJR4CV3xku4KU 4DtIn420vyxObK2qaUN8PY8mLakGCT0MRe5t4nKyZ Hz4bFpI8kjzrBO8zpl6lcyWPK3llbE0GOwl9MvLy5aWJXMkjocRLKPESSrwv7OUE4cNSJp34SfLK2I1eJqYNif9JqNdT9tonKyZ H0YblhCS9/KbS1vNA3zttqd3yZ1crVu3Tg0MDKjBwUE1NDSkDhyAf9r/TZ06Va1du1Zt2bIly793796sDMqNwX/427uXZ/Lsyg8nLiR54bqqqmuzfC8HJ7Puqvcy2Enok5eXLy/NJ1fSRYaEEu8LU 4DtI34SfJ8Nu5Lr8OGivphHkafrDrwu/AIFgmRL4TknTv9TJI8g uR5NW0xWkaL0keSZ5pEyH3MshJ6CuTly8vzSfXTC8qq5cThIk1xj3xp0Pyitqmyz5iyRH5ddhQTIw WXXgF92YoWCREOl5JG/t1tXqwoe/m53lGz/zfLX 7dcysrdh4HU1fekD6vuPfE8t27RkGAFc8dZydcHD56qT7j9e/eip/1Tbd2/rpOelCdZ7F9zTOTsoOBG um2tem7dbAXCeeL9/6b 88nL1OZdb3ZkS/nw0GBtSimu5PWIuIV30kEDHTt2bIWOJkkqom89by8HJ73eGNf64IFrn0zJb8uXl2bLnxdXVFbKfQA9ED9JXp4/hKTVYUNF/TAPp09WHfjz8CBNx5RH8s6b8e/q8RWPqD3vvqOmLLpfXfLo GysBImbtmSK vcHvzOM5O0/sE dMfUUNWfds2r30KC67YWb1I3PXpuVyUvLwwtCCWL32tuvqlMnn6hWb1mZ4bn1 Z pq395pXfsdsvuGcn7M/WpT31K/emf/qn66Ec/OrJWSwzYpv1fc4TFrch6MXElr1795vVrE4NTHp4iaTLISegrm5cvL80n10wvKivlPkDbib/9JE9stKhtSjkzjCVH5NZhQ4JRQqmrTOiTUQd H04dUx7J 7dJx6q3d2/NiNTg3p3qmqevGkaqsLqnr St27pGnT3tjE6ejQMb1CmTv5Xd56Xl4b39hVvUo8sfVsvfXKaeWPFYRzZWBattI49kUTWs5O3NDuzh4B4O8GGPN QfSV6X2JDkdXWR5yh1pDUxOMVqhwxyEvrk5uXLS/PJNdNFFkIzzXafch gPcRPkmez6yJxddiQ7oehvujCLLJc6XXgd9Ul8TqmPJJ35S/ Q93w7H8N23IVGQhNkvfSGwvUDx77fmfswgog6hrat0flpeky9eude3Zkq3dYFdTjcY3tYqwUmvHh9yPZFkket2srGNRIMtaEc4c7wEi8ZtmU8csgJ6HZNvM L19eminHdy yEPryIj3lPiD ro9Jv4f0ecw8RewnFsZYckQPRdogZULDGFh9MurE72qnYEKYR/JAsm6ac0N2Bu662T8dQfZMkjf3tRfUZY9f3Bm73t03lJE8kLS8NBfOGUunKazkmek4n3fmA6d2VhnN9LB7krwRig1TXHfg6kV ruT1Vt96nzYxOOn1V7nWBzlc 2SZ W33Phmh6SI7JH/KfYD2Ef9B/y3S5yF2EZqniP4Fox6G1qPnk/J6XJXrIm0oWk8MrD4ZdeJ3tVcwIcwjeVJ x54BdfOcG9VFj1wwbKw0SZ5rtQ5kLy9N6tHDffvfzYicPOwhaVsHt2Rbwvo2saQVC0nyhnVmMeX1jniQ5PVO16YNNDE4mRjK3uuDHK59csz8tnufjNB0kR2SP U QPuInyQvxM7z8tRpQ0V80YXRJ6NO/C5MeryL5GG1DCtpkhdbruMm/p/soQeJM0keHo7ACpuk62fy8tIkvx7iSdornri0IwtpWBHE075I0/OWuybJi6DE gkISV79OnY5UNODkwtXSLwMvBKGlDHzSFkJzfSy9yJPwjw5KfcB2uXDLzqQME8XTaT58Idiaqp9ZfFXwVulrE2fZdtgk2XGCdYyociSsnJvhnXiN uy3btI3ls7N2XbtHjAAQTvFysfz56c1WWYJA9P0OLBi1lrfpkRMjwBixVAlMlLw0MZulxcY9Vw3voXO/FY2cNrUx5 eXonzixT7J4kL5Ii6yUhJHn16jfPaZoenPKw dJk4JXQl9 WLmUltOUpEyfyJBQZci8h4n19IHklFFltCfsdf6iem ofn/5d KvgrVLWhqdsG2yyzDjBGiM0Zct9nfiljrzQRfJQ5unVT6mzpp2WnavDa1NA HRZJslD2qrNK7LVNnlP3sA72ztlbGl4ave0KScpPd/Kza9k9YIYSn2LNizsvPpF7w9sA0ueYiFJXknF9ZZ0kOT1Vt 6EzU9OOlYil7rgwSui5ZH/hgy8uoV ZJH7l2h5NNDM6 e1oZrnw2Z OW DdiBwYc/FGdT7SqLX/BKGNpO5CtTJk9 2TbkyaySJu0zQ5fMpvHnkTxgxnk6vC/PhT/deJK8JDqVJI8kr8wgEzoA58mOISNEvuQx67PdS14JzTwS35bQN8GZ M37ptvhwx KT9oVmj9WvrL4Ba ERfCUKZMnv2wb8mT2Mq1p/D6SB13Iu/J6qZf66yLJI8mr ZUxTTt3VSdKGb9MNBKW0YWUlbCMjLwyplzzHmXRBxIfEubV10Saz4akTYJN7iWU KZCH/5QXE21pyr MrjLlMnTY9U25MnuRVrT ENIXi/00Ps6SPJI8kjycm2g6cGpyqAgE42EZWRJWQnLyMgrI3LNUC8jfWDm8d3rMpq8FvwuDNIOM90Vb ar 96HP7T ptpTFX8Z3GXK5OmxahvyZPcirWn8ISRvx4tP5s4FvdBT/DpqJHmvvvqqwh/erowOXrp0qZozZ4669dZbR9ZqieEXL7pblNyu7eoivhPky256cKrSXploJCwjS8pKWEZGXhmRa4Z6GVcfmGXMe11Gk9cu/IJJcMu9hK54Se9V6MMfiqOp9lTFXwZ3mTJ5eqzahjzZvUhrGn8IyVv8BXxyNX8 SC99JLkq8sUL8DXwNvA39CHKCrcbI6IPHDighoaG1MDAgFq/fr2aPh2PBvv/keR1jY0kr6uLXjtZ04NTlfbKRCNhGVlSVsIyMkLKiHwJ9TKuPpC8EkoZ817imwpd AWPC6/ESyj5ex368IfiaaodVfELbglD2lskb4i8qm0IqaPOPE3jzyN5u5a oJZZNq7v81Ri39yqfU7pWLMrK3Y95TaslRn1DzP/MeteKkv1N733p9BAkcXD5fzf2LX1Xbn505Ig36fOu azO5kC1/B/YffJo2RH71PhnJtYqQPPA18DbwN/A48Dn5R5IX8RcBSR5JXhlnl4lGwqZkhNQrGCXUy7gmCMkroZQx7yW qdCFX/C48Eq8hJK/16EPfyieptpRFb/gljCkvUXyhsir2oaQOurM0zT PJK35IiPqTcn/ljt271LvX7t WrZMX REbaFn/uA2vLQnVn82u8fp1adfeQIIvfy//krNf z73WSPMh74/rhX9AQPYfIl7zlQ6Fk3ZAkLyI5K98xw0kNSd5wfcTSa4icpgenEIyuPDLRSOjKlxcvZSXMy1slTeRLqMsq2gciQ0JdVhPXPvw nL70utvkwx9af1PtaAJ/7LbGakNoX8XO1zT PJKHlThZpXt3xza18rTD1NDmDWreX/5ah9Rh1W3xP/1J5x76eWvyjWrNeV9Vy772506SB3K4eepNw8qhbIj8OH3QJXdyRZJHkjfCIKsYW9POXQU7yqaMXyYaCcvoQspKWEZGSBmRL6FepmgfiAwJdVlNXPvw 3D60utukw9/aP1NtSM2/pB2hOQJ1RvyxWpDkTpj5m0afx7Je Vbn1Orz/2XjHhJm7GlClInK3nrLjlerbv0m5258d3tW9Siwz6clckjeStO/nuFlcL5f/1basmRH1c75j dyfDJFxzVQ6F23ZAkr4UkT/by2xCK0QkW3704d2h n7xep6eMXyYaCdEHRfUnZSUsWj5GfvRBGfsRzAjLlC jL1t7ffgFp6s SUdok4 4Otvnwx9av7QjNL9LH0XLx8Yv7cjDJ3mAtShe5o9rz inPJIHwrbmgmOys3erzzmqQ/YGnn9czf3zX8l8a HffVAhn/TnuovHqU13/TC7zyN5bz81VWEVcP e3dmWMOTsH9qTlcuTL/VUD7vkTq5I8kjyOhOGTBx6KEYncb57DLDIE5rfJ6/X6Snjl4lGQvRBUf1JWQmLlo Rv wkLZgRNml/PvyC09U/ko4whj4ho4g fPhD5Uk7QvO79FG0fCz8gkfaIaENj55mSy if5YvZq 6vkTPeSQP fE3tO0ttXb8sdn2K65f v9 X G1Kjirt FnF6lXvvm3Wb5di dkD2rIAxR5JE9kS/jSP/yBwsMaefIlb5xQqF03JMlrIcmDgY4dO7YzwMfp/N6cc8MAmxJeE2vK GWikdBsWyr3VfqgDW334Q/BGJKnrv704Q tt6k2xMIv7ZR2SCjxepiXpucLvY7dhtB6Y VrGr L5IFwbbjl0s4chRU3rN5tfexehYcqpP0geiCMSMdqn5BHPdx423908qMcSODWmXcPixOS9/YvpznlS51xwi65kyuSPJK8YUZZ1dCadu7RjF8mGgmr6qKp8lVsqA1t9 EPwRiSp67 8eEPrbepNsTCb7Yzrz15aaackPu62hBSd4w8TeN3kbw961dl27Q4KwcCh1eeYAUvi//se9XOhbOyeGzNmg9eiF7Mlbxdy Z25lCcx8MDGpCNBzAgG9u1ReRLPeVCoXbdsDaS9 abb/I9eSUJJFfyerPqaHOipgcnG6bQOJloJAwt17Z8VfpA2i5hE23z4Q/BJnkk7GU7fPhDsTSBHdhi4TfbmdeevDRTTsh9XW0IqTtGnqbxu0ge2gbytWjsH2arc3gvnjwcgYcu8IJkPDTx8tc/rQZXLOyQN10nOsnD07l4NcrQ1k1ZXrxzL3vNyl//VvYOvp2Lnu3ICJWv11X8ukvu5Coaydu fXsmc/fu3Z2XIa9Zs0ZNmzZN6soNAcT r7kJv7iC42AlyYujxzL91/TgVAazXiZ1/GhLlTbIZCuhrpteXfvwh2CTPBL2CntV/es4m8AeE7/eFlxLeyTU021xenrRa58NFZXX6/xN488jedAFVtew6tZrvdRf30gWFY3kiejBwUG1Z8 e7I3Jr732Gr94UWI1jySPJK/sYND04FoWt14uRhtiT7o6Pt 1D38RbEXy nCFpvvwh8ppAjuwxcJvtlPaI6GebovT04te19WGojjK5m8av4/koV3yrryybWxnOWFi3TAqyXv33Xezz2BMmTJF/dM//ZN63/vep97//vd3a8u54kpel9iQ5HV10WtHanpwqtre1PGj/THaIJOuhFX1WqS8D38RTJJXwiI4yub14Q V20vMOqZY HWZ rWtXbY4vUzR67rbUBRP0fxN4w8heUXblEb kSQrGsmT75zdeeedasyYMeo973mP tjHPqZ 93d/d2StlhiSvC6xIcnr6qLXjtX04FS1vanjR/tjtEEmXQmr6rVIeR/ Ipgkr4RFcJTN68MfKreXmHVMsfDrMvVraZct1PNVua67DVWwhZRtGj9JXpdkRSN5 JDtzp07OwTvkksuUfPmzeN2Lbdrkzr30PTgFDKA5uVJHT/aFrMNMhHn6Sx2mg9/GUxlypRtlw9/qNxeYtYxxcKvy9SvpV22UM9X5bruNlTBFlK2afwkeTWQPIh87rnnMpKHlTw8dLF /Xo1derUbm05V21fyXvpJfuTNiEGXzQPV/K4klfUZiR/04Or4KgSxmyDTMRV8BQt68NfBpOUkbAopiL5ffhDZfUCqw1LLPw22WactFFCM73sfS/bUBZjXrmm8ZPkdclWtJW8/fv3q1/ 8pcZyfvN3/xN9corr2R/06dP79aWc9V2kjdu3LierUiR5JHk5Q2geWlND6552ELTYrZBJl8zDMVSJp8Pv2ApIlvKSFikbNG8Pvyh8nqB1YYlFn6bbDNO2iihmV72vpdtKIsxr1zT EnyumQrGsmDyI0bN2Yk79d//dezFTys5E2ePLlbW85VW0neihWvqJNOOin7AsW3v32yWrt2TYfsYeXy1FNPVUcddVQnTgw/L03yuEKSPJI8l2344pseXH34QtJjtkEmXzMMwVE2jw /YCkjX8pKWEaGr4wPv6 8pNeJUeqwhbHw22SbcdJGCc30sve9bENZjHnlmsZPktclW1FJ3rZt29R3vvOdjOi9973vVSeffLL6h3/4h25tOVdtJXknnHCCmjbtAfXOO7vVhAkT1Omnn54ROpC4Y489Vj3//JwsTTf4vDQ9n uaJI8kz2UbvvimB1cfvpD0OtsQezK2tceHvwoGKSuhrf6qcT78ofLrxJiHIRb vDrqTku9DU3jJ8nrkq1oJG/v3r2Z1IGBAXX22Wer3/7t3 6cz tW575qK8k7/PDD1ZYtmzNit3PnDjV /PjsGqt7rnN6eWkhgwNJHkleiJ3Y8jQ9uNowFY2rsw1CPCQsii0kvw9/jLpjyHC1xYffVc6MrxOjWZd Hwu/LrPX16m3oWn8JHldrhWN5IlIPGULord48eJsq/aGG26QpNywrSTvvPO qy6//HK1devWzpbsjh0D6gtf EIWf SRRyps465atSpLz0sLHShI8kjyQm3FzNf04GriKXNfZxuEeEhYBp vjA9/jLpFhoQ TEXSffhDZdWBLaTuWPhD6qorT ptaBo/SV6XbkUlebt27cpehox35oHorV27Nvmna0HarrrqKnXEEUeoyy67LCN7IHRjx45VDz74YLZVO2nSJIVtXTh8XlrogECSR5IXaitmvqYHVxNPmftetKEqAZHyZoj2 vBLmTK6kTIiQ0KJjxH68IfWUQe2kLpj4Q pq648qbehafwkeTWRPIiVlTw8dIE/EKGQf21dyRMn3r79bfWjH/0we9Bi5coV2Xk8Sdu/f5/64he/mG3r5qVJfjMEYbT9wVH4Rx3QBuLbgBAQCYvqWMqZYYgcKROS15cnpixfXUXT24ytaFuYP74P1q1Tc54dHfcj2Va0lbzdu3d3VvFkJQ8kD584C/nXRpKHVTms0olx7N27Rx122GHqzTc3ZaRuaAjnEA8oIXlvv71NgQyC8NnSRI4v5EoeV/J8NuJKx8DpSkslvhdtEAIiYVHdmOXkXsI8eSF58srraSJLQj2t7HUs/cfEVKQtsfAXqTN23tTb0DR ruR1WVc0kici8f1akLw33ngjW8lL T15GzZsyLZplyxZrEDwZsyYro4uhsEj333HPVLbfconbvHlT33Xdvdi5PHD0vTfLkhSR5JHl59pGX1vTgmoctNK2XbShLRMxyci9hXltD8uSV19NElh7q6WWuY lfMJXBUKVMLPxVMFQtm3obmsZPkieMTKnoJA/btfpKXsokD476yCMzs61ZbKeeeOKJCoQP8Xji9vzzz89I4Jlnfke99tqrnRWUvLQQ5yfJI8kLsRNbnqYHVxumonG9bENZIuIq54rXdRCSR88fci0yEYbkz8sTS/ CKa uOtJi4a8DW6jM1NvQNH6SPJK8QgMhtl7lwYpQJ62SjySPJK s/TQ9uJbFrZfrZRuEiBQlR1JOx41riTdDPZ k6XExrmPJjaX/WHiK6iYW/qL1xsyfehuaxk SR5JXiOTBeeVdeTEd2SWLJI8kz2UbvvimB1cfvpD0XrZBiAjCEGySR8rJvYQSb4aSjlDS9LgY1yJXwrIyY m/Ko6m8ZetP0a5WH0QA0sZGU3jJ8kjySs0oJcx8iplSPJI8sraT9ODa1ncerlet6EMGckro OXfAiljRIn97FCkSthWbk6/rIyUK4qjrJ1x8Jftv4Y5VJvQ9P4SfJI8joDbgyHjC2DJI8kr6xNNT24lsWtl t1G8qQkbwyOn7Jh1DaKHFyHzsU RIWla/jL1pWz1 2fl1GmetY MvUHatM6m1oGj9JHkleZ8CN5ZQx5ZDkkeSVtaemB9eyuPVyvW6DkBEz1DGZ15LXjMe9id/Ma97bZFSJE/kSFpVl4i9aXvKXrV/Klw1j4S9bf4xyqbehafwkeSR5JHmqHiLVtHNXHWCJvx67KNIvve4DISNmmIdZ8trymPglrxnaysaMk/qKyjTxFy0v cvWL XLhrHwl60/RrnU29A0fpI8kjySPJI8qw00PThVnSBSx4/2N90GIScS2vokL83EL3nN0CY3ZlzZ kz8wGTKyruXNkgeue9VaMPfq7pj1ZN6G5rGT5JHkmed4GM5aFU53K5tbjWp6cGpqu2kjh/tb7oNQk4ktPVJXpoLv5SR0CY3ZpzUI2GobBt kVEmDK03Vj4b/liyeyUn9TY0jZ8kjySPJI8reVYbaHpwqjqJpI4f7W9LG1yEBhglzdZfLvxSRkJb2TriitZnwx8iQ/KYYR1typNpw5 Xv41pqbehafwkeSR51gm Lc7OlTyu5JW1xaYH17K49XJtaYNJVuQeWPVrHTuuXfiljIRmubrupT4JffXY8IeW9cnuRboNfy/qjVlH6m1oGj9JHkkeSR5X8qw20PTgVHWiSB0/2t/WNgjR0UNbf7UNv45Xv7Zhd lfyrnKtCm bfovo5vU29A0fpI8kjzrBF/GGesow5U8ruSVtaumB9eyuPVybW2DEB091HHLdUr49bbo19IWCSVN7tsctlX/RXSWehuaxk SR5JHkseVPKsNND04FZkIbHlTx482tbkNQnYkTLEPBHtIKO2TvHLf5rDN9hOqt9Tb0DR kjySPOsEH qAdefjSh5X8sraWNODa1ncernU25AyfiFzEkq/mPcS38YwZf2LPlNvQ9P4SfJI8kjyuJJntYGmBycZ5MuGqeNHu1NvQz/gF1JnhmXtspflUtc/faD6j3ySPJI86wTfy4Eory6u5FV38jz95qWlPkGkjh99k3ob gG/Se7kPs932pKWuv7pA9XHf5I8kjySPK7kWW0g9Qkidfyc4KpPcFXJVuo2lDpkB1HyDJI8mzTvBVB8dY5bmSV93Jy/ZF6hNE6vg5wTVnIzqdtQ6vjpA9V9gCSPJI8kjyt5VhtIfYJIHT8nuOoTnJC1smHqNpQ6fvpAdR8gySPJs07wZQfF2OW4klfdycv2SeoTROr4OcE1Z/viM6nbUOr46QPVfYAkjySPJI8reVYbSH2CSB0/J7jqE5yQtbJh6jaUOn76QHUfIMkjybNO8GUHxdjluJJX3cnL9knqE0Tq DnBNWf74jOp21Dq OkD1X2AJI8kjySPK3lWG0h9gkgdPye46hOckLWyYeo2lDpkB1HyDJI8mzTvBlB8XY5biSV93Jy/ZJ6hNE6vg5wTVnIzqdtQ6vjpA9V9gCSPJI8kjyt5VhtIfYJIHT8nuOoTnJC1smHqNpQ6fvpAdR8gySPJs07wZQfF2OW4klfdycv2SeoTROr4OcE1Z/viM6nbUOr46QPVfYAkjySPJI8reVYbSH2CSB0/J7jqE5yQtbJh6jaUOn76QHUfIMkjybNO8GUHxdjluJJX3cnL9knqE0Tq DnBNWf74jOp21Dq OkD1X2AJI8kjySPK3lWG0h9gkgdPye46hOckLWyYeo2lDpkB1HyDJI8mzTvBlB8XY5biSV93Jy/ZJ6hNE6vg5wTVnIzqdtQ6vjpA9V9gCSPJI8kjyt5VhtIfYJIHT8nuOoTnJC1smHqNpQ6fvpAdR8gySPJs07wZQfF2OW4klfdycv2SeoTROr4OcE1Z/viM6nbUOr46QPVfYAkjySPJI8reVYbSH2CSB0/J7jqE5yQtbJh6jaUOn76QHUfIMkjybNO8GUHxdjluJJX3cnL9knqE0Tq DnBNWf74jOp21Dq OkD1X2AJI8kjySPK3lWG0h9gkgdPye46hOckLWyYeo2lDpkB1HyDJI8mzTvBlB8XY5biSV93Jy/ZJ6hNE6vg5wTVnIzqdtQ6vjpA9V9gCSPJI8kjyt5VhtIfYJIHT8nuOoTnJC1smHqNpQ6fvpAdR8gySPJs07wZQfF2OW4klfdycv2SeoTROr4OcE1Z/viM6nbUOr46QPVfYAkjySPJI8reVYbSH2CSB0/J7jqE5yQtbJh6jaUOn76QHUfIMkjybNO8GUHxdjluJJX3cnL9knqE0Tq DnBNWf74jOp21Dq OkD1X2AJI8kjySPK3lWG0h9gkgdPye46hOckLWyYeo2lDpkB1HyDJI8mzTvBlB8XY5biSV93Jy/ZJ6hNE6vg5wTVnIzqdtQ6vjpA9V9gCSPJI8kjyt5VhtIfYJIHT8nuOoTnJC1smHqNpQ6fvpAdR8gySPJs07wZQfF2OW4klfdycv2SeoTROr4OcE1Z/viM6nbUOr46QPVfYAkjySPJI8reVYbSH2CSB0/J7jqE5yQtbJh6jaUOn76QHUfIMkjybNO8GUHxdjluJJX3cnL9knqE0Tq DnBNWf74jOp21Dq OkD1X2AJI8kjySPK3lWG0h9gkgdPye46hOckLWyYeo2lDpkB1HyDJI8mzTvBlB8WXXloYVR5X8qo7edm TH2CSB0/J7jmbF98JnUbSh0/faC6D5DkkeRFJWXjxo2LKo8kr7qTy4RVNEx9gkgdPye45mxffCV1G0odP32gug Q5JHkRSFlK1a8ok466SQ1duxY9e1vn6zWrl2TyV2yZLE68cQT1ZFHHqkuuOB7auvWrYXqI8mr7uQyYRUNU58gUsfPCa452xdfSd2GUsdPH6juAyR5JHmFSJcMfmZ4wgknqGnTHlDvvLNbTZgwQZ0jQFSRAAAgAElEQVRulq//596uijj1ZPPfULNTi4S11zzTXqiiuuKFQfSV51Jzf7KvQ 9Qkidfzop9TbQPzN W8/2E8/tKFpHyDJI8krRLpcBOHwww9XW7ZszmTt3LlDjR8/Xq1cuUJ9/etf78h//fX16stf/nLn3iVLjyfJa26SaHpw0u2gzHXq NHm1NtA/M35bz/YTz 0oWkfIMkjyStEulyT7XnnfVddfvnlw7ZjX3jheXXGGWd05GOVD9u5e/fu6cS55Ek8SV5zk0TTg5PYQNkwdfxod ptIP7m/Lcf7Kcf2tC0D5DkkeQFE668yXbHjgF11VVXqSOOOEJddtllGdmbNWuWOuusszryh4b2ZiQPW7d5svQ0krzmJommByfdDspcp44fbU69DcTfnP/2g/30Qxua9gGSPJK8YMIVMtFu3/62 tGPfqhOPfVU5VrJA9lzycJKH/ oA9oAbYA2QBugDcSxAdd829/xXXInV vWrVMDAwNqcHBQDQ0NqQMH8CPM/m/69Olq/fr1WX4z7xgpAgFIhFBkRqGQfwBi/9fsr0KXQaxatUpNmjSpQ9ywHXvYYYepl19 WR1zzDGd DJn8lAnHN1Vd5vjU8UtOiX 5v2NfdBsH1D/zeo/5fG/X8ZRaUd64UgWRZJX8ssPGzZsyLZp8boUELwZM6ZnT9Xi6Vo8ePHoo49mT9deffXV2SpfUWNJdaBNFbf0D/FzghNbKBvShpq1odT1D7tLvQ2p4y/r 82XI8mLujr2yCMz1bHHHps5JN6LB8KHTsZ5ALw/T96T9/bb2wrXm6qTpIpbnJP4m52g0Q/sg2b7gPpvVv/0geb1L/NBeiFJXmGy5etknLXD /J8 YqmpzrQpopb icV/Js2bVQTJ05UM2c rPbte7djf6ngF33bwtTb0Hb8 AzjvHlzOzZj9kHb8Zt4zfvU8aM9qbchdfymTaVzT5LnHNiqdKK8K6 MDGz73nnnHdlLlfWHM1JwEnzxQz XiPangBs433xzk9UWUsCPL6t89atfzV60jS tnHvuuZ22tB2/y95132l7GzZvfktNmTJFPfPM0x29p4IfBO8rX/lKttOgY9av265/HavNj1PCj7bYSHfb2 Dz47bj122ov65J8qyDclOdvGbN6myy/slPfpw9mXvee3Cp9PL9/85jfV00//MinM0iZgv/3225LEfumll2Y/CtAW/DDAkQE84CNta2uYur1Dr3jg6mtf 1cFn4UNFf2aTZN9AzKBHwdLly7NxhuETeKJUXfKfoz2h5DuGHqKKaMf/DimPtoliySvVYMaVmCeeOKJDBMm62984zgFB2qX0djPR CXHCYMYMU7ACdP/nn2V/Q7vU20FToHocYDMikSvYsu r66//77O3aC86BXXvmf6mc/ 5nCNm4TOg2pM2V7l/adc8452ScLcb9792DmA/jajaS3NdQJHjA 9NBDmc20FW8IrtT9WO8TvH4rFdLdD34cYl9p5qmR5D22eI3C36OLVquHF6xQDzy3SN39 LPqkv 6eWStlpjUXqESwwBAMrDlKbJuvvmmbPCV zaH2LLCtg eLMav6Ysvvlj94AeXZHHLl7/caVMb24Avkrz66rpsyzZFogf94qGe66 /PvuUHh7ywdbhjTfekBFXfGWljXpP2d5Fn/ghJvaNJ nxuiToHUcuirzwXOT1KsQPA51EgKDic4spEFSXjlL2Y53goX0pke5 8GOXTaUfP5JcFXmFyr2Tp7jfk7d7926FP7xwD /I27Rpk1q5cqWaPHnyyFotMaOR5N12263ZwXkxrAcemKomTJjQmaD1A/WSp00hfn1iBQmfdhNcv/jFk9n2ISZAiWtDqJ/dwcurBRPiUyR62J598MEHM xYVZX2gHBjApH7NoWp2zt0CR/FDwRcY UU sZT9thCxypfm/Ttw4IXuONsoS9fW9NT9uOUSXc/ HFbbbo6rpHkqgjJ 8G1N6uXV662vwyZJMral3mu wKrYfrrvuumzQxQCGFZqVK1e0YhDWSZK0CSsDhx9DBiijSsdrQFt2DNO7uTKtFD2/7t3/5Nvfbaq5mNYKscqzNVHgQSffUibLO9S/vzfBZkWlbv8KMGxxdsfiKyeh36sMB/YT 9xlW2Pl97UvZj6CRV0p2CH5e1ufTKVSN5d0y6Tz0yZwFJXpmODzmsik i4Vu4QvDuuuuu1gzALpKEVQxs286fPz/DCoKB zadzQs5u9P2CeLZZ2dbCQTOQuLBC2zdIpw27YHW2IzPT9ps78Ae4rPSRtj9UUcdpdq0Ve7yWcGMEK9/auvKr44T1yHtabsfm23S71Mj3YK97X4sOEdHWI3kYWV/4pPPkeSVMZaQw6p4ifJZZ52VreC1ieD5SNJzzz2XrWKMGzcuI3j4 kcZHdVVJvTsDiYIbMfVhaOs3B07BrKzX66Hcl588UV1zz13Zy/hLltHXeVc5BT1tdXeRRc n8W5Nqy QPdYvcb2uZRtOvT5rODDAzyXXXZZa3ALLjMMbQ/KtdGPQaSfeuoXXj23lXTnHR1qux bttTf99VIHo7X4VkKHLkb8e1abtfmb9eGHFZ9443Xs/fMtYngwSFCSBK2q/B6iTJf96jb6VI u4PtQmzBXnjhhd4Jom49FpXvI6dttXdpp89nYfM4MI9V1LathoX4LNoJ3zDfdSntb1MY2p42Ydax4GtIWOn1Eb02km6QOJy/dj2k03Y/1vuh/69J8hqbKEMPqy5evKgxjC4HSJkk2dqU2pYOHmbB07T605G2drUpLpScttHeRY hPiv52xT2m8/2Q3tCiF7bSDe2Yi 44HvZd9pPOeUUJ9Frsx 3yS/rx0KS1xoChe2Htj5k4TPE1EiSrT0ptEF/QhlEDysBKRG9FMmpzVYkjj6bv1sheupFmIL/2vQQQvRs5ZqIw1PkOF NJ/mxXYsnyPOIXhMYWafpkyR5rSF5qR9WTXWQ1QcFtKGNZ/CwpYMt2i996UvD8KVA9LBFi1U80XMKmAWrL6TPmhNKs/epjEGzZs3Kzj3Kj7ZUiB4eqsMqnvgF8JPoNWvz0hfukCSvY7BuJcXrRDiF6xxDPxxWbStJwpO9rocUetHvVerAr ejjz46ewUNJgN8Qks/oymkCS jrlJPHWXxQuYjjjhCffGLX1T4Cge sYt6BHMKq5ApPyiC84E6wbb1cVt91oY1JC6F9uA1O6effnpyRA/ C3/W35SAOQ07CmhP3sMYIX3HPPG4RleXJHk9mxixGgNnwGoM3obf7YSDHdvmw6p4HUQK30IVneLQuxAIfEsXOscZNrwDrG3v6xPMrhATNZ7YRDqwg Th/Ws60RPy5JLRRDyeNMUrLvDOPgz eNIU9o HcYBHiF4byanoK/UHRfAAyNVXXz1irJH2pRSmNgbZdAt7kvg8otcmfzZXHX/6059mW7TyQB0I35lnfid78ffMmQ932iftZFgHcSsikySvJ0YJAqefZXC9O6uNh1VBTkGSsBoDspHCrzUh1CB6WEECQcUvTrzKBWRP/3Rc2wYhEFQ8OSgTAojdtdf V7YCjPfePf/8nGxFbOzYseqaa65pZX9g9QhkFJ 20/ULoodXQkhcmyYzwSRhPzwogkP72ObH6pa0K8UwxTFI9IyxH9cYg9AX thjI3pt 9FjYsT4D6KHH2zYqsUuw OPP6bwUJJt8UL0wLAIMYuZlySvJ4MfDmjjszWmoeN9cmZcm 7h4CBJGKhAOvDOPrQjBaInK0Xnn3/ MB1jZQzv72uTnnUseJnxYYcdlr0bUYge0h999NHsW8C4xrdSx48f3 rvGov ZUUVuEG0QbJlNU9vdxuv0YbUnmKGfYP8C7HDZxExKbdRvyGYUh6DME7ifYn43B3aCh82iR6O78Df2/ZuQn3sMYke2oLjL3jROvwb4xF2F9r8oy3E1vozD0leTwY/GD cW3/sHwaFX0HYhmijcWElA46LF8AKPqxApkb0bJM02tXWM3ryoXiQaXzGTgZbvOAY72nDlgi2nXHoX/ql6RCrE5s2bRyBxyR6WKXAirDvnFiT7YG dXxmG5rEFlI3sP/kJz/Ozk4hxNjT5nEmr039MAbhuAJWtU2iB2KEtqONOM GhYA8XfQyLXTVEZjwHj8QWfnCUS9xsq6QFT SvJ45Fs7G4OyCTNo4ywDi59q6bYMBY4LDQVt9NUYneliZaQPOPAzmJA1SDeInKx15ZZtKw4Rw4403ZOepdKKHT8yA/KFNTWGz1Qu7/sIXvqCuuOKKEeRZ9I VCmw3t krEGZbUn9QRPdHjC wI4wxIBk4n2e2N4X7fhiDTKKH7U1sd IYBnYVsMLXtr4IXXXESqRud21rB/GQ5NXiXBiYMLjiLBscGcQIS/f4Di1WkTAZ4tc1Ju02GqHutDJJm0SvjQOTTe/QL JB7ECQ8KsTW1pt1LtgwooX7AcDKMiRTvQkT5tCkCOcI8RWM wbr1nQz5dC//CFtn0FQtdhyg K4MyajDfmK4BgQzgrhX6Rw/J6u9t4bR72T2kMcunTJHpY/QYJx9PbrjK9inetxAvRa/OqY690lG49JHnRHQwTtGwHYtXonHPOybY4xUjgMFjN0A/gSlrToWuysA2yTWM16/fpXYhemyY6ECHYClZZzO1O/BDAjwAQbhxwbjvRw4rEwoULsh80 CwWSAeIn0xibbYhbJml qCI7xU74icTJ04c9kS2xLcxtJ0Ba7P9hOpQiJ5JxEPL15UvbyU hVXHuvTSH3JJ8qKTPJyVOu 872ZyQegwecybNzd6PbEN0DdZyCALMhW77rLysDIkZ1lC9N62g8HAg6eucdYOIcgc3pcIfeCpWsSD5AnRw9PBZXVVdzmcFQSpQz1DQ3sVHnjBDxzYP56oBYmFDeGHRN1YysgX 9ZXrKF3rAC3 UGRkFfsQB9YlWnb4X6zn QoC LziF6bxiCzDb57PB1/zDHHtMoHfCvxbVp19OmX6eY5PZK86M6GyQwTA1YwdIKHCVzfwmqDMcrj/cASMlm0iSSB4GEVTCbllPSu9z10inZgqxNPq2E7GWQJAy8eckGo52/rNYgdjiBgqw3btVde Z8ZOcUxBemjtmB3bU ZRA9kom0PipR9xQ6OiuDhnbb0geCQMSj0sH bxiBpQ5EQP/xxNrVImV7k9a3E9wID6zAJWox7krxKzobl98svvzxbqcDqnWxN4ZUFeI8ZXsQLw8UWISbANv0CNR/vT l9bCbBk8EhBb0LVj0UoidnNGFHIHiHH354Z3VMz9/Wazxph9dBCMFrK8687Skhem19UKRfXrED2zDHIDkDph9laesrRorYNh7yuvnmm7JVbDwZj8 DFSnfi7whK/G9wME6YhA7XQZJXmlnE6KBiQ0ECSth2HLDgxYYvDDRYSXvBz 4JCN4bTuHAWeSMyLyeD/iMNACM67xq7Nt72PDaijOe5mrQ3jnYCp6tw1kIHqwn/vuu7djk5js2jgh2PAjDg8v4KlBnM1z5WlDvG97CkSvrQ KpPiKnbw N8cgIXoYe1Cuja8YyWuPLQ0/7rEYgOMLbV2ZT2kl3qZjxunETr8mySs1GbmIBpwZv9Ruv/22TC4maUwY2IpoqxGag2yb38cGHdrIEF43gi3OvXv3JKN3mz3Y2mbL1 Y42D6eYm4zRmDzbU/Jip75Y6IN7UrtFTs nZljEA/765N0765TWYn32RPTdZshySs1GeVNxvjliTN5ctYkBYMzB9m2vo9NdKnrXwgeDmpLesqhtK2N5CJEr3jhN56uDcnbZJ6Q7SkQvTY KIIfkym9Yiekn80xCD Q2/KKkRD8/ZAnlZX4ftB179pAkld6MpLJWN9ek46T11/IfQqhDLJt3Fa26U/0j0PM/ULwpJ3ml1EknqH C7XadQrbU/30ip0Q201tDAppU2p5UlmJT02vzeElyStN8tBpQjRMoofPCeGAdHMdW24CbOPj/Xk6dOk/rwzTytlGP qt7dtTYt/98IqdUPtJbQwKbVcq VJZiU9Fn83jJMmrTMRkIBaihydp8cBFStu1Yohtfbxf8NlCU/ 2PIwjsbPZQArbU7DvfnjFjk3/trgUxyBbOxjHMacdNkCSV5nkoSOFaEyYMCH7MkFKq3gpPN7vcxbRf6rn2HztY3p9E0YK21NC9FJ/xY7LjvthDHK1jfH1 S51G6JbkrwoJA/GJkTjrrvuiiazF0acwuP9IXrgObYQh2ce05ZS2Z6S8UV2DNCO1F6xY pe7vtlDJL2MOQ40x4bIMmLSshINOjc7XFu9kW/9YWN6PVbG9ke i1tIKYNkORFJXk0zpjGSVm0J9qAaQNC9Hg0gbZh2gbvaRMjbYAkjyRP0TFGOgZ1Qp201wa4Y9DevqHfsG/aZQMkeSR5JHm0AdoAbYA2QBugDfShDZDk9WGn8pdUu35JsT/YH7QB2gBtgDbQhA2Q5JHk8dcbbYA2QBugDdAGaAN9aAMkeX3YqU38WmCd/JVKG6AN0AZoA7SBdtkASR5JHn 90QZoA7QB2gBtgDbQhzZAktfaTt21a6e6 eab1UUXXaRuvfVWtWfPO2r//n1q0qSJ6pJLLlF33HGHevfdoSxu2bKlWV75lBo vo6vbyDf9OkPjmhjqOzQfO365cJfkuwP2gBtgDZAG6ANjKR4Sq1bt04NDAyowcFBNTQ0pA4cgJ7s/yZPnqzufvzZLL Zd8zu3bsV/iAIAjdt2qRWrlypUCjkH4DY/42OjnvqqafU7NmzFQgbPpM2f/58he863nvvpIzwTZkyWb300kvq1VfXZXG33HJL53u5CxYsUA8 OE29887ujPwhj 7wobJD8 myeT067JP9zH6mDdAGaANtt4GRLIokr4VL1o88MjP7bNozzzyjFi1alBG2V15Zrp544vEOeZs6dUqH5D3GNq9epVWdq8efPUnDlzOvlMpwyRjTKh Uz5vG/7IEB8tFHaAG2ANtCfNkCS5yQ/benwdevWKvle5ZNPPqlefnlZhhkkbubMhzv4dZI3d 5cNWPGdDU4uCvb3sWKoK09obJD89nqYBwHT9oAbYA2QBugDTRhAyR5VvLTFmPEh7tvu 02tXfvngwnVvKwRQt82LoF6ROsOsnDWT1s31522WXqpptu6qz SV6EobJD8 myed2EM7NO2h1tgDZAG6AN6DZAktchSW0zjJ07d2REDaFgwxbtPffck53Jwzm9JUsWd9J0kof8eEhjw4Y31HXXXad27x7s5ENaqOzQfIKPoe5cvKY90AZoA7QB2kCTNkCSN4z8tMkYn376afW9732v83f77bd3nq69 OKL1V133ZU9XSuYTZL385/fr66//vrswQzJI2Go7NB8Ipdhk87Muml/tAHaAG2ANqDbAElea0keDVU3VF7THmgDtAHaAG2ANlDMBkjySPJa DRxMSOm01NftAHaAG2ANkAbGGkDJHkkeSR5tAHaAG2ANkAboA30oQ0kSfJGgmYMNUANUAPUADVADVAD1EC BhJ4GXJ A5hKDVAD1AA1QA1QA9QANTBSAyR5I3XCGGqAGqAGqAFqgBqgBpLXAEle8l3IBlAD1AA1QA1QA9QANTBSAyR5I3XCGGqAGqAGqAFqgBqgBpLXAEle8l3IBlAD1AA1QA1QA9QANTBSAyR5I3XCGGqAGqAGqAFqgBqgBpLXAEle8l3IBlAD1AA1QA1QA9QANTBSAyR5I3XCGGqAGqAGqAFqgBqgBpLXAEle8l3IBlAD1AA1QA1QA9QANTBSAyR5I3XCGGqAGqAGqAFqgBqgBpLXAEle8l3IBlAD1AA1QA1QA9QANTBSAyR5I3XCGGqAGqAGqAFqgBqgBpLXAEle8l3IBlAD1AA1QA1QA9QANTBSA6OE5B1QSuX9jVQMY6gBaoAaoAaoAWqAGkhZA6OE5KXcRcRODVAD1AA1QA1QA9RAcQ30NcnbtGmTevnll9Ury1eqlSvXqFUrVx 8XrFKrVy5Ovt75ZWVaunSpeqNN96waGuu7449Xxw/6uU/MtORE1/4bj1fEXzFAbHOlh0RvUjAvMOg/eX eqOEzwKMx1sP8unF6tR Iobr66rrJtxEFCKdDASNvI/Pf4Q/69cYa68Pjjldfn5l njj/ QjVjYxytbph ob/OOFVRSq4GzHE4Xh/nVutKnH dasc45gKYF19sHs2TdDDtUN/cUG1CjDNf 9E2naNvSd7 /fvVj3/8YzVlyhQ1ffrD6s47Jqpr/ tGNWP6TPXQQ4 oG2 4Rd1y8wQ1/cGH1JQpU9UVV1yh9u7da/SHOREcMtaKxmVU4rzFgH 8TDrOXExwa8DsP3fOulNGy4BStx7jyR9pG8NIXmhFMUleKLEMxcZ8JTVwiERoP8oOjsVNEb2RtlqyYQ0VG4m/DeNhGzD0okP6luTt27dP3XvvfR0dbt68RS1btrxzv2bNWrV167bO/T33TFI7d 3q3B 8yDPOg2nHX3Bh9ov/ Bvmj1jJOzhpHFqV04ihHp/362w4yTtUX0eOhi2baI5X192AVYWRq36h9RmN74NbTUeW1hzUr6yaHlrBGTZpSx8fWp3V0oaV7fSJ8ev/UPywvCTtlp5oImqkbRz0E/tKXteHLlTX3aD9 DpkExdqq /d1b9D9pP5pEYQDvnrQV VeD3v8Qmv2jTRl5Hr1PzcKvlQ/x3s5 GE8KCvX6gO2sOFasaTB8fkCy AzRxaGT5E5g/2v wMyerUdd3do4xk2scUK67WRo70NTVMh0oNGyM946lSoius5B3yG20e7sSZfiflsvjr1HVRdt5aq/QOsL4meXfeebfauXOnGhwcVK 8skI999yc7Hr37t3Z/dn/fk62igdCeNttd2RpHc1kF6ZxHjKozAjFuLrbs9lEcOjXnzh7to2j/ULP4uUXohY/vN6DdwdlyCAgjmAhIzJpDCMVB/MVqc GIe04s/ 01gwbZPSBWivTGYwP6rLTv1lZ6Rctvy4zu5YJPNZWvoaflxU1cMh/D/0okh9HnZVz3Tf1fu1MFLofCinT7ejgtfyI6/ryyDz4gZj90 us2DoWL6 Bbl85ZNjsYdi4r23zH8ordiAERH4IdMYUh10dzKeNMQ5I7Y624D9k65leMh0VGU8P ZB1Hnb5ncyfMiYf8n Zi9utwEro pbkYbv2mmt rB577An1wgsvqgceeFDdeuvtatas2eqZZ2apY489Tp1xxnfUmWeerU479Sz1w6uuUXsc27XdCQCrPsONsTNAG2fyus6r988h4zQmlu4AoOcVo5T6lFKZYxw00mHy///23jXKruJKE7w/pnqtaQMip7tquqfdjGdYtmqt6lqDrV64usZ2 QVjXAWJs0gvjG0ZMwNGVSW3H4DLgCxIJ1C8wbyEMZIsOpOXEC5ImbIwpIRRqgAhycjmIQkLlIAEBilToJRIYe1ZOyJ2xI44j3vi3nMzT96771qZ5xWxY 8v9o74zo5z7vUGHVRE3z3esiGuPb/1djhKGVyMWR5 eE5h5mO7AZfLzR3iLRucLFU36EPlB2bgIn/h/Zporx3gndE2uP4kM3S/mnhjhCuc9L1j5jfKjSg7EPiC9gnmX9Z/wvhmBIEUk 2UIuD1b1rLdnzFi2aM9UgeEQkaV1ifmro0Rugt oCRk0r4k76aplZ1z6Xob IDx8j48ZRjpWXbebhe3DFS1yljctuSvIMHD8Jdd92j/P6hh/4F/u7v5sOmTc o4 uuux7OO 8fYffuPer4lptvU9cxo d/UpzTFgicK4bkMUez4lJ2koONdu6FQytVSt SCG/Q4QOLPwClNNHmp7L7LxHgfLJW zqdT4PQwltvgYXmAXuPDKQgyAct6qNEeyn15NRUIpD0Da9fSyJ51P8Jy7zJKEksE XlxNQhwMeCtFa98dYfY/WYXZ/kUSbPiefEhW7oiRwmfdXVmwl7Kfqz PLiLsWc5HjKsdKyQ5KXFnfhGBwepzTdFqfaluQhYRsYuBMWLfoxXHfdj AXv1gF3/zmt6Cvrx/uu28F7NgxCjt2vGI78Sc/WQz79k3YY72T4py2ROBcAcnzg93J8c7XGUySJI ye5hRTA4k5Oi8Xkx71rS22XG4J0zKGahpSQXvsnEw1hiyN6d5XTZY8WwgyaDBplMGlATOlT2R9A09maQQLt7flHGhjH4Qw66f/ck/cT7l0QqdqaeJvbLAdYBift hwd44amJex7aZB4pm8ugZMtX/nKzw/fYneS4eeFIisNuLLR6vHCuDP2VAKT5Nf/B2vD6kfiiYcJnJTt 2JA875Vvf g584xvz1LN4uGz7gx9cBBdf/EN4 umnYXDwLrjnnuVq faxx34F1157PRw4cCDoS 5YwSVyEutcyeeulIPRsowtZxzUnCcSEErHY 2UbDkHT1IGgDsnTUKpL14Uby9Nh5l9zgwA1AdmS3fRlryp8z7Ouu/8CZ/3VXrfGh g9lgfubb8dmY2vjNZ 2Rsp/U5 Yrr7/QXL grVFQ56neKVeUP7KbMO89JnfNX7mszGeWZq7s/bno31UQksF9/cAvcgi/dmD73iURAYAgMM167pVq8wImLG e1/zFd7DxCwmbC1vm1W6b2x0EXX2cBJSvQMu88xZWHlZHNcfHii8Ud1TPjvbx4kfSdFStWwOAvR2B8fBwmJyfh0CH8EQn9qeHLDPiHLzlgAfyOuq1btwJWKvJBtlnmBzN5d9zxP Cdd/apZdlnntkMa9eug4mJ/bB7925F/DZs2KjesH3rrbdg8eKlKS9elKlRSbKMA9Pko6QSyWvua4NKUlDECAJthkAQX6k3X21mspgjCAgC7YFA22bykOQlv0LlBdtr BUqr73mvsEUn9/DN3Gr/LF3NfaOxmgbTEJVtkF0EwRmHgIsk2KytN5N1swzSDQWBASBDkGgbUkevl17ww03wMMPPwyPrXkc7r33Z3D7Ty YTAYAACAASURBVH4Kq1f/CoYfXQNLFt8Bdw7eC6uHH4NHH3kUrrrqqpTl2g7xAjFTEBAEBAFBQBAQBNoOgbYledhT27dvh6eeego2bvy1erN208Zfw4anN8HT6zeoLZ7fuGGTKoNLy/IRBAQBQUAQEAQEAUGgXRBoa5LXLp0kdggCgoAgIAgIAoKAIBCLQIeQPHxDJO8vFjYpLwgIAoKAICAICAKCQLURaCuSR2/4yla/6Sw4CA7iA ID4gPiA IDM9cHmqWQQvLMV79IEMzcIJC k74THxAfEB YmT6wfv16aJe/VvigkDyGQAjwrSOT8O8vAqidW/8Py2H5UIYcz8yBQ/pN k18QHxAfKD6PoAErx0 aEcr/K1ZbNo6k1eU4BEJxPK8k becBoU eN1vP2tS6C7VoOFq6sfaJ7ekt30/ECwEf8VHxAfEB9o3AeGF9SgVjN/C4a98bUTSN6LH/mAZ3PoSxv/r6MyrwvJYwiEwBF5y9oe QOA4W0AJy91mT4uowjBwzK8Dt/fvrQbuhcshO7AqXkZ2W984BDsBDvxAfEB8YGK 8DqhVDrWQLbty6BJasnAAkfT3y0O8lDgkd/ab6KBG/kz/8zDP/Z 1O5BKM4De22dSYvi9zR aUmSzy2vxUkbzss6emGJVtpS4E4DAtr3bBk6UJzZ4Nl8Jy y leul13tMkC0t2PPu/K ecnYAIDKXGnpNtauKCbtUV6dMY27w4SAw6JuBqAwuylwh/7JgUnr28WwrCty/sno64qiz6B9ag8lzEBEyS/xJsDZSeXx/0FB2BrQ4q9eI2XR/9luCjZxvfc4E22BX4dyPL8netXT58Sruf7BvaRPxl5GKRglsA4VUeNi8PJ GACv7AfyGfY TwfpbZpgqVj2mb2p7abxhKuZ9oENTHhl6/xPmRt2H6mmKOxqsZ9n/kMw3d4ge9v6XowXMjGJrbRvmFjuRaMJ k2ORvYdYsJ2etf4xi6 uXa3RK56AfoF4bkhW20luSNQH tBv3rHD8a6XNZxZ5B96tXrgTt7YSBXr8urOu382xYN2u5lggebbn9nOD9y5/ RyF5BH3WloOH 0Tm0rbfesBJOebaFpA8HIDNgIeDvwtQE7jmmh5M9ECnJgkzuG1fPewm3tSBGuWYAdIb7PWgq9vTbVHbqi0 CDcxCIZYV/KYcMu4g7Rkik0o2g6auGiw5QOpvkaTH8eU7/O DLHBa7o 9k83dAdkQtXFAb kvtI xuVpvyAbVHu5bWk9idhp/bjvmX3Ce0LfrZPfEc7cZiVL a2payZ/0inErPRj0jXVNzQ SHScPvmYJTHmPuP2qZyVyzEgnVLi0vmMk6VxTfNRViZVZnZ/qr618eCXS sD33c0Rm7sMbpxG/m 8RO6yUJsdF0/xiaQQFmdmG0pOKXpGH2OMCvsG9zffd2zbUq3A/GkuHF13Y2f9ZtW2d4iueT31Ne8T1pJ8ojQWZKnSFo/jOD0PzoAPbUeGBh1XMDtaXKIY4CtC3jOlFd1jRxTKYvkoa1E8GiL54oQPCzX7KdjMnm4NEtk75OLHGyn3 3O43XufM0s13qDMg5sdpDKmSxocKFAUwOiueuw9XFwQBluclQZBnbdDbw5bVEb7bxFPJG8pN5B4mBsMqoMO x/PdAu0RlXlrHivkH7fCB2uJvsTCpx4hMW9o/WgQZ2nRnpBpV9pfrcD2oZE2HoO6ZfyQ/VIOvJy/Yfsi1zyyZqZbPFz9iTwIxNfKin9V12XunLsUmfBDN1ivXjTN9AnRAbP3Y0oUrHLBXjNH1Um0u8DGEx/DJwUf1giFQWrnje9k8Gpqw/uT9Tli6GWNj6WfqEuFj9fLwVLuSv03EDgG0nxo0M3wh8xemeb1PCl1k/JK6ZjGlMXyRlZPR/2CetOkY8lyafU28ZyUNC1zfgZ M4OeP7jhIAAGbwkMAFWUBOEFUZTgBBvSGchzkRvGeP d8LEzyU1 ynI0geErk9EwCYsfvApXofgcPlWiJ tOWd1DjJ08FNSx56S3fcOYFvBzx9Z2gnQ3aeSABlVZS 3nVOMHLaalUgV0yuIjeYFQsmOhyIFbEKsFOTuSqL2FGfpQyOakBGAs4mfrYU5UhbUBfbs5OXaWM1uwlAuT1LYBiXkU25rKyutSHMnKX0gUfy0ialwA4eB G m8S4r6Gdvr/Zenzy8vDWJM9hhcc5mKfYZdto4FqWb2iZoS3 scIgwMzHOOh3hQ36iraZJmuOZSZ ns8wuQrX5kke10Ht21jRNrv YW2n4o3lmT5WTtjPTg5ipuWzuhRHtr55XMDGjavfTP/n1Y33Dee3DsM6NgUYYpvkFwndeAwF9RJlq3qdSHPgz60heUjQkKilLLkqcleDWu8A5C3WQhrJs3W0XL5km5fJoz6KJXhYr9lPR5C8Ta9pmJDobXxV7 M5InZ8S52B24ZJnjeR6QHJDaR64KRgdufNQGYGNjf4GcKnzmdMgnywN5OIGzjdwOG1VdWBoBV6hXeQiBdNIF5fcXz9AZr7hbeP9dVk709kbqD3JyQ87yZNasO1S9cTfaX6OMjqWjtcfU83hqWatPgkqfTW8tTLQQFhyZKTnTVGO33f1jLIRoNDAm a5PX13ImO2ZOpX2yZ0Dds/RRb6mCWwNjK0jGsY177SWr8p JHmWXzrC6TqbOLjFTZPmRteHj7vqgwTFzXdfWN6UJYaElYSl2uS0BefT/RMp3fa1m j/t oq5RjGI71tfr6VHi9cK kaV71vk0HbGsf8PofNyX486nyaneOdvPhuTxuQ1taQXJw2Vavczqk7ydgz2O3Cmyl7VcizwhJZPXJMkLl2gf OD/6q0epvWtkDyGQAgQkTdcqiWih8XxRQu fEvlcMtlNEryQidWMtUkjUGMAZtBvPiAyyaUhSrFvRCG2TmbJaSJm1 jc3lteQN09QYG3g9N75vBRU08C4b1yxb2IWdGnDiRstfdHXqqHqoOlgkGYnvexxYHPDfZuTr6/LDNZNmBkZ5bogmA 4iaWLthCc8EZvRrHgHxJ2RfX24z14nOq3N2Mnb2qOvW55lM5ac0mTEyYvRGPYkAURst3Qa 4dry49SdN7Z4/aDPZWOsZdmYNb6FdubiZzDBMtZnEFPCm/tYFq4pepItaf1J1/Q22T/ derXoN9R7yx9WD9bm9Q5HEbtxuIyNdF9KphG1h38jSPet8im6Ilx232fW0GJoq 0trh984JFdVyid5mpyF8YakD8mfy74ls3GMTqSTPJUdxFI ecQz9TJ5aQRv dF/DIP/x7/zeEfo175O8UcdkclD8saJHn/RghO8skhe2ElyzAat0gaO jLtRJFxB6n6JXMSTJm4lO44YDnip9pQk64eyOzE5U1yTFdvMGdtqEmsG7oNmbO6B0uxikjQJI/6rF4I3T2MBGTg6xMQ1q6X WV6BnJQH2sbv8YnIY5l5qTM2uZ1lUwf21bGjcU30zdQT044md4ZmPkYZ2Gp/cQSWY4Bx49jnOUzeJ7Iv5Jj/FLtG90zZGb1p8UF2 fyuT7ePuJCpJ3bzPDiNhp/tvYzWYif9rEAI9IljQSx mX5i8WgsG80/ IF2p7ABHHjsd4CW8vCrJAcIs2BHeWTPE6EfDLmZfLCTB2vpvaDTJ4q39iLFyHBQ7yI4C35z0fCrf/piEyil1Ar8kQMybv//vvhrkfXwfj4OExOTsKhQ4dsazXq5H379qkCu3btgq1bt8KKFStsobwdVKTZD lA25DAIdHj34kXXheSxwfpdtjXk4W9o0sbMDMmQb306MicNwibSVTL5ROcJgb6vKtL/qi3fFJkE6EhDnQ3bycamuAo 0NZXTtQchnZfZYgIGoCN1lMNnmmTv6evaYOm9iVrko/sjnAnXSnLwVnbXsT25ROaoGOCd/Qfenpx/SmfuJ9G2KciqXpZy43iV/Yj9xniHyZpXb6yiXyH8S6ZyEspDe20/w7tz85LtSf2culymbTvxRn9maA4WXtZeeovHteVmOuzjOfRIy9 LO H JU1jHHIJl5yn4sIRlPVDa0yfcNbI9hrewLdAhjqOUYlIVlfTlTSfKQY9Abt9gnNquHS7d2KZaYSEjyAPhXqLi3bnX5rExeGsGjcYMI3g3/4TC4 k/ bSrRI20a3caQvDvuvhd 8a8bZw7Ja/YXL6gjZFs/UCuNUcYd5HTpjAO8nfSaHazTJvGmZA7DEkscprbfS8WlKAYV840sn5wWbAIMh5cW D7FoE6WPXHnM94ubklbzOdniG/EYcnsazV BeW3luQ1So3i62WRPPqi46zvwSOCd9m/ zfTTvIuufl2eG7ri kk7 HNvwP8W/XMi/DQxi3wz uegcFfjkD/TbcXQqsVmTz57drqBfRMH5DK0T/IzBQcDMO2ceLHu9HSCCPqsXqJ90XHYZstO57SLN5MjItyfKbx/ps 8j 1WbyZ6BszW d2J3kYc1kEj Ixi Dh9WY/MZm8e1bcD6Ojo kkjxTBNVxcy8U1XSw8NDREl3K3rSB5BKBsZ/YgIP0n/Sc ID4gPtCePoAkr13 WuGjucSpwMUYkod8TUheg1mXVnS yGzPQU/6VfpVfEB8QHxAfAB9oNmPkDwhbanPAcgAIwOM ID4gPiA ID4wPT6gJC8ZhGQ oKAICAICAKCgCAgCLQhAm2VyWvD/hGTBAFBQBAQBASBtkWgXZ7Hq oLJG1N8hY/BfDHF6X/fFn4HXlYDsvLRxAQBAQBQUAQEASmBoGqkqNY66tqR1uTvKIEjwgfluef2icBivzxOrSf oWLdDF1i1 8mPI7evRjyt4XjuIPL8d8MmRniVjXr76aw/uyRzyX LLILAFyXhAQBAQBQUAQ0Ajw bDW589eVSVHsX1XVTvamuQRecva4i9gDG/zfwWDd2wRgodlEh9OiOr CDLVziBiKfVVwASBQlJStykyUsvRSUPyPFLHbaJyshUEBAFBQBAQBPIQoLljdAAGzO/H8gRCVclRnklp16pqR0eTvKXrdVeN7XdLurzzGiZ5XIgiWCbzppy9H/p7a6DvZvTv6qmfvOnrz8nkBRk ChpsB/dZlk8Hj/m9vj689nn4 78xP7eDmTheN VHlpXqSmY/DAz2uJ998eql/TQMJ6n 7wUiKbU/H8OxkX1BQBAQBKqGgBqzgzGLj OZ vIxkBfKOs/L PvqN1bZuM7Hz0bHU/93W/32WnqEcwcmJQzJC9uqKjkK9ax3XFU7OpbkfesB12XHXNsakkcpahugijw5wuYFXXDNapeSheOZvJF1LvWt5KkMnyGPlO3zZOCAY0hn1sCldMEyrCyeM8u1rh3U0g1gbvAZgX4krUwXfudmbZMdQUAQEASqhoAaF/HGmD0WkzVWct29cZZfiNwP5Rh9 A28nVMiRHvzTUS9MorSXEhzCJdZVXLEdSyyX1U7Oobk4dIsLdt cpHrstPvdufxOv Ukskz2TIVlJY8YSuaiLlgdWSJ64B3Pz3sjk5n7djgg4WVXJOtY8TKyg4GDQw4NWBgPSKCvFGu57p nYXDc4bk2YBlemFblvypOiMw0DcAOzlR5G3IviAgCAgCVUSAxstBNj6qc2zczRhz1ficeHaZxna wqLH69SbXz7 BvioMVaNu5QsQNlm7OekNKEf6PHZG8OZPUE7LTnETN6gns 43VUlR7EYVNWOGJJ3//0V/1mzsFOI1CGR2zMBgBm7D1yq97EsLtdSGdpyGeWQPLO0iWTKC94YkkcBzbXDfZOxS2TYAtk0aI2a qhH3whYsheKTejZAwM44LEBwhJIXhfb6R2AkcF GBhFu029NCLJ68m ICAICAJVQcCOlziOmrGXkzx7HRVmY613nhvjkzy6sc7LrPEbaU6IvPZ426jJYI8ZozXx0/W0frhP10ew3HSMybRca YfQqiq5Ij0K7qtqh0xJO/222 HF198sbq/XRt2BhG3Ta/pK0j0Nr6q9/EcXedbLqNhkuc5MQs4jzy5oNuJjaprKWQuc DASi6AaV8HLxt4sFhCxk4Y6OuBHn7nxw0P9LTZRE4mbV1mn1m67ek1d4iY0etlz/XxNmRfEBAEBIEqIsDHS9xHQqTOuXGNbnhRfUWebJmUMdw 0hKMyzjOmjE1EwbVLmbqSC6XQeTR1CYdaRsIVXqqrN/UZvA4PvTiBU8SVJUcBfDVPayqHTEk75577oENGzbMPJKHS7VE9LCn8EULvnxbOsnDJ9X6KIXOHuANyRNl4jDwYl68YO7mApdn2/hAgIU1EeMDig08JsvuJvQ09rABKdU spvKqcGGBicrfcp2uI7 3fCUqSANVRQB8Y2KdkwV1ArGLfSVfrXMOA0kz CBOmhixMf2BkieWmmZ6kye1tm IEjzg7GtquQo1hWrakcMyXvwwQdhZGRk5pE8JHGc6PEXLTjBw33 aTiTx4VUcl8HnRCfSnaOKCUICALTiUBA8uxNMq1eeNcZ6fLOcwOIjLGyeDkjk6dv3P1smyKa67ASl8H3 cqQvqnny7X2mWlFsHS9KR//abmWQwMAVSVHgZp1D6tqRwzJGxoagrVr185MkkdE7 Sl6cu0RPZ4T7YnyUtm9bjNsi8ICAKCQEcjkELWEsRLrXaY1Rr7fFvW2BpH8hB7nmnGDBhf3tTXaIXEtBkuwyobjH4mc6ZsoCxaymrNdPV5VclRLB5VtaOtSV6zv3gR28lSXhAQBAQBQUAQEASKI1BVclTcAl2yqna0NcmT366NdVMpLwgIAoKAICAITB0CVSVHsQhU1Y62JnmxnSTlBQFBQBAQBAQBQWDqEEBy1C5/U4da8ZZKI3ldc46H T96EvYcOgSTb78CP7/tXPj6cR G9x92WCFtUBH5CAKCgCAgCAgCgoAgIAiUg0BpJO Yri7o6uqCL/7DfDjxQ11w5DGfhuM/dzz8xUdnF9JUSF4hmKSQICAICAKCgCAgCAgChRAojeQdGL4QZiuiNxcWbfi9egV3dHQU8JXcIp8ySN7ExATIn2AgPiA ID4gPiA ID7QDj5QhD/llSmN5MGr98JcRfKuhJHJSSF5QjiFcIsPiA ID4gPiA/k kC7PI HdrSCVOYRuCLX2prk3ToyCf/ ovzvxaPvx8NyWL4VnSQy5Y5SfEB8QHxAfEB8IOkDSI7a4SMkr04vtmK5tijB40SPB HGWg2K/PE6tD 8wP2sWffS7QXI4zAsrHXDkq1BEGxdAt3qiy6dvFptIQxH3R1myM6SsXohJNrAcz1LYHtWnYLnty/thtqC4QJ4BDgUlE/4y1bwEx8QHxAfqIYP8PkwHP F5OX3UR3qVPdyW2fyiLxlbfGnzoa3AfBfweCDQhGCh2V4HbXPCZEiaSnkLUFaMohYSn0VMDFEKUVGQmeuj5C8ZJ9yfGRf8BEfEB8QHyjmAzQfbl0CS1ZPAM5fC1c7YiMkz2GRNi/XZXF1CnQ0yVtqssRj 92SLge5YZLHg18RLJN5U86 EBb21Ew2azsswX3M1C1YmJPJC0giBQ22owiZy/Lp4NFyFy7AjNzn4BsnmOuYieN1J0w5FnCWpIbZQl5P2URtMt288yzbaHXshoULpjaTl3UHqTKKlCFNI8x5xNizk/oSAxWJegou3B/UPuKO LD L1QvfzDgvjsRyrY2Bm3a89myPaw8v CyWH TvdxnrN2EDxvoVy EYtnubB1924uVE98wfWF9gPcn9 tsPNvSN0x8ez6pzqX4OPm62mbcqKtxgY2TXp10bH1ca158oN96uhWQh/GhZJawGhMdazgOoI8ZkhfWF5KX7gOEUx0OV/dyx5K8bz3gsDnm2taQPJpEbEAqsuOC3Qu64Bp1MAZGd7CMq SagXl4tVv6VPLUeTNY0 DtycCByAxWWQOX0iUY0PCcGSD4IOPa9Ac4/zxN6IFeBQcni0VsedI5vINM4EH6UbDRZOf6ytOB5Ab68H7x jYoh9c4Gbf geUU9hntBnI8nYJrDn 0SZNPbCfrfKaswEeUjcYPuCzuEyhLXUPiyiYVdc4e /4yvKB5mzNtCLBR5agPxTfUjYn4BsX hCIj hEZNgYGcZDqa964wuSl V/euVCOOqYxSo9N3piRJ4td8 OvCf2YzFQcUq6rcSMYD6iukLz8vnBMpbG9jiF5uDRLy7afXOTAOv1udx6vk PhtpRMnsmoqKBUEzgNHGGw pOe1cMEuMr22WwPyTDOoeTyu/JAdjBoYMApkoH1iAjywPT0ZG3QBG3bYxNzlp6BLE4MrI287TL3yb7EHSTHmu9rW1HH7qVL0jOrRGBScOO28X3fzmFYSDhy32B2e4TJw5X1Oz9v5WUPFp7MrLbYeV9nJhcxVe0FPmbPa6JqSQPTzddB17fLNmhPCqaZehTRNa M IYd6/x cX2ddT6zT6wPzHDfULHVDUuWsvFRnWPxh7bSeKz8VtuszjGf11jRGGN8Xq2w6PHa j/3VSWbtcWuqXFFtUtjL8qm7Dirk9DPz Rh3yaeu2btZPZxM2VwHF6qnzHndgvJczGXhrtjK43tdQTJQyK3ZwIAM3YfuFTvI1y4XEvEj7Yc5HJInn4GQZEpL3iDgTArpU8DTvhChgo2M7CYQcURi0B2KAP1WDCceDbC2h4OaNgW1gkGLzvg4Pm0OlSPMoc5BMm23cwgklJXD2Z Rkm3RYMjGxixPtqh7KSBOQxAg7kdWGmw1eUIk8w7bYO91iHoJ6O/60dfB3fer1d/MvblOKyzzoc2u2PXltbBDtaebzMsmM8o/e0xts2XnfA46IuU/nS6O50aPSe gRhm UDW Wzc28Y37HiJPm7im49v9jpiwWLRO89xIix1Wbqx9uOBlzdzhhljbIypeGDt8bZpbLVjl5/5QxnU3vB0vfxGN9veGDihftKsMfpSrVpIVhsdi/LqNWtleSTPaHIIf9asIt TR8Rt02taOSR6G1/V 3iOrvMtB7thkuc5MQY4y5yxiYyCTr2xqiZJnzAoXTIHDjfA6EGADyB8IKDlBy57OyxZ0A3dTBduNy3vucGFyw4enEW92cBC5MbZxuw3gxINcn6b/iBX6rXwDlJhTYQi1I9wooG5jl5Wlo 5s9 vj cJI2 CYIRG1cXsgOp7ukunLepdUDc2Kbi JH20vsnzdD25tXqlybU4uHpJDIwfqclrISz0ni3Ca4S9k1GqHzCMrVzxDe8heI1Lh/sGH3Nx38aiGTPsmKf91MYFr f5GsWrxtXGfyDH iSva8cAig0ug SaeFFlF8IwbbkcIoEm9uK naG5eOT40IsXFoMJIXmp/c76TkgeQyAEi8gbLtUS0cPi KIFX76lcrjlMhomeRP nZh16MREqAM2 sUL5gAqgFTgmuUFRbj4QIABioOBn82ygcdkcdsTBMNmYJg8apeyjHZACpYClN14bupfvFA2BXeQoe0qo2MHciJTtKXBNWOgUzZjmbQBN1kX27b ENyJE/42I5IxWGdnX0IdA51sX2edD u7Y6uTlRH4WMqEpXD2/MbJI4LrSCbKS JFmLRsK77hjXnFfcv1Zdv5ho1pbSPat1AtM04DyTPx5jDmcRfEMY0XtLWxqu2geJz6TJ7W2S5vB2OCLNe6WEob5xjFaWi3IzJ5SN440eMvWnCCVybJS us6pzTQecm2Hwnq47ecXpaMmcmcjtQemSbD5pcfjCA2gETyzsyQgPn9pCweW0wuXhePcOD51LaVvVIPurgljSz2kK7nExqC tStpLO4TbrPC/j76tJLnwDmzIDxhaLrcXJLQ/Rdyva/sAyCXzi9WrGL60u4huM5MX3QTv6RvJlN8SF3bh6JJDFsHeexxDWx5hmZSkGAsKDPq18M4hdhzOXwfd5vGl99fjuyoTjx5SP/3RDxcYItFdIHveV5H5DzI5V6hiSR0SPfydeSPA6g SZAStlcGlm0qxmXT3Apd1B6oHUZOss6eIBRgOzPucGWVr Tsv0GWzDDKc3qGEZIl Bfmn11MRBbVE91Im3xc87fa3dSq4mi2hH2nnsP89G0lmRsaCO9R2mvz3nMHSTCp1j5YM3xhXpS 0Hqlv2luuSkuU2mCXJM ohvqHivV19I4WsJYgXt936rYnJRCyQv2ifs5l8lJEoq/08jFNbx64S TeCOqbZOMDHDdOGF49Kf1ae4n0atkLy8sc2xtca2m1rktfsL15Uk7jkO4TonIJPxh3kdGGFg 2U30UXGbynEacp/woVwmMabU7zP/GNZPxOm2 Qj8iWZXuT/ZPmxzHnhOTlY9oQs2OV2prkyW/X5jtPTCBK2TKxxDv7atxF837dvnRJ5M/llYQJZhVsNqQkmTN2Yhbf4D459RneTve/qbdfSF4 5oyvNbTb1iTPGyxm7KCf7wBio AjPiA ID4gPjBTfQBJXrv8taIPGmJ2rJKQPCF/LU3Ft8LpRaZMaOID4gPiA IDneADjK81tCskT0iekDzxAfEB8QHxAfEB8YEK kBDzI5VaiuSx ySXUFAEBAEBAFBQBAQBDoaASF5Hd39YrwgIAgIAoLAdCOwc dOuOmmm C8886TP8FA QD6A/pFsx8hec0iKPUFAUFAEBAEBIEmEMAJ/ZFHHoE9e/bIn2CgfAD9Af2i2U9pJO/1g1qV6fzt2mbBkPqCgCAgCAgCgsBUI4AZPCF4QnBDH0C/aPZTGsmbfdJV8OQ7ACHJW3zhiYV0REXkIwgIAoKAICAIdBoCQvKE4IUED48rRfK6urpg9g/WwP5Dh2BychLGx8dh9OFPBhhxWKVyF5hWCSQoKAICAICAJthoCQPCF5lSd5N36iC7q6vgjLthHJewOWn3M0HCYkr82GIzFHEBAEBAFBoEwEhOQJyas8yfv1zX8FmM2be 8uk8kbhvNmzYLDDvvbQrEgmbxCMEkhQUAQEAQEgTZDQEiekLzKk7yxh85VJK/rkic0yfvtMjgFSd5/ 26hgYKggAAAIABJREFUcBSSVwgmKSQICAKCgCDQZggUJnm/vQ1OrNXgwoeJFL0At51cg9rJt8ELUW lroILazU48Scv1HnhYxVcGCl71fk1qNX8P6cv6W22D18ItdqJcNtvg/NRtuyBF35yItRqF8IqU08f16B2/ipjXxF7C9iawL85vdOIHT HftHsB7kVPj63b98 xc3wvYmsz9DQEKxdu1aVx8fueNkaPHWVJnmn3wOv4DN5q/thFpK8z34/S553vnySNwL9gaNpx uBgVGv6eTB6AD01PphJHllRpzZOdgDtd4BaOgbdkqxfScM9NagZ7AhDTTGpegxBd21rh9qpfsK q7xU5Rv nKkr0lMORwcX74Puu9UrPTNgAhg HDzytln/QAApeJfjoKlSsm2T/tE/7pSm0sRpsfs1reT0vQ0n6oqyVOErRGSx po0ucIGCcxpe0rskjk1xBfnP9JD 96OjErZKuQvC7oqhjJa2jA8Ca9aY7 BppviuQ10F6ySgkkLym0mmfageR5yOJEO4NucITkeb3XzEE2yWtGakxdIXl1SU CZPiZPJ3BOhEuPB8zW5hNY1kyU1edP/9CP5NnSBCvY7NhSo4mad45myXzSVOCLNlsHel6ospGKgJmr2kZmhCaLCCTX7ddY5vKTBJG57ssoa5viGYjthJZpHZOJnz9bCjX32VJdRZRY uXr9ffksnLHT/qDBiGyPX3ubSyJoS6nu4QM9mpslSOTYBqgumBHgyCIHMWDphIvGxmK1eey8ApsqayKYY09faowE0lropsoI490N/HM3ksM1OrAa LOpLj1Shrwwlumn22nXSblbzefujPyORpXAZcltVrtwd6elGnfhjhemA/c8w41ln68PKUFUvxF4WxGsQ0dpTlVXr29eu DfuXye7vS8vkBZkPpaPzG883UvXH qY8Xq TySuqq8s4Bj5usebne Cic/zMoefDhKWtSydQhm8r Zjv/64MMBtJCpiMovXXLAxN3QHry0yuyb5ltZ Mfdc6ta/r6qxqpu9iNeYTDufAD4w 1ibenLLPxaMto wLxhhelscClwcAWb6Nxfg16pds wI70tpP9QO3aoKyE/2g9NWy1bW fjUuWNsDe9r5sKxMHpEhIhiOcBHBMsu6hujocpqE6CVVU84QLFd/D xRdSgjl7386dXZswc08cF6RjZbVtUyNRHVuhtSSkQNl6ULtcv0VuVPhNsedkvbTqcYWykzyGw1etEysLPNLBkHZBAx5XZ5ZLPAknS1SN66fr1c 91fwO9xufZX/XB0BZZrMwcMMyjzAY4mUz1g02ShJz6SowYrGljVYOcGMm8QUoMzETYcyKiclpfarlfHDMSM5Fki5jXkJhitoxk0GTGw9bi XltMPz5Y8/LYprpGdph2DEnTk4bBLMCWq6sHe5LBsDV1COdkH1AdtmyWqY/WzcpCO4hMcmWUfdTPWi6V03r69mh5Kf3HSA2J54RI7ff2m8cEQqzJLh9PksMJEOpEfmOvWyJTUFfyXYUdr0M4oH1Gpywf4Y2nkbEcn1AY8rZRlteOE14IQ9WHdPPiY6h80rPXlDO Rlh6Me2aR2QdFgVwJn/j8pQO1vdQHuHMGvL82MQ96a3sIx/Jj0EmUWPK2lI6kR4e3s5GVYbqGIy0TSyePF053qwMKsLayOwHwtSzlfrSs6btD8oleS575wgGIyqKXITHRMYMGU8heZrQOLKuiDnLtlFWKq2cRyCJCKEeRMh a9rn1wwJSpNHJIvaxK0qd/JtcBs E6jkEPG7TT 3yHT1ZKbYmknGOPncQwSOE1gfH0WilY3ufObziSmkr1Ik76W75iqS91c3bdIvXmy7C05Tb9d tVCATtkzeTSgeIOVPyh5BEMNsmxgVvXMcXjNs5QN6FjHazeUlzapJkkeTUpeM3jABlR1zR6jDnzQZAOxLRNIy7HPG6yDdnGC4PqFx9SKN9lQRgEnn7A/Qj0IPxJEdfl5axOzk5Wvt8snZF9PJo/rhQLDY2rE6oLksR9G1vVrfLC80TkPTxLD 7YYpvV0Nb7G9eb7HrHJ8GGrnN5BO6jvUUdOdug8lrSYeu2l C/JL4ChwoeICfmEIjMah7B9dazaZ8SJtUNN660jQJ7 6iLDGeszHTyfwLbIR7EcES2/If I6xPILuQzvjStLT6na9qO9iNG5PPat/1r lpjn9MPTK5WmWGaYkM7n2qa5Bmi4kidXv50xyGpY8dedoqIkX5hgYgTvtShiRFl8vwl2jSylXwRxMjmRK4wyavfrrZVkykvk2lWahS5KmhrwySP2 aRNmM718W7no5npUjeA/ A35M3G658kr4n7zdw/d/gV6j8l0Kx2SqSRxNOQom8iYZfU4OsY F8 YZPwAn5ZqDD9vkkGE5KXraAD 4pE1aWLdkDryZ5tExCW5r4VD3jdHTOm6DS9DHlSZae3PIGch ZcIJROliSF5JffZywz4jk vv6YAFuO5PrqaP1dnVrGRMhm3yCSdfDy5NNBGkE nGSR59CO7G mWzz9TfCWB E2FFz/vkcXTmB4z7O93mZLB mhmmL9RWRIZvxQtInMvua2Ugi9ZbkZWMYxqBtw7Tv9S36bpqv5bbvyGA zhljhNJDy8D6WTGM1zxdOTGkfRoTUmPQR47w92Qqv0v2C9XMtI RsVyftThivxFuuj1PD oHE6MOE a7pFSHbAuTvD2anLlMFiNrNrPknvtyJC0gWCa7xDNNOsPky3f1KetmljCDjFYZJM8RUiQ8zC6jKydpqdkwInD87WObRTPZTS4rwDLTVlpmRiId2M3JoKe/aocvQxuSGtTnuKXtV4rkHd/VBV2fuBE2sV 8eHbJ16fxy5BxoMkeVBOTsx2gguwMPx8OOHnXsCxe7xtgS7WBbCyjJlgzIAby1MDPBmY3GAaKBPXcxMcH26COd8gGVz7hB3LdBOpVVgf BMGWVIOiziZ9wR7zdvESPw70IJF5 lAZtc2rH06ghoD59mTgE rpNYoY9MDAOkPucELrHQB8doz6sZD THdfJ9eYf76ersbXOL58PyB5qT7smjZ72GYPDAw6AosXfL2yM3kKB9YPXHw9DJ2v61oOU4YDF4j7nr05mcQAC98eJp/1UdgUHqNOPYP4HGrGzQbW59e4PL5PJM/4aFpbdC7E1OGS7Beqk2lfSPIy2zfjDfq87U GEzVkt G18NgWbPud4iRvjyUaljiz7BERjbgXL3iW6UQ4kX0li5aHNyCapOhsnrkhYcufnKB4ZMnLVgVEE68xMoQysuRnneftEjEkXdU1In4Wo K2Ottp ddhTyRTl6EsI5ftiPYeIol0c5aBm2 LzuxViuR1dR0PVz11IPjt2nXw/RPeXyhAK5vJC 421WBJA3IwACcN1UTTPuunCuhzlDnDgdVeV4M93QGbukVInqejHihJppJPg7Ka3DTJ4IO vutPmfxD 1R90s9M2jSYK93NJGbaIRs5Lkofwo/rHU68/DitXbQp7bzSx0w29FU5qBthwJTxJ0KOdzgR8slH75Ntvj1MOE3uvXwpE18sYRN9pv5MDusDbIvaZSUCMsV1zfG1BL6kV4Cd6SPyJ94u39dx4QgsXvNiRbVnrvN9yriRH3GhRTBk Ng2TV n9a/Cj9uOlQIZTgUfCx//JM4eebc TqTSZYmdfLOH7dvyWq7FO9RN6Z4Rg0xwmu0UA2nXUPds 5itddrX8eD7aVp75MfeNYWD70PMpLbejSJ5HnHyl/mI5DX7vXNphEPO VhPBR6VInk3rhtTQYhfnmd/u3Z0FIaW31ooOFtF8uzdDrFoyu7lDvRmwqeBV5Wl5RQ3wGZPDs5kf A05z15NLnqazRI4qA/YJ jYYOsE 3vmQES7e0fTN5JEw40uIbLOfY8xyWcYLBF1o6bmNJ1tzKZpgoP9taqLcPbxfLhMW XEwJ nvqrjp5OHepn7Fv93BxNrn6/Bfiz/svN0Khyzl/UhBaSzSz9SUm8buz1daICeZMz4Ui y32NbA/fZPaJDbaS1a7TgNrh8vVVrJv0PSKAeM1kAHmfcsH1MGT4YLUQY94 kZxU30pt3xAus/To45DtE8omusFQtgRluX3susbJZH/JlwP7VPF6PqMKUf8mfRsvc1woBrPtC/TPa19dcz6vVAnas/2gLhLG maXZ7qpbidsheRNPYGaCpLWbBuVInkUiAmSNzREl3K35ZO83Oam6GJywpyihivbjD RVFZNUcwiUMyHQ3Jlq8tO8oZFMBEEAgTKInnNkgqpXy2yKSQvCJRKHZpsD90lV0q3aVRGSN40gh/bdEEf1lmhZBYvtrm2LG yXrSU25Y2ilFNIyAkr1rkqipkV0he06ElAgQBQUAQEAQEgelFQEiekLw0Yikkb3rjUloXBAQBQUAQEASaRuCmm26CRx55BNImejnXmQQQ/QH9otkPPgo3Pj4O /btU 9L4CN1WZ hoSFYu3atKo/vVvCyNaokz QRErIVBAQBQUAQEATqI7Bz5041oWPmRv4EA/QBJHjoF81 hOQ1i6DUFwQEAUFAEBAEBAFBoIIICMmrYKeISoKAICAICAKCgCAgCDSLgJC8ZhGU oKAICAICAKCgCAgCFQQASF5FewUUUkQEAQEAUFAEBAEBIFmERCS1yyCUl8QEAQEAUFAEBAEBIEKIiAkr4KdIioJAoKAICAICAKCgCDQLAJC8ppFUOoLAoKAICAICAKCgCBQQQSE5FWwU0QlQUAQEAQEAUFAEBAEmkVASF6zCEp9QUAQEAQEAUFAEBAEKoiAkLwKdoqoJAgIAoKAICAICAKCQLMICMlrFkGpLwgIAoKAICAICAKCQAURKI3k3fbY68o8 e3aCvayqCQICAKCgCAgCAgCHYdAaSSvq2s2dF/zJOw/dAgmJydhfHwcRkdfhGv/v78oBCoqIh9BQBAQBAQBQUAQEAQEgXIQKI3kXXVcF3R1/RVc eR R/Ie7ocPH3ZYIU2F5BWCSQoJAoKAICAICAKCgCBQCIHSSN7Yg/Ohq6sLun6wGt5Wmbw3YPk5R8NhQvIKdYQUEgQEAUFAEBAEBAFBoEwESiN58PK9MBdJ3idugKcVyfsNXP 5WXDYYZ8upK9k8grBJIUEAUFAEBAEBAFBQBAohEB5JO9VQ/K6roQRRfKGYcEsIXmFekEKCQKCgCAgCAgCgoAgUDICLSR5I7Dg6OIkb8eOHfDeeVbJ6IEwQEAUFAEBAEBAFBoPMQQE718ssvqxdh9 3bp96XwG9AyfoMDQ3B2rVrVXl8gZaXrcFTV8FsXK49 5/hFZXJG4XBs5DkvT9Lnnf rbfegjfffFOInoeKHAgCgoAgIAgIAoKAIBCHABI85FRvvPGGJXkHDx70iFsoMZfkrfrubPXixfwH9ti3a59d8vXCL14gY0SFMKOH6UX5EwzEB8QHxAfEB8QHxAfEB J9ADN4SPDGxsZg7969MDExAU2RPPVm7XE3wibve/LWwfdPKJbJQ0aJzPPAgQPwzjvvKKXwu/bkTzAQHxAfEB8QHxAfEB8QH4j3ASR4yKmQW9V7JC43k9d9/r3wwjugUoHuy5BHYWj5rWFGMPMYs3nINFEZZJ24hix/goH4gPiA ID4gPiA ID4QLwPIJdCTlUvi4fELJfkEXNDouaRvKEhulRoi/WRbaJC9Ify5E8wEB8QHxAfEB8QHxAfEB o7wPEn3CLnAq5Vb3PlJA8UgIVkj/BQHxAfEB8QHxAfEB8QHygcR8gXlVvO6Ukr54ycl0QEAQEAUFAEBAEBAFBoBwEhOSVg6NIEQQEAUFAEBAEBAFBoFIICMmrVHeIMoKAICAICAKCgCAgCJSDgJC8cnAUKYKAICAICAKCgCAgCFQKASF5leoOUUYQEAQEAUFAEBAEBIFyEBCSVw6OIkUQEAQEAUFAEBAEBIFKIdBykrdr1y7YsmULPP/88/InGIgPlOQDGFMYW/gVBDEfiUcZhzpxLJZ4Eb9vB79vxI9bSvJwQtm5c2fdn92ImaSkrCAgCOifC8TYovgqQvYkHsVzOhUB/OJYiZdO7f32sbsRP24pyUPWiUrJRxAQBMpHAGMLY6zoz9tIPJbfByJx5iAg8TJz ko0zUYg1o9bSvIwPSofQUAQaB0CGGNFf6ha4rF1/SCSZwYCEi8zo59Ey3wEYvxYSF4 lnJVEKg0Ahjse/fuBfzBavw9w7xlWyF5le5KUW4KEJB4mQKQpYmWIxDjx0LyWt4d0oAg0DoEMNjHx8dh3759QvJaB7NIbhMEJF7apCM73IwYPxaS1 HOIubPbAR4sE9OTkomb2Z3p2jfYgQkXloMsIifEgRi/FhI3pR0iTQiCLQGgZhgx7LyEQQ6GQGJl07u/faxPcaPc0nemtc1KPicD2YJRlf/GPr7 uGHPxkqhJZMKoVgkkKCQMMIxAS7xGPDMEvFNkFA4qVNOrLDzYjx41yS1zX7TLj3ZVBLQEjytt3xJZg1axZ8 uWwjiYpPKczC8fDks9/6G4bkiLTw/DENPvlGkpCmT1tZyGJYERwSGUrRKCMQEe7F4ROvegCeGeEwOwRPmhg9efwKGlpcQM7mxG8Ypa78e Fzu88OwfHlE3Xqy5fqMR6D8eNG yueh5x7F2KkzhxWOIxaLQ09A9mxnyj2anDmVPml1C rwxpNDEkcV8/wYP84leX/V1QWz 9bAfpPJI5J32GH/ZyGTi00qGUGS5pReq8l63uXUg2Qd7cB1AjJVlpwUBKYfgZhgLxaPZrJg8ecN8gUnhnxkknHoyutry9lk5bXvCqbs5clNKS6nOg6B8uMl6XOlkrzC8dYAySvY 8Xjr6BAKdY0AjF nEvybvxEF3R94kbYFJK8r19bSMlik0oySEDdgbtsgQ4ak1lQkw 7u8EMoJkQeDl Z WUzWqL7vbT5drsxaOYGdB6OPm8zjAM412cnSB1e7oOteG0kT1BoFkEYoK9UDzWy36ZSQcHjvxYcHFJk8SQyg4 AD9/gGUJGZlDLKiszRwqgPgEZmLq0WG3AqBk8Dg0bQe2aNnUtrux05mOYRi22Ut3LatOs/0m9acHgdLjBZJzSkjyPB8if fkjeY7Nr/o1SU fyyHoSe36Aw7zS9UT61E8RjxsdX nZIF5DrQPtOB5jgek2SL1i8l5vym5ahFCMT4cS7Ju OrXdDVdRU8MdUkjyYSXIpVjmwGXXJE5dR cCnnI f3ynGU/Tp4hQekJ4NPEEaeTya1TjwAwAS8Jnk6APxAcZMH10r2BYFGEYgJ9iIkT/tzjp/WiwWKQRY/Wqa7aaM4odjgtmdNSO48TXz1xwQ9dpibq7QJ0eiqxwBTztindTNtqYk5OXZwvWV/ZiBQdryQL9MNj9sa/ TzFyeEfI4yvknzixeDvBw9RuHFGMVVOSSPdEjMi/jYw5M6yWHjlseU2pdExlRFQYwf55K8rq5pyuR5Ay3CRgO7vgvndzna4YI7ikS2jaD35aRm2Ezb3jUv0CjboIPYTT66DXvsyaHsgQQB9YRsy0EgJtjLJHn0HKs3IaFJnt9rf9dluO9nEyYbPwE87ryJYcqI0NiQRsTYxOPqG8GZ17huwbhCk2ugmxzOHATKjheamyzxCRIHyu 8581NlpnPKZwsIZT8mJebApKXFtd0k6bnRHYD6MU6ZhqznxicOR4yMzSN8eNckjc2NgZjYwcSL14c1urlWubY5GDK dh5P7jMYFx3EOYDuJ/Fw67VAWkmIzYJ0MSVFgDh5GGPja7i DMjaGaqljHBXoTkedmvNFC8GEy54aEXHVj8xJC8ZFlUgmcpppLkGQDMpKsmubpjTBpocq4qCJQeLzw7Z4zU8whLAqS9hMHjiJM6lMGPeTmKA/JBXo6u2Zsfh7idk9wpvcdl83372IS2gebg5UND6qWrcE7T9upERngtbFKOy0Egxo9zSR6pQ1 hYl 8aDHJ407JA8Zz/iC4vMlBOT/PHJAlPskjosiXV l5Ok9e3QCgtswEpILQJ57cJtJGtoJAswjEBHshkkeTBU0kdsA3Pp4ZC76/8/jh 9reMA45CjyG9Hm/vrlOE6enTyCXjwNpE6Kx0Y9NLoPvm5tAhgvXWvZnBgLlx4vvI4hC5pzFfZXvG9 kpVLt7yZjxssFsnW5cpdr0xIZPP483Xh8BfPxzPCGmatljB9XhuTpVDAta2akhL07CTOp2Bcv2PHyrNRxMiCJOKo7EAo2lGnaSmYQ/eyFzTKolHzw4oUJUG/pd b6lWheQQRigr0YyUMj/VjyvoYkmHSSg76JYRY/fJLQEDL5KZkHe/Nll7noJgpr6xhennjxItAb5XqTEMVtcozJJnkuqyIxrHtupv8vP16Sc4pH8iwxM35H/s7jyMw7w ylByJb4SoSzVfoj1RelzUxRfJZR2l9yO ZHlwHvm9v7Hgmj2KQ4k9/VYsnW26AGOqt3Y3x41ySd8el58IX//sDsKulL160FoxWSw8nMH/CaHXrIr/TEYgJ9uIkr8qo pNMlTUV3aqHQCXjhUiefF9r9RymohrF HEuyeua/VE48 YnYY QvJyuNpNOatYhp5pcEgRKQCAm2IXklQC4iJjRCFQyXoTkzWifmg7lY/w4l QdMNrTM3nj4 MwOjoKWKnIpz0mlSKWShlBYHoQiAl2icfp6SNptToISLxUpy9Ek8YRiPHjXJJHKgjJIyRkKwhUC4GYYBeSV62 E22mHgGJl6nHXFosH4EYPxaSVz7 IlEQmDIEYoJdSN6UdYs0VFEEJF4q2jGiVhQCMX4sJC8KWiksCFQLgZhgF5JXrb4TbZIILH4K4I8vAqidW/8Py2H5mI/ESwxaUraqCMT4sZC8qvai6CUIFEAgJthjSN5IXw1qNfrrhxHSZV0/1HoHYCcdV2a7EwZ6a9AzGGo2Av21HhgYpW1lFBZFUhAoSvCIBGL5mE 58bIfBnp3Q8/g/kCFfdBf2wMDo7QNLjd6uG4carXd/l/v3iZisXH9dg7ugVrfvkYtyaw30ufsC3Hl12q1cTcmZUpr5oLu2/51zchoXd0YP64EyXvrrbdgy5Yt8Oyzz8L69eun7e 55/R3/0ynDjOhbXRd7LPp/nvv5Qvg4PMnT nfey dAN9sEfxte0LoIjJMcEezGSp8lSrc/SOgAkdjVD9CpL8kDrGRDQnYM9FSWlEZ3cQUWJvGVtj/wBwPA2gJOXukxfDDylxwsSr4BoKQIUnIvRMbOsInmc3GSRzEwJwYXGSZ4iXGWTPI7l6F7oUUQZVdZ2eqQygUVgWtOHQvIKQVhkUkGigOTq5ZdfhomJiWn9Q4KFH9xOty7UPpE Op7uLWGE/fbee 9N2x 2jwRvOj5/eHM5IMGsAtErfdIaHYAeInQM3J2jI7BzNCRShhCqjB9my3QFRawoC8hIl3eek0jejkfKWPbNkMsByjAyua46K69O8uyef41nKnX2j1/X9eguHssmM4SuVdkrD4Esckfnl ohGsb2V4TkQUiUOPHi13CfslSY5UPM HWfVCCJCjNZkEJsbEZNEaRx6O/dbTNs6ppp08kyhAnP942bjCPGNWYJiUAmdaEMoooJVVbbQjHCPSCtXa0ntmcwqEcQFckz vB91tDO0X16TAKA9CyfwXeQMqCUXdU6WEyUfOqbFAy869R3TJFp2I0Z96c9k/fCCy/Ajh07KkGqiMAIycsm24RRJ5M8jGlF9Eb7piG8/SZjgr3ITVfdzBfL5CmiRGTNZvsyyBKrB CTKG6R3z6TpeTXQE8qnLzx2jjYM0LmEVYnS7VBeoM77 qOQH9fP/SrMtm6 i3LURkIEJlL237rAdfCMddWheRpguETBiIKROJ80qQIlcn0OTK3D/qRdCnyE5Qnsz0ihid1OdW2usYIiFdWE0yMHUW2KMvI63jlWfv8PCNbmZk8Xl6R2N0qZjXx46SN6Ur2mS0RNsLU0zkoqw/3wYhdVmW6m/YpA6jlah2cTOojLUmdD/rA9ZHBrx5BTdWx3JMx4/60kzxcop3u7BS1TwRGSJ6QvCIhiUu30/2JCfYiJE8tzaZmyYyllqyF5McnS p5PibHy JRls8SLYdiLskL5aXU50vLeWTOPW onzvETJ0tv64fegZHYKAPnz1Eu9gziU5V2WsBApzc4dIsHX9ykWvs9Lvdebwe8yk9XrBxRmwcScALRCA0yaJsmN5qkmPLrxuHnsF9MNCHz9hheSKKzDrVDmWczNYjbK6OlWuqa6LydvAMIenn20Dk0ZLCFFKjCFPK fR29/vk0uLCbEvsBgSW7EyUcyc0idO46JtBjbveDwgaYokyvSwdYYs4MrJocc8mpk6LqdmL8eNpJ3lVI1TYRVXTqWr6IEadnslDDKZruZgPIzHBXojkedkv15LNchUgebqWJoFIpjwC5USqPZUNNKRPTyr8GTpHHEPyaQlZIA8UKcOMXz4JTV1 Rdt7B2BksF8tp4309cDAYD94zycm2pMTZSJApA6J3J4JAMzYfeBSvY/t4HItlaFtTPulx4tqnMgEIwb2PBIDRqZCZZFk9O6FkcFx43N7YACXF1MIFCeToZjwWjrZmkkkzyzBIg4sg8jtthk2Q9R05o/3AfWLruVh4pE8R46dfC6H1cfl5gKE08lpzV6MHwvJY88BIpnCT9VIVdX0QYyE5LUpyTNLqR6xUUulyRcvFEGjbJot42e PHKo3nJF79EELJVoWTnm T qo87Tc3859VG6eq6vRxE2966tI4zqus3O4XlaBtZlenqdrT29PfI8nhoVp YfEbdNr n2kOhtfFXv4zm6zrcxmsVMjoVuikzjikD07lGEzfkckTtNGCxxU5khIha6TE vOcaMHspJvLEbZtsCqz2ZYVlHdrSe5o1cVcdkpxRR4vt6mdUjj6xMVibPK2 WS21G0JIjwiXFBktunc6UWbT4YTVuLyeBhvDXi9rYAAAgAElEQVQVzuQZHQlvh48jeWgrZQNVu9aOQP8pPIzxYyF5QvKilsuJCLcHydsJY7fXYPdmANg1AG9e2w9vRwRqW2bylP0uC6eXNdlyJZItu2zKyxEBI3Jmvn7FljXkK2epVkOvSZdqF5 LC0heT29SbqLLVDaSPZunCjiSh4c8g8jJpjpPOis5zK5EQ3KibASIvOFSLRE9bANftODLt1QOtzGfmMkxhuTpbFP4sgQnM5q08KVa0lsRJiIOjEjRdbvlxMaeNDsp1xRhKfriBb3BqjJV gUOIjZpcugcleHq0DW0NUmesCTHhdc02buEzljGEGVzzb0kElzr3QsD9qUVThQzlmuxuiGGum IfDuSp/WlpdxqLNnG PEMJXlb4eobN8BaRtDoubpmtkRgojJnOzbDGTc Du/Hv6Wb4eUW6BSlD7W/cQO8v4UYNULynv3924B/ZbyVi 03T7KE5PlDbIWPeIavwmqKas0hwMkbJ3r8RQtepjIkrzmzpbYgEIVAm5M8JHhIqqpB8l5 dB1cvRFfVNB66f3sFxdiSSgSvGiSpwje43DGo1vh5R3l6YK6oy74iSV5SO5 tuUNIXlRoVy/cEywR2Um6jc9tSWE5E0t3tPUWkjgkOjx78QLr083ydPZH8ryyLZT8Fiy5N1pihDdbMy4n5vJ 8nAFvjd69vgf9y Dk4 91GYe/16GHl5FLBSkU RSSWWwKy9/3G4 lHMnjmSh0RLZdIoo8a2Zzz6SuHlSCIwsTpp4sZJ3itw91KT3WO6aB3Xwd0RxAt1idPHkOD7t/p2G KXilNYlrKBKVvCKIbk/X7fAVg7ukf9USZvdHwCfvG7N GdA5Mqs/fkq2OAf0WzfNGZPLUcW4PfX4t/tCwrmbwicSxlBIGpQmBm/eLFVKEi7QgCPgKlkbyes1bDp6/dBL/c9gbseGY99J6xEr5292 nleQpQqWWSEOSp48V4TPLpny/SAaNCEwcqZqACZs5I0JpSJ4iT3pfk02 XyzDhrpE6ROSOSJw6rwhmGrf4Mf3U0hdiBthFEPyiLghiSOSd2DyIKzZsQeQ7CHRe Sl3YBkkMrW20aTPBsjmti9OYyPRwvJs7DIjiBQAQTkt2sr0AmiQuURKJHkPQ4DOwEOHToEk5Nj8OAVK GEpRthaGhpIRBakcnLJHlpxA4JTMRzckRgokiVJUacwGXtTwBmImOzi1H6cNJmnhdUS8j8PN8PCHNI6sJjwqhZkockDgkfEr3te/apLRK/euSOrkeTvM39Jouns3lC8gqFsBQSBNoKgZjJscj81VbgiDEzBoEYP85dru05i5O8SXj4eiJ5txUCo0iQRBEYIlQBMeEZO76vMmwtJnkvP7rBLL9qYvf Otm7lpM8jk3FSR5m8HDJtpFn9eJIHsvYmewdJ3lqXy3n9sDYrkKurQo1/ JH8baySsYEe5F4zGpHzgsC7YCAxEs79KLYEOPHQvKIOLKXCmKIpyKV9rk7WkKexkzexAR4OnnLtSlLtJwUMizCDB4dl5nJw6wcLuHyZ/MoU1dvG0fyACaGe0wmrwd239cDv79vRI0Ub99Xg9/fPgATMAK7r62BJn/FBhEhecVwklKCQFUQiJkc5aaoKr0meoQIxPhxgyTvvrDN1OMiQRJDqIhotGpLBKZqOlVNH zsRpZr04gbLtnGvHBBMmJJXqqDNnlSSF6TAEp1QWCKEYiZHIvMX1OsvjQnCCgEYvy4QZI3fW/XtorgoVwhefVfBiGMmiV59OJFI1k8JHpC8vRoFxPsMmnJDFF1BOTFi6r3kOhXBQRixv1ckkfG6BcvJmF8fBxGR6f3K1SE5NUnYlOBUbMkjzJyjW6F5OnojAn2QiTP/FqE/qUL8 sS9me/aESo0DZDX/4rFgltVR32Kx6JAq06kfVzbP6vcYStZ/9Ob1hy5h/LV6jM/D4UC1qPQMy4P 0k79lnn/W/z63Ac2GtIjGUpara8mjV9EEXFpIH8N5L57Q muu0EBPsxUme/1Ne rdgB8D9JmcdpabyciM/PTadX6zs/SycBqoevp1E8tK 7Jifwy9HHt7mf0FyjLuVHi8xjUtZQaAkBGL8eNpJ3pYtW Dll1 uBNETklc/S0gYdTrJ 8Oby G90b6SQrZxMTHB3ijJgyDzpUhH Bu0hrwM9LHfllVkCo85aWS/TVsz2bSA Kjfj 3TL8Zk/casRSyP5Kn2KWOn2 0ZfBD6ue6q7X7ox9/EVW1y/ZzemmgNwAD9dm7fCDgcqI3s38S1 kKYtWPZPWWLy55SNtKSPM8eXc/ dqhXN10fbZ/TpIp7nNCl7S/VP7ijfsuWrsfYUXq8xDQuZQWBkhCI8eNpJ3lIFlDhHTt2TDvRIwJTtcxZ1fRBP 1kkqcI3o4L4A/ja0oK2cbFxAQ7lq37SSFNimT0mkyeR8gY0VAEpAaadBiipEgTIzHA9/EHw3ugpuRy4oNlNLmy5EYpzcswKzxy4wgSkR UgWSJtqomJ0tqn8gcswcLMluVLkRWTZuahGlbsb1C oImgkTgOIHeuW7EZUvDthFLrrfB0uFNNjA9lJ5E DLwY1BWYZeIW9r2Ww84Dflv2bqz9fdKj5f6TUoJQaB0BGL8eNpJHlqPhOGFF14AXLpFQjNdf88995zqjOlqf6a0S32G/Tadf9fAHgG65T YdLtJjBqwLBw36ICfbiJM RJf1sXkAgKBNG21wCwklNQDQYCcGMnSIseM4QSp7Fo2cELTlSkQqgSZLTj07zrZJDJBUvcLLE91WWLd12ReCsDG6HI4aF9A3a94kh2WN0MO3ZMp6url2NQag3kjtdRmGnCDdHpZr7nNzh0iwdf3KR0/f0u915vB7zKT1eYhqXsoJASQjE HElSF5JdosYQaDjEIgJ9uIkz5Emn9ywLFGIdBYB8TJXnBwRoTGZJqxvlkCJyCFpov2wOXusiKLT1563O0R0KKNVj Sly/Jx4HY4slVIX6UX1kdS6 riaU0SGR5RJI/ZZ22nHd0ekj3KcNKVqm2J1CGR2zMBgBm7D1yq91FXXK6lMrSNsaH0eIlpXMoKAiUhEOPHQvJKAl3ECALTgUBMsDdC8tAmRT4oE6TIHBEhTVIUEStE8lh5/OVgu1yrWoH Wg/0mKVaPKOu03N7JsuWICl1SB7KsPp5NjAyZdvQ tln15hNaboOjCot1XN6qFchfbEK2daL9roXWjhJVJiHJI/bqvaJtGkSR4TY6oplrHyfUBo1Krch4rbpNa0aEr2Nr p9PEfX TbGiNLjJaZxKSsIlIRAjB8XInkT74zD5GRrvkKlJJtFjCDQkQjEBHujJA9oGdOQJE1mzPJgGnHynhfjy7XYRS6rVLPkSnedJSesJ3V2S7dFJIZdNsu14VJlTT3r92uPRDKCaQiSInOMyGm5XD8is mENCR5WL uvqS80cGzSemibekfHIAeg4/CReFsSCguk/fql0Us6SWb1BK6y ql9hXpUMEtkTdcqiWih2qO7Qfgy7dUDrcxn9LjJaZxKSsIlIRAjB/XJXkHJ9 FxxafBhP73mnJ9 SVZLOIEQQ6EoGYYC9E8joSRTG6Kghw8saJHn/RgpcRkleVnhM9phKBmHG/Lsl7edMK2HDrn8CWkZ8KyZvKXpS2BIECCMQEu5C8AoBKkWlFICRwSPROXpq TEtlYxSWeIlBS8pWFYEYP84lefhLFw//6DgYX/VH8OA//QW89ebvS//Fi6qCKHoJAjMBgZhgF5I3E3q0s3WUX7zo7P4X64shEDPu55K8nS88Cht//CdwaKQGT93yJ/DM8G1C8or1gZQSBKYEgZhgF5I3JV0ijTSBgPx2bRPgSdWOQSBm3M8leQ9d d/gtZ8drkjeWw/9Edzzgz HB278Ktx40ZcLgSmTSiGYpJAg0DACMcEu8dgwzFKxTRCQeGmTjuxwM2L8OJfk7X34jwDW1RTJm/xVDcZX1uDp2w D27/3vkIQy6RSCCYpJAg0jEBMsEs8NgyzVGwTBCRe2qQjO9yMGD/OJXnwWA3w79CaGkw WoPxh2owel8N7u3/nwpBLJNKIZikkCDQMAIxwS7x2DDMUrFNEJB4aZOO7HAzYvw4n Q9XAN4uAaHVtVg8qEajP9zDUbvqMGFp/2nQhDLpFIIJikkCDSMQEywSzw2DLNUbBMEJF7apCM73IwYP84neQ/VAB6qwaGf12DywRqM31eD1VcfCYsuPasQxDKpFIJJCgkCDSMQE wSjw3DLBXbBAGJlzbpyA43I8aP80neUA1gqAaHHqzB5M9qMH6PkLwO9y0xv2IIxAS7kLyKdZ6oM UISLxMOeTSYAsQiPHjfJL3sxrsHvw36suQX7r938L4YA2euuZ/hqvPPaGQ2jKpFIJJCgkCDSMQE wSjw3DLBXbBAGJlzbpyA43I8aPc0nev179v6gvQ37xiTvg8TvOgn 59H9TJK//Gx8uBPGWLVvgvffeK1RWCgkCgkAcAhhbGGPj4 Owb98 9fvS AXmWR Jxyxk5HwnICDx0gm93P42xvpxLsnDL0PGSQP/JicnYftvV8OKa04u/OLFrl27YOfOnUL02t/vxMIpRgADHWPrtddesyTv4MGDKlazVJF4zEJGzrc7AhIv7d7DnWFfI36cS/IINiJ5mDEYHR2FO269lC7lbrEeTkSYQcD0ovwJBuID5fgAxhQSvLGxMdi7dy9MTExAPZIn8VgO9uLDMw9HiZeZ12cSZ8k a8SPGyJ5WKnoB5nngQMH4J133lGTERJF RMMxAfK8QEkeBhbGGMYa/U Eo/l4C7 OzNxlHiZmf0m8eb3W4wft5zkYfYAMww4CWG2AZ8dkj/BQHygHB/AmMLYqpfFI/In8VgO7uK/MxNHiZeZ2W8Sb36/xfhxLsnDpVZ67mfHjh1q2XXDhg1wxx130JxRaIsTC2YQcCKiP3zGT/4EA/GBxnyA4gi3GFsYY0U/Eo NYS6 OnNxk3iZuX0ncef6rhE/ziV5NGngpIBAY8oUn8mLWa4lGbhFOfInGIgPlOsDPMZi9qUfyu0HwXNm4BkTI7ys9O/M6N9O6Sfum3n7U0ry8hSRa4KAICAICAKCgCAgCAgC5SEgJK88LEWSICAICAKCgCAgCAgClUFASF5lukIUEQQEAUFAEBAEBAFBoDwEhOSVh6VIEgQEAUFAEBAEBAFBoDIICMmrTFeIIoKAICAICAKCgCAgCJSHgJC88rAUSYKAICAICAKCgCAgCFQGgYZJ3vr16yHmD79nrx0 aEeM3VI2zk8Er/p4Pf300 KDkeMP pXgVt 3JP4EI/GB9vKBhkleLGFDx2mHT4wdWHb37t3yJxiU6gPig43FVAxu7TBWiQ2CgCAgCAjJi/SBmIlCSF5jk7EQ43zcxAfz8cnynxjcIocFKS4ICAKCQCUREJIX2S0xE4WQvMYm46xJWs5rPMUHG/OrGNwihwUpLggIAoJAJREQkhfZLTEThZC8xiZjIXP5uIkP5uOT5T8xuEUOC1JcEBAEBIFKIiAkL7JbYiYKIXmNTcZZk7Sc13iKDzbmVzG4RQ4LUlwQEAQEgUoiICQvsltiJgoheY1NxkLm8nETH8zHJ8t/YnCLHBakuCAgCAgClUSgmiRvdAB6ajWosb/ dQ6/kT681gMDo 7cVO3FTBRFSd62O fBnDlzEn XPdbYZBZOckr vAHYNl1vuT52mW/b5Y839Lbp45cnMbK4oUzVzmXweJqdedfSyuO5FwZgXkq/zGlQ/7BfGj0u1QeVjQFmxu55d27z knhXw9nwjIPbyV/Hgy8sDu/z0hWSdsY3KZqPJF2BAFBQBDYv38/rB0Zge3bt5cORvVI3rp Re56BndaY3cO9njnWkHyRvqKkcaYiSKK5IUkTE2SZiJscpJrnuQ9DpfNmQONkE5NYH0Socmafy6W8FjCwbHJIxZ517gMvs/JiD2vsQgJUKz zZQv1wdT haxmjcP5nk ycoVwTKvDMc1r1yAeSP x3GOwc0OPrJTEgI7YaA3 8Yd1LjfDyMltVZfzAj012rAkwdUR80vfVOnCbU7/dv9MNC7G3oG9wOM7oWe2h6dSFk3DrXaeGrfjPTthlrN/0vDtNW2KT369qlm H6r2y1L/qZNm2DNY4 pv9///s1Usfg9n1ju7bffTr2edbJiJE8HXq1OgJVN8mLkxUwUTZG83dtgYN4cKINMTBvJ45O5nbAxO9m8bdEkz2u/YIY0Q//m8SzYfobOZfsgYsn9DI8vewxJHSPiCgt2nKGbJVV55C0DV1s3IZsRzMS14ljG4JY1YMr5RhAwBM8b1wOSJSSvEWBLrhNB8hQJ3A01Q6ysInS dy 4NI292rIdTuz4fssaLFHw66 /YQkeEb3JyUmvBcz00TXcPvXUU971vINqkbyULF6a8kTKetidIc/86btCdtfIBheq29 ns4Of/4fPe8vCnpyUxmMmitJInplgLzPLlZTRUESHlhO9JURNovRS5jy47PJ5MMdkZUJyFBIWnXkzy6KqDpdlsnlKH7d0SvqEk3Qom1/n17ROl6lsIemslvJyJvTQDiXbEIsBtvxtyYtHOnybMpdfM8gI150Iq1025sTIkFmyifcD6pvEuhhhKdsHlR7WfxAbnUFGjG3fIn6U2eNYZvlCXl9wXLksD685oPvF7yutj38us/8C/4nBLSX05VTDCASEzshRKzRsbG5YfEMV03VqSFSnVTJELjtjx8jiNGAz00je vVPewSOyNyvf/1r MMf/qAQ3LJ1q1dm67ZthZGtFMmjZdls59F2aaJWAyJkRNzUM3rmeT66FsoM66JEr34d6GImiqZInpr8zHKtmUgtYSGCQJPubp3poOs CdHXaIIOyZFX1ptwd4MryzMpeoK1k7/SLT3D4 qnkBfWlio3xy1Nq2NrW0rd3Vw3dl3JZFkpjiFrL0lqGJnhxICTEXs BWuPILn2PWxNH1E/hM8P5mJl29a2lu6DvA9x32DPccJ98i ne44v5PUFx7VQv3D/M Q4wNz6Y4AVv7GIwa3OMCCXoxBIy QFAoJMHo3T Fx2fx8 wqOXctX5vn611Kqf2Q4es/Ge5w6umSSCqmdkpM01ug1crtV69/T1s2fEc5aUvbZr4K1I8bZznyfXBEkvge6B/r49UGNZMUVgaHnUZtGIVO2FfrqGdSirhudIhjpn5FLZhJz85VqPRLE2cJkXr6nl3nCJVx2bZd2 caWnwt6UGxjcY5d98Ty3k/cRP1 j5WQ1h7usoqdf4GZ6GZqWl81ytCnjyU5gUgDbsK0Cx7/5zW888kYEj7aPr12rpCDho3M7d8blSGcwyXMBHBI5hYoXVO7ZizRCl3Yuq39iJoookkcZOba1ExefFNUkpidXO l6pC/vWpIccSKSTTT4JKvlW7KSM6lmy/MfuA/LcZ34JM33wzrqGiMM6pjjxq4p YxUcrnevqrvMpY2W2cJBiOYCgdOAOv3A 8//ZJHOln2dNq9W/1ubZZ/hueL SDqbUg24kT2of2K8KEtjoSHJC/VFxjeib6I7hfuf5QBZfrk CDHLiZ2QxzluEkEAgJEN FWKid5fN8QLY/kMZKkxu7eAbM0GGTnPDn tdQ5wygTkjxqm0ifR96sAZoQWkKi7KU5CtumfQC10mR1tgLUzk4kO0TIYJ8mbebYv0bEbj8AEDGk5 b8ekRslG5EyojEmGOtN5NpyKBKnHiEDWUbcsTLENGq7TbPObJyxg7CRtlB5Qz5U8QQabUhe1RWES/CA8vSPrVn7ODEju/76GpcSDYwu3xsdTmtUwS2fmN1j/bufdsSNyJwadvHzLN6eO2JJ56oKzcsUCmSR8usiQEg0DokZV7A2sFEB5V3LSNrF8oLmvMOYyaKYhOsmbTyMld8UmRkwpJAj T5E6Ka5HDCNfJDcuQIVZKUuAkylGmIHhHSDN2d7JAM TZn65SsRzqFdaydfLmU4xaQDk30iMBlEAZeP4tIKLlOzjz7HGWIGbc5wI9wJKKV1ZY53wofRDzRn2ircSZyh7YwAuphGdhCvuCVoTeVDc4c16Bcer9kYNlC3Lygl4NSEaAxWWXp6FsTGCFzJMs0m3NNySLChOVoX1VlxIvJ0FJ90scNdO2bTB57CdBd4zVS9lV7ROx0W nkkNdlJMucduRDX7MEBa9b0hPWC48ZuQmIGXgEjNXj5RgZcm3qbBuRM6WuquMTTaUvr68KMn3Ca8Gxs98AYjdaV3omkBM7vm L404g211jdpuTrt3wWnjMbHEC7R76eNbnueefL0TyOPEbfeWVLHGZ53NJ3q926If/Dh3cBU8O/BC 9Y0zYd73b4LrB4YyBWZdKDYxFQuGkJTRoIEOxfdRl/A4rItl0s41Z4eu3TqSpydWnglyhCrvWhmZvJB46QmY60JETGen0giUr2NI2JwtYVvuOKwTS/KsjrT0S SEEyxORvh5u /bQc/naSzCa5zk6X5IxczKdrZyXXG/WCzFC8Ox/3M3YGm8vuHIB5lN1D/QJi5vRjvhCW4Vjy/bAcs1/1seqXJMlzbRqfTus/JisWt6z4l/PlIaDHZrP8aUlYkljxN29DkqVkGGJHY71exnXPZGPSgJfTFjACGJjk2kjq4q4Flew8Ytrt7YEenr0DM7fR14KlPouYJAyObOhr4Zus q3XkHiEx0wuJ2/KBHbNZAQVcePlODnCfZVN4/UMFvYaHuN1nfFzNhBmrC6XjZeDY6 u0skttfb0pi/RZpE8TxaporZMH3PelQ2xDI TdT3ROQcjIyNRJO/xxx/PkZZ9KZfkbdjxDgC8Dg8tOA3Oue1JeO7VnfDUiovh//nkWdkSM64UnphUsLvn7VAcBS9l EJSRtc5ydNlXWDRHVBY18mnu64MA8zpwnYAqMmYT0ZZ 3VJDZ8UzcTl12GTK2X1bOZFkw3K5Kl6GdfCydu1wSdZvo9ERMvnWUVup9 eJi5q8rY65BNPLovvN0PywrpKR05iiByk4M51INvt8qYiLI09k5eGk9 WI32t8EFFyC /DC4LydJjl8E8/DoV/p15lpjl IItY/TmWPJ9Vi67X/x2sss5jNKwi8EtfxSQq1EI4JjuZdhMbUvszBKm99wd woTVi4kWR55y2oHm2MydOt6bqB5gdvj2ogged7yLACEx7wBs9qUbDskEGb5UpEqfS1ZBwWH9cJjRkQ4eVM6sWtcDi/HiZclclgv5Zk2s3yqSBItCfP6YZvhteDYkS3znB7JbGS5NpDtuiTEK4m7y1iGZTl TmKRvaeeWm9J3q9 9bjdHxlZp/bx3Jtvvgnr/vVfAZ/N27dPf0VMEdm8TC7JUwV33Ad/f9ptsHH/JIyPj8Po6FNw/omf5DIK7UcNsHbJ1d2NcecOiRonefa5CXPHRA/NZhFEpTxvL/UOy5kYYweWTZtswnOOTGVMUnxSJAJCGShasgpIipoIzbXLLnfLtbvpBQB1bR4M3MmvmWwTyQyJ2BxDYJQ tERJb0Fm6I76GvKT9Uxb6qQdkg1mN IX1lGYMsKgjjlu3jVDfFPs9PqG1w/at W4bZc/HujF27kM1Fu/zC5N7AjHtIxnOqat8EHrF4EfpWZjOZZZvsDLIHYcS77vleN4IS5uiZj8mWdJrT xcrZfUvorBjcX8bLXPAJpKzSaQNklTE7C H7aM3lsjPZInsmW2bnCI1NaB5oH6NEgW5YZ2TjJy3j2W nBkwioCz92jXNSQ0up9Byaf82QHkYACxERTt5Us5ykMALDy3FyxPa9jJk6b57HU/ucAPI2DIHynsmjJd78TJ5qj57JU/rFZfIIT9vnzEYfW62vxpNhovAKj33bXE/W33vuuecUmduyZYsqvHvPHjh06JDaxyXa559/vr6QAiXqk7xf/wR6Tzsd5v39PDjzG2fC177 NfjsJz9bQLRfpF0G2Bg7sGzepCPX0klMu KSmTFMISR5GIgPNuY3Mbj5o5ccNY AIXW0XFnzV2vCTJu kceb/B4YGAzfrnVZPp/kUQbNJQcsqUMD M18bz/09zpSxu1riOQFy7X964JMoSKuGXrxxu1LFLgsOQ7qrVMiNpS9ordi7RcUh8QjPGZEhBEb3Sy7ViST5z3Dp uqJeS feyNWEbayDZDArFsz6B U1WRLUYaVdHg2CNfROzM28Ij7CUVTjj5vqrPsn/0Egote1vCF2Jr64RYhsccPzK22PZZQ/LeeQdXTP0Pkrzf/e53/skGj4qRvPnL4aVJyuSNAlaK/bTLABtjB5bNm6zlWmOT9UzBDbNPbplTLzm648ZtFx9sDLsY3GLHNynfQgSQIKUt97awyaqITpCUCiimdLIEM0shTX5cdpGXw2s808evdc4 ZfJCkofZPCR5e8bGSgEjn S9h8v9/wrXnXYm3PrkHrNcOwpDDwjJK4K kLzGJuOZQuLq6pm1lBmZuQvbiSEr4oPOB2NwKxLfUqY1CKjsnF2SDZZ1W9NkZaRiFsoRI0eUKPNUhS2CpYke19VBSNdslkxl4Fx2j5PEKthTlg4OgWJ7o6OvqN qHd 716uAX4C8ceNG71wzB7kk7 Jf7lGy3352EM758t9C79dwufY0 OSnvxbdJv7uGn17c3TlilRA/dGOoh8s 9Zbb0k2r0lSE5KcTj5GfxIfdMStqC/E4lY0xqVcKxAwz/DR0m4nZfH4kiQuS9plw1bg3KxMTUITJIktL1MLagnVLjNLFg9xwd gxZ8ve/Kpp2Dy4EGCCg4ePAibN2 2x83u5JI8Eo7pQ1TmzVd3wgvPbW9ouRYfItyzR5NGkjvTtqh/zMOQmI595ZVXhOQJySvNB9Cf0K KfsQHNSGMxa0ovlJOEBAEBIFGEHjttdfUsiy cIGEjz47d 0CfMM29pctqH64jSJ5 u3axp7JwzvpZ599VrHUUImZcIzsGvVHO4p sCz bAm Bl0045YnUYwAAA0wSURBVCDl4rM0nYIZ hH6UyM iHU6BafQzkZwKxrjUk4QEAQEgUYReGv37kRVJH9PrV9f2srnlJE8tARJEv5hRmymLN2inqgv6Z7okTonsB5OzJhJ6OSJNpx45bg4mUW/Qf9BP0J/iv10qg82i1sszlJeEBAEBIGqITClJA Nx4EXlzzxuSJ8ELrqf6gn6ot6N/rBurhsNlNsrnqfdJp 6DfoP KDceNFGbg1GvNSTxAQBASBKiAw5SSvCkaLDoKAICAICAKCgCAgCLQ7AkLy2r2HxT5BQBAQBAQBQUAQ6EgEhOR1ZLeL0YKAICAICAKCgCDQ7ggIyWv3Hhb7BAFBQBAQBAQBQaAjERCS15HdLkYLAoKAICAICAKCQLsjICSv3XtY7BMEBAFBQBAQBASBjkRASF5HdrsYLQgIAoKAICAICALtjkBDJG/lypXtjovYJwgIAoKAICAICAKCwIxGAPna2rVrAX xDH eFn mlj412qHfrqWfNROSR8jIVhAQBAQBQUAQEAQEgWoiEEXy9u7dC6 io89NBDsGLFCrjzzjth2bJl8icYiA ID4gPtJkPXHXVVSX16WK48Yffhrmf/lN437Gfh7lfnQtzz7kGli1bBJfMPwNOOeFj8JE5H4HjTj4bLrrZzCfXz4ePve9jMP96c3zteXDGV8 GC65frHS68YIz4PMf/wh85OOfhzMuuNHpeeMFcIaS9zH4/FfPg2sWJ eni059H7zv1ItcnSU3wgVnd8Nxcz4CHznuS/Dtf1pkry26 Gw444Jr4MaL58NcJfc4 NL3UXeSuwiu M6XVF3U/4JLLoCzz74IFtH1RVfAt089Ttt36rfhikW6Hsld9E/fVnZdZM5ruYvgiu/Nh 5j3wd/ ulTFF5nX7wIlhlMzr74Ipj/1c/DxxCzUy Aa0xbi6 /AM7 qrHj45 Hud 5Ahaba9ecMxfmX3IjXPO9s6H7OI3b2ZdoLJ0tqNsiuOjsuaDaM3VR17nWJmfvR47rtuVQvu5Tg8tV58FcxF/JiOhn0 ayZVk swyWIabG/o dcAZccCP1RbhN1/XG R D9338bLgotU vgfO OhfOu0rLUv30/Svgiu/MVf72sRPmwnnXhu1U8xj5GfI05GsjIyOA/C03k3fw4EF423YdeuXfDiiy/CM888o36SbN26dcD/UJj8CQbiA ID4gMz2weWL19e0li BlYuvRn 8YuHw Ff/Ee4 Zab4ea7V8HIyAq4 dLrYNn9q2DVyrvgijOPhcO/dB2swjnkgUvghMNPgEseGIGR y Bk446FubfhnVGYOXlJ8EHj5sPN2O9 6 Ds449Cs66ZQ2MjCyD7x7zYTj9mhWwatVKuGvx7bBiVbIPbv/7w Hwv7/d2LYSrvjCUXDsVxbC7fevghWL/1G3tRTljcDKS0 Aw4/6OJy 8Ga4a VKWLbgJDjq8C/DdUbuioWfgcOPPQuuuHslrLz7Zlj4lWPh8LBFaiDWuWwfxjj4UvX7oMVq4ydT 9EFaQ3GM/A71fOgu 2FcLun5yq465Yr4Ky/Ohw fvYVCq9lD6wxmBwFH//aQrgZ27tjIZx01OHw5Ws0LqsWXwdXLL4LVq4iOz4M371D269s/tMT4LtXLoMVq1bAdYj1Md FZYn5eiVc8teHwwmXrjT4GAyMTauu TIc/tf/CMtWIvbL4Lo7dDkf0xEYWTwfDj98Ptyu5BfsZ0 XDJ9RmB4Fn/nmdao/7rryLDj2qJPgCvQTr/4IZOma36e3w/zDD4f5i7U8XfYzMN/gdvv3ToKjjvoyXPdQsr2w/ek6Jj6GP/ JPA352hNPPKH4G/K4zOXa9957DyYmJgB/WB6zeVgRf08TfzQd/zZv3ix/goH4gPiA ECb ABmAMoc1 /8zhFwxHfuzJZ51zlwRPfVsAbxe RqOOmIk DqgavhlA/8JZwzsM7U wVc9pkPwDl3ufnmF5d8Cj5w7n2wefOdcM4HPgXn30VlXRluh6fHQ5fBp474Ovx4nSuL8o742o9h3ebNsOaak5xOqNfTS EbqNcjWP4 OH/OEfCNxU87m5gNTy/ RkrdU CGNSlyEz6zBq7uPgJOumaNk02YqLax/adh6dlBGStH1yecPJuxjLL7HLjTlif7k 1yDNT V66GNZuovN4m5CMOR6TJ3wybGUa2n61N XIVpnPOh/us3hqD/3oh9r9fN0tXbo q4/XpnXDOEUdY/0qU3Yz dwSc8iPWL0G7oR5TfUycDPkZ8jTkaxs2bFD8DXlcKsnDlWa8gCxw3759iuhhRg8rj46Oyp9gID4gPiA 0GY gA9rlzm D10wC2ZdMMRkvghrliyAr3/ueDj c8fD13tPhFm9i2Aj4rh EZwy62g4 uhZcNrNG1mdIVgw62j48HG6DtY7/r8eDX9x6SpVZt0d34QT/3wW/NnfnA1X3MfruXnK02PlApg1awEM8b775/Ng1kf7YdXoKGy89RSnkyqD7Z8Ci9ajPNyfBQtWOtmjKM/YoOrSeUbUrPz30C/mzW2TD4bJpcJkO1sxEW9c6CU25lNihMqG1dHm2xZZ4ZgivOOkW313sanPhRp5tns8U3sDujXQ DF1bBFV/6MBx99IfhtAsWw5pnnR5e33q41utn3ybuc6Heni5K31FYd/MpMOusQXjWHNv6GbomZWT3abLsKAx9j2EetlmhY RnyNMwMYfEL8ziIa zL14QySOihxk9XLrFNV58GYP/jY2NgfwJBuID4gPiAzPbBzZt2lTqWP5o35FwZN jTubIlfB// WF8PPfaZxeH7oQjjztp7AV55DnfwqnHnkq/GhZP3z6g1 AK0deN/Uehf4jPw 3bsrD9nXYOnwrfPNTH4Rv/myHa8/MTZ4ej/XDB4 8EB5l89bWwa9ZPbYuO9Xua3/G9k Fnz6P7a F/g8eCecOkW5jMDbcb8urut/7ObzOZFNMJOWG9myFn552JJy6bKvT32Ci29bl0RZdZgfcddaRcOqPN v23twMt556JPQPu3Ie9kpWv2e31i3Zbqquv1sP91/6Bfjgp34E68fGwMMU7UUcjjTyC/Qzt4kwwm0oV/XNqT FzQzTtZd 0Pcrdk3JCnRN2sP7FPcdbsmyW GuMwjzsM qcUx8DPkZ8jTka1u2bFGJOp7FS5A8TvQw5YesEB/iC//effddkD/BQHxAfEB8YGb7wPPPP1/qWL7 yg9B1zk/h71mjnjjwe9AV/cS2ErH938HuubeCa/g8Ut3wle6vgJ3vvQuvPHY5fDZD/2/cOc2xHMv/HLhh Czl62FN/hcsy J9dofdsEpS7cmbFh7WRd0XbZWn9/7S7j4Q5 Aix95w5TbCnfO7YLP3vQbdfzKXV9xOqn21sLlRi/07/U/ ix0/e3l8Mttb8Abr/wGViz8rCv//BI4xept9DN6JuWG r8CK87qghNv1XqoWGKYUGyhLV 56xV49931cP3Hu D7D 81dq2HW7q74PIRLdez2eJ7OazlGKr9vfDLC7rgE9euN3jshfU3nehs4jhvwz66GH65713YevuJ0DVvhe2TN7Avu7T8ov1MNvFt6DPvIqZdX4ElyhfehXd3r4WLP/4h M5D1H8Mxwxdk9jzPsV9h5sq230LrN9r5G5bAl/pOgWWPM/aSWA4vdc4J0Oehnxt27Zt3jIt8jn8eJk8c05tkA3Kn2AgPiA ID7Qvj5AE0NpffzrH0P37C7o6uqC2VdvgkNvPwFXnjQbjjmuG7qP yJcePWF0H36PbAL55dX7oG5XXPhnlc0vtt/fi4cP/tMuOelQ3Do7U3w49OPga45x0P3F7rh DnHwPyf74JDu34B8 ccA8d/AeUdA7NPuhKeeDvZP3tWnQvHdHVB1 VPqHls/69/DHPndCk9jp8zG7rP/wVsN3PcrnvnQhfppM49AVcyvQ4d2gNPXD9f6dH9DzfA6nt/6JXf/vMLoXv2bPjoSd3QfdJH4Zi/vAE2HToESbk5enZ1wZn370pggv3yxOVdMPfeXcqO7ffPh2NmfxS6v3A8HH/6DXDlfCK5/UcrEc2av6U F7JTyRMpfvf/JKOL5L63z8cWfCDVefC7MNBptuQhu6lb0fnX0MzL9/u YCL90DZ842GGJfXv9D GKXkZ/Xz4c2wY9Pmg1dHqYMi9BnDh0CjinqMHfRJtifYkeWrknseZ/ivsNNlf3EF2Eu umcY6Br9kedzSltlhYrJcvGZ/PSPpkkL62wnBMEBAFBQBBoHwSyJoayLTwwNgYHGhH6jl4eO3DQr4zyxsZiJR7Qy6Lv LJij8YenA9dZz8Ar3sVjexonTwhxQ4OjMFYkzaohlBOlr7q2hiEuMNBbWcW8g33c5rlpq0sFW2VLF1tgfyd15cjyb9X9afSP/C1/NrVuZoVy0LyqtNHookgIAgIAlOKQNbEMKVKVLyxsWfWwKpnXlIE8fVn7oVzj5sN5z40VnGtRb2iCHCSV7ROFctlxfL/D46dN7f3hoBlAAAAAElFTkSuQmCC
I've been buying them when they dip down near $48 a pack. So far I've bought 24 and had 1 light fail to turn on. When I get an 8 pack I test each one.
I'm not replacing my Fluorescents that work yet. These are linkable with standard 2 prong plugs. I was hoping they would drop down to $24 for an 8 pack but it hasn't happened yet.
   / Another shop light question #11
Any issues with RFI on LED fixtures/retrofit lamps and any issues with tripping ARC Fault breakers?
   / Another shop light question #12
Not that i have heard of, and ive installed alot of them on gfci circuits. I dont believe ive done a retrofit on an ark fault that i remember. But i dont see how it would affect an ark fault.
   / Another shop light question #13
I have a few questions in regards to switching over my shop lights to LED and being able to see lol. My shop is 40x70 with 12' to the trusses with pre existing lights 16 total. They are situated in two rows, every 4th truss. I'm assuming the height of the lights/fixture makes a difference on what style. Everything is already wired so it won't be hard at all and I'm trying to decide or figure out my lighting options. I'm not wanting to put up gold fixtures but I also don't want the cheapest either. I just don't have any idea when it comes to this besides the fact that I want plenty of light. I will also put in a couple extra around the main bench/work area. For those that have did went to LED, please share your experience with different light set ups and what you would do differently if you started over. Also I'm just starting to figure this out so any links or pictures would greatly help. Thanks
1. High loft vs rectangular vs strips---would rather go high loft or rectangular
2. Is a high loft what is called a UFO style
2. Best to hang or fix to the truss
3. When it comes to lumens or watts, what should I be looking at or for
Any other suggestions are welcomed.
I have a similar sized shop but 18 feet to the eaves. I originally had 4 high bay sodium lights mounted about 15 feet from each wall. The electrical utility had a conservation program and they changed them for me to four T8 high bay fluorescent fixtures that use six T8 bulbs each fixture. Last year I changed the bulbs to T8 LED Luminous brand similar to these
https://www.costco.com/feit-electric-led-4'-replacement-glass-tubes,-4-pack.product.100482236.html
The LED bulbs are instant on, very bright, no buzzing, natural daylight coloured light, and use a quarter of the energy of the fluorescent bulbs. The fluorescent bulbs were a quarter the energy of the sodium lights, took about a minute to warm up, white light, and tended to flicker and buzz, especially during warm up. The sodium lights took several minutes to warm up to full brightness, were very buzzy, and had a very yellow light.
I have no regrets switching to the T8 LEDs, no RFI issues. I have a mezzanine with the same LED bulbs and a motion sensor switch. I had to change the motion sensor switch to one that used a mechanical relay switch. The original switch had a MOFSET and bleed off voltage/current causing the LED to never turn fully off and flicker in the OFF condition. I had to leave one bulb as T8 fluorescent to sink the bleed off until I found a better motion switch.
   / Another shop light question #14
I definitely like the LED conversations for florescent fixtures, however if you don't already have the fixtutes I prefer the LED high bays (UFO style).
   / Another shop light question #15
<snip> Last year I changed the bulbs to T8 LED Luminous brand similar to these
The LED bulbs are instant on, very bright, no buzzing, natural daylight coloured light, and use a quarter of the energy of the fluorescent bulbs.<snip>
I've still a lot of T8's and T12's sucking up electricity so your statement of
made me look it up.
The link you provided has bulbs that
Features:
4100K Cool White
1750 Lumens
Actual Watts Used 14
That's about 125 lumens/watt at $11.25@/TUBE
For reference T8's like I've been using are like 2400 lumens for 32 watts (75 lumens/watt) at < $2@/TUBE
And the AmazonBasics twin "tube" fixtures I've been hanging are rated at 4000 lumens for 40watts (100 lumens/watt) at about $6.25@ FIXTURE.
I'd love to see inexpensive LED's that use "use a quarter of the energy of the fluorescent bulbs" but they just are not there yet.
   / Another shop light question #16
I've still a lot of T8's and T12's sucking up electricity so your statement of made me look it up.
I'd love to see inexpensive LED' that use "use a quarter of the energy of the fluorescent bulbs" but they just are not there yet.
they are definitely not There yet. I only changed mine because i got the lamps for free....left over from multiple commercial relamping jobs. I would never have swapped out existing lights for leds because the payback time is still too long. The only rime i install leds now on my own place is when i install new light fixtures.
   / Another shop light question #17
To me, that would add insult to injury. Replacing good old lamps for LED, thinking to save money and then the LEDs fail.
BIG difference from large and commercial installations to the little guys house or shop. For one, if you are that cost conscious, you turn off lighting whenever practical. A switched off circuit costs nothing! I feel just terrible, if I find out I left lights "burning" unecessarily.
   / Another shop light question #19
NICE.. I love your bright wall coverings. OH, to build a shop from new!
Staircase reminds me of that on the TITANIC.
   / Another shop light question #20
2016 Jeep Compass 4X4 SUV (A56859)
2016 Jeep Compass...
CASE TV370B SKID STEER (A52706)
CASE TV370B SKID...
2020 CATERPILLAR 289D3 SKID STEER (A60429)
2020 CATERPILLAR...
2025 JMR 36in Bucket Mini Skid Steer Attachment (A59228)
2025 JMR 36in...
Massey Ferguson 4608 (A53317)
Massey Ferguson...
CASE ROOT PLOW (A58214)
CASE ROOT PLOW...
