Best bar oil??
/ Best bar oil?? #1
Rebeldad1
Hughett Bend Washington
Kioti Tractor, John Deere Mower,New Holland Mini Excavator
I have a chainsaw that leaks with the thin oil and would like a thick bar oil.
Any good ones out there?
Thanks
/ Best bar oil?? #2
Fix the leak! :confused3: Thicker oil may not pump and you'll be replacing chains, bars and clutches. Choose which is easier for you. :cool:
/ Best bar oil?? #3
/ Best bar oil?? #4
Most bar oil is just like 600N right off the MEK or propane dewaxer. Heavier oil would be a bright stock. Like others said, it probably will not pump right.
Not sure where you get the bright stock type oil.
Ralph
/ Best bar oil?? #6
Yes - fix the leak. I make sure mine are pumping bar oil by running them on the porch of my cabin. Nice straight oil stain left on the dry deck boards.
/ Best bar oil?? #7
I should buy good bar oil but wind up just getting the cheapest stuff I can find. You will get good advice from the guys that do a lot of posting on the "Tractors and Wood" thread. Many of them cut a lot of trees. I burn 7 cords a year and do very little tree felling. My Husqvarna Rancher saw leaks and just live with it. Now that I have an electric saw, I no longer keep it ready for action for those small jobs we all get if you own land. I only fire up the gas saw when I need to do a lot of cutting and then drain it.
/ Best bar oil?? #8
What I consider the best I only used in racesaws. Slick as snot and used less HP to run IMO. But cost to much for regular use.
I just use Cam2 or TSC brand for everyday use. RK sells cam 2 brand for $5 a gal.
/ Best bar oil?? #9
I bought 10 1 gln bottles of Cam2 from a logger for $4.00 each when he had a retirement sale. Love the stuff.
/ Best bar oil??
Not sure there is a fix. Dewalt 20v. Directions say drain it when done using. Its self draining:). Goes through a lot of oil when cutting with it.
Heard from several they are leakers. Just made that way. My Dewalt 60V doesnt leak.
/ Best bar oil?? #11
I run the cheapest $5 a gallon stuff I can find. Any oil is going to be thin after the saw is hot after use. Just lay it on its side. You might could try gear oil but it’s like $20 a gallon for the cheap stuff.
/ Best bar oil?? #12
You might try taking it apart and checking it. My HF Lynxx battery pole saw leaked all over the place. It turned out there was casting flash on the oil tank nipple.
For bar oil I use whatever's cheap that has tackifiers. Some bar oils don't and they fling off the chain too easily. TSC's stuff is fine. I've also uses Bailey's and Husky bar oil and not noticed a difference between any of them.
/ Best bar oil?? #13
I returned two Craftsman saws that leaked and made a mess in the truck... guess this is why they come with big plastic cases?
The Echo I now carry has been with me 15 years and no leak...
My Stihl AP battery saws have stayed clean too.
/ Best bar oil?? #14
Sithl used to make a summer weight bar oil and a winter weight. Now they make a synthetic "Platinum" all season weight. But maybe that's too costly for large volume users.
I think that I've read that some use any oil around....e.g. automotive engine oils....even used old oil.
/ Best bar oil?? #15
Husqvarna bar oil seems thick but flowable. Got it at Lowe's
/ Best bar oil?? #16
It's all I use.
/ Best bar oil?? #17
All I ever use is used motor oil - but my chainsaw
use is very infrequent
/ Best bar oil?? #18
Saw dust is a wick and draws the oil out. Was the biggest complaint when i worked at a repair shop. Just clean saw at the end of the day. Tackifiers in the oil help with chain sliding around the bar and prolong the tip sprocket if your bar has one. JM2C
/ Best bar oil?? #19
I just loosen and then tighten the oil cap after use and no oil leaks. Seems like there is a vacuum in the tank that pulls the oil out or something.?
/ Best bar oil?? #20
Try laying the saw on it's left side. Works for me.
2022 EZ-GO ELITE...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2006 Freightliner Auger Truck (A63688)
2006 Freightliner...
New/Unused CFG Industrial MX12RX Mini Excavator (A65583)
New/Unused CFG...
2019 John Deere 460E 46 Ton Articulated Dump Truck (A64194)
2019 John Deere...
2002 Kenworth T300 TMA Attenuator Truck (A64194)
2002 Kenworth T300...
