Smart Shop tips!
/ Smart Shop tips! #122
For those who use rattle cans and hate the shaking, if you own a sawzall, take a 12" blade and some hose clamps and make your own mechanical shaker! Have used duct tape and also electrical tape in a pinch. Sure is quicker and easier for those of us dealing with Arthritis!
This probably works well with full sized sawzalls, but the hand held versions might shake almost as much as the can does. I've been using the small versions (one battery powered) for awhile and they take a bit more of a grip to accomplish the same task as the full sized one due to less weight. I'll have to try this next time I need to shake a can to see how the small sawzall does.
/ Smart Shop tips! #123
I see used corded reciprocating saws for sale cheap often. Perhaps mount one permanently somewhere set up as a dedicated rattle can shaker.
/ Smart Shop tips! #124
Where do you get the stickers? I see them on tool boxes all the time but don't remember being given any. Maybe I toss them without thinking about it.
You get stickers by spending a lot of money online ordering "stuff". Most companies throw a couple in the box. Mine are mostly Jeep Offroad Parts oriented. Did I mention a LOT of money?
/ Smart Shop tips! #125
Change your username to ovrspnd .
/ Smart Shop tips! #126
That痴 actually a good tip. I have 2 ATVs, both with leaky petcock valves. Replaced both but they still leak (stupid cork gasket design). I知 going to try your silicone grease idea.
The problem with cork gaskets is that they are easy to over tighten. I got my hand slapped and my ego bruised went my first boss in aviation caught me tightening valve cover gaskets on a Lycoming with an open end wrench on hex flats of my screw driver. I always remembered, after that, too much torque is a bad thing.
Too much silicone on the inner side of the gasket can break off and clog grease passages. I think he meant wheel bearing grease. It keeps the gasket in place while tightening up the fasteners.
Old Crisco lard works well too. I like to use old Crisco to hold small, hard to start nuts on my finger tip, when there is no room for two fingers. Harder on your finger's skin, but a more modern practice is super glue the nut to your finger tip.
hugs, Brandi
/ Smart Shop tips! #127
hugs, Brandi
I’ll keep that in mind. I’ve read silicone grease is what people tend to use on carb gaskets?
/ Smart Shop tips! #128
Form-a-gasket, or (later) Blue silicone was used by me lots of times on iffy used gaskets, on my own machines. It's just too easy to leave an unseen large blob inside. I love my Cummins and Mahindra when I open something up and only see an oring. Orings are the cat's meow of sealing.
hugs, Brandi
/ Smart Shop tips! #129
Agreed! I still do on occasion but I try not to.
/ Smart Shop tips! #131
I had posted grease 4 gaskets, I always used 'dyno' grease as if it oozed inwards on carb gaskets the gas would simply dissolve it.
'nother tip is to use plain cardboard to cut gaskets and bearing balls to punch/locate the fastener holes.
U gently place the ball over the fastener hole and give a slight tap with a hammer and ergo, a perfectly located and slightly oversized gasket hole.
/ Smart Shop tips! #132
Good stuff right there!!!
In a pinch a small ball peen hammer will suffice for the bearing ball.
/ Smart Shop tips! #133
For making washers like this
Use something like this.
Hollow Punch Sets | Mayhew Steel Products, Inc. | The Pros Know
/ Smart Shop tips! #134
Like most I don't use sealer with a gasket. It like using glue on tape. :rolleyes: Greasing a gasket means no scrape when removed and likely to be re-used when coming off in one piece. I've used #2 grease on all fiber gaskets since the '60s and do to this day on thermostat housings, carb bases, cyl bases, primary covers, water pumps, and others we DIY.
One exception has been head gaskets where anti-seize is preferred or nothing at all. All my motorbikes and past MX bikes are/were air-cooled and I've had heads off more of them than not.
Piloon, thanks for the BB transfer tip! :thumbsup: I have to cut a head gasket for a 2 cyl compressor head. Taper of the bolt holes confounds precise location for them, and when greasing the part (like inking it) I didn't get a great transfer onto gasket stock. It's easy to cut out for the reeds, not so much to 'locate' for the bolts and not be sloppy about it.
/ Smart Shop tips! #135
I would most likely fumble and the ball bearing would fall into the intake manifold....
/ Smart Shop tips! #136
I organize my drawers into categories. Like in one drawer all types of screwdrivers and other pointy things like drift punches, that sort of stuff. Another has all the measuring stuff like calipers, rulers and measuring tape, various gauges, etc. One is all sorts of abrasives, files, sand paper and other stuff like that. And then another has all the grippy stuff like vice grips, pliers, adjustable wrenches, etc. So I do it like that, just so it's easy to put stuff away to keep organized, open a drawer and toss it in.
I did a similar method but my drawers are heavy plastic "cross-stack" tubs.
You can cross-stack them 3-high and strap them down in the pickup bed.
For example one tub has all my copper fittings, solder, brushes etc, I can take the drawer out and its a tub with everything that goes to the 'job site'.
It's been a couple years now, very happy with how this has worked out.
Van slide out all the bottom tubs and sweep the floor.
Also easily retrieve the socket that rolled under.
516714d1501223079-building-workbench-cross-stack-plastic-workbench_drawerslides_top_done72-jpg
Thread here: https://www.tractorbynet.com/forums...building-workbench-cross-stack-plastic-3.html
/ Smart Shop tips! #137
I really like that setup
Caterpillar 345B/BL Excavator Vol. 1 and 2 Service Manuals (A63117)
Caterpillar...
2006 FORD F-150 XL TRITON EXT CAB TRUCK (A64276)
2006 FORD F-150 XL...
1998 KENWORTH W900L 6X4 TANDEM AXLE SLEEPER TRUCK TRACTOR (A59912)
1998 KENWORTH...
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
2006 FREIGHTLINER COLUMBIA T/A 6X4 DAYCAB TRACTOR TRUCK (A59912)
2006 FREIGHTLINER...
2020 ISUZU NRR 4X2 S/A 22FT BOX TRUCK (A59912)
2020 ISUZU NRR 4X2...
