AZEK decking verses TREX decking
/ AZEK decking verses TREX decking #1
coobie
Super Member
S.Michigan
Kubota RTV 1100c, JD 740,Kioti DK 40 with KL401 loader .
I am going to replace my 10x20 wood deck next spring.I am currently looking at Trex & Azek decking as my options.Any & all opinions are welcome.Thank you.
/ AZEK decking verses TREX decking #2
When we recovered our deck 12 years ago we went with Fiberon decking from 84 Lumber. It was less expensive than TREX, easy to install, and has been extremely durable and very low/almost zero maintenance.
Frank
/ AZEK decking verses TREX decking #3
Is 84 Lumber still in business?
Frank
Any sun fading issues as our deck will have a southwest sun exposer ?
/ AZEK decking verses TREX decking #7
They are probably both very good. I have Azek and it's done quite well for about 8 years now. I pressure wash a couple of times a year and spot clean any stained areas (grease, mold, tree sap). The hidden fastener systems looks good and is reliable. I have a combination of light and dark tones and fading is minimal at this time.
The negatives are heat buildup in the sun and being slippery with snow and frost, but I think that's going to be the case wiht any composite.
/ AZEK decking verses TREX decking #8
Mine has a full southern exposure here in MD and we’ve seen very little fade in the last 12 years. About the only thing I’ve done to it has been an occasional pressure wash.
/ AZEK decking verses TREX decking #9
If you get lots of heat.... look at aluminum decking. I used nexdeck aluminum. Non slip, stays cool in summer. Powder costed. 42E1C7BA-0C34-4F2C-BFF9-C24377424E35.jpeg. I was going to use trex till i talked to a few locals here that had it. They all complained about super hot in summer and slippery in winter. Also some buckling issues.
/ AZEK decking verses TREX decking #10
I'm not aware of any Azek product intended for decking. Azek and Trex are 2 different products intended to be used in different ways. Azek is a PVC board (same as the PVC pipe) it works well as mouldings, and trim and does not need to be painted even in exterior applications. I have it on my cabin and really like it in it's use as trim. It's easy to clean, except where a cut is made and left exposed. When a cut is made a lot of little cells (like honeycomb) are exposed and will collect dirt and be difficult to clean. Those need to be sealed - one way is to use paint another is to sand and then wipe with Acetone, but I've not be especially satisfied with those results. It is not self supporting so spans are limited.
From the Azek website: The Most Trusted Name in Trim, Moulding and Fastening | AZEK Exteriors
Can AZEKョ Trim be used in structural application?
No, AZEK Trim cannot be used in structural applications. WARNING: AZEK Trim products cannot be used in any stress or structural applications. AZEK Trim products can only be used as the decorative part of your application; either wood or metal structural components need to be incorporated for structural applications. Check with your architect or builder if your application is structural.
/ AZEK decking verses TREX decking #11
KennyG - are you sure you've got Azek for your deck surface? If so, please post a picture.
Your website is different then mine. AZEK is tied into timbertech products.
/ AZEK decking verses TREX decking #13
Interesting. I wonder how the term "Azek" can be used by two different companies? As for your Azek, I'd look closely at what happens when you have to cut the board (as in cut to length or rip it to fit a narrow space). It talks about 3 and 4 sided caps, but there are 6 sides to a board (including the ends). Does a cut edge have to be sealed? Can a cut edge be left exposed and does it have the same color all the way thru or is it just in the cap?
I am completely unaware of this version of "Azek" so if you go this route be sure to post how the project goes, the stuff sounds interesting.
/ AZEK decking verses TREX decking #14
Here is another good choice:
Explore With Decking Visualizer | Royal Building Products
I do not have a Zuri deck, but I can say that they put in quite a bit of time testing and developing the product. Evaluated for years in various climates prior to sales in either. Their product is cellular PVC, not a conglomeration of plastic and fibers as some other are. Best of luck with finding a product to fit your needs.
/ AZEK decking verses TREX decking #15
Multiple companies can have the same name as long as they are not direct competitors. My Azek is solid and the cuts can be exposed and look fine. However, my design used contrasting edging boards so it has almost no exposed edges. However, I used cut pieces of decking board to top my posts and they look fine.
When I get to the computer with photos on it, I will post some.
/ AZEK decking verses TREX decking #16
I have a 20 yr old Trex deck thats held up very well. In fact, my treated lumber framing is rotting and the decking is still fine.
/ AZEK decking verses TREX decking #17
What I never liked about composite back in the day was static, did they cure that?
/ AZEK decking verses TREX decking #18
Here are some photos of my Azek deck. Note the use of contrasting colors at the edges of the steps. I think this has turned out to be a valuable safety feature in the design. The posts are 4 x 4s that are covered with the Azek post covers and topped with a section of decking that was painted black.
/ AZEK decking verses TREX decking #19
Timbertech website shows azek decking.... weird that same name product is used for trim and decking.
2018 PETERBILT (A68134)
2018 PETERBILT...
AGrotk 680 QA Drop Hammer (A64912)
AGrotk 680 QA Drop...
2005 Infiniti FX35 AWD SUV (A66738)
2005 Infiniti FX35...
WHEEL LOADER FORK ATTACHMENT (A67714)
WHEEL LOADER FORK...
INDUSTRIAS AMERICA 2426 - 10' OFFSET DISC HARROW (A64277)
INDUSTRIAS AMERICA...
Schulte XH1500 (A64911)
Schulte XH1500...
