two_bit_score
Super Star Member
- Joined
- Dec 22, 2008
- Messages
- 12,679
- Tractor
- John Deere 110 TLB, Diamond C 19LPX GN trailer
A bit of a (meandering) update.
I've hit it with a center punch to attempt to start a dimple..... the punch got blunt on me.
I've tried to drill on it.... perhaps I'm expecting too much too soon.... but the bit didn't scratch the "bolt"
I've banged on it with a chisel to try to budge it. After all, I KNOW it's not in much of a tension mode since it simply tightens into the pin.
I've heated around it (only have MAP gas)
I said I've sprayed it with Penetreat.... I got that screwed up. I sprayed my LOGS on my home with Penetreat..... I used PB Blaster on this.
Oh, and I like the ice idea! I have tried heating around it and then squirting PB Blaster directly on the bolt hoping that would do what (I think) your suggesting the ice to do.
I don't have the fix kit yet to rebuild the cylinder so I'm still on "down time" but right now, this thing is nothing more than a yard ornament in the front yard and you might imagine what the wife is starting to say.....
Also, things to do around here and I can really use the bucket.
I'm chasing my tail right now. Know a guy with a fabrication shop several miles down road. He said he could come by and do it.... then h as disappeared and I hear crickets.
My wife's brother has a welder AND he's coming here (from New Orleans).... I thought this weekend but it might not be for two more weeks.
So I debate all that verses just buying something and moving on. I found a stick welder but I concluded it wanted to be plugged into a 50 amp circuit. I don't have one of those and am unsure the issues of putting it into say a 30 or 40 (I have several open slots in my garage and can add one quite easily, in fact, I probably already have some breakers laying around)
Got to thinking just this morning..... can I go RENT one!!?? Then I again, chase my tail.... money to rent verses a bit more to just buy.....
If I don't get something done soon, this might turn into the Pallets in the Field thread.....![]()
If you have your BIL coming just call and ask him what kind of welder he wants to use when he gets there. Then get one. Probably a 110 Mig I would think.
In the mean time work on cutting that slot and trying to work it out.
Good Luck. Sounds like a really aggravating problem.
