Blowing white smoke
/ Blowing white smoke #21
I'm with those that have suggested doing a compression check. As I work for a diagnostic tool company, everyday I see users of our tool pour money into parts that were not part of a problem. Fatjay, as you are fellow Pennsylvanian living on lock down as am I (I'm from Ambler), I would invest in a compression guage and learning how to use it. That would eliminate problems with the pistons and valves.
The fueling issue can produce white smoke but usually when fueling problems occur in a gas engine, the engine does not run well. Often white smoke when it's a fueling issue would come out the the exhaust because the engine is running very lean.
I'm not saying you won't use your gaskets, but the pressure build-up in the crankcase - that is the concern.. Didn't you write that the oil check dip stick and the oil cap blew off? I think the compression check is the way to go. Find why the engine pressures are not right. Remember, an engine is nothing more than an air pump. It sucks the air in and it has to blow it out. If the air cannot go to the exhaust port, then it goes somewhere else... The question is what is causing the diversion.
All that's worth repeating. I think you might have two problems - one being that a stuck float loaded your crankcase with gasoline...and the other being that it seems (from the sound) to be low on compression. I'd change oil, drain the old gas & put in new, check the carb for a stuck float, clean the spark plugs and check the plug wires to make sure you aren't losing spark (take picture of the dirty plugs first). Now try running it again to see if it makes a difference.
If that doesn't fix it, I'd consider ordering a screw-in compression gauge, because the problem is deeper.
rScotty
/ Blowing white smoke #22
Why would you not do a compression test? Your local auto parts store probably has a loan program for the tester. If I remember right this is a flathead engine. Should be easy to see if the valves are going up and down.
/ Blowing white smoke #23
That's a fair question. And my answer is ....Well, if it was me I would. But that's probably because I have a compression gauge kit handy. I like to use it because it's a beauty with half a dozen different spark plug thread adapters in a red fitted case, and I am always looking for a chance to use it or loan it out. I remember when I bought it.
But I didn't have that tester so handy, it would be an hour into town and another back on the off chance I could borrow one - although I agree that poor compression stands a 50/50 chance of being where this will end up. But why start there?
Anyway, I used to have a mechanical shop and caught my share of calls like this one. So now when writing for the OP I try to give a choice of ideas that anyone can do immediately with simple tools. Most people can unscrew a spark plug and lay it on the head to see what the spark looks like when the engine is cranked. The condition of the spark plug might tell something as well. If the problem is a stuck float and gas has been leaking to the crankcase then an oil change will solve that and the smell of the thinned down oil is something the OP will notice.
It could be that the gas is very old or has water in it or the tank. That's why to change the gasoline.
I don't see the problem as being a head gasket when a flathead air cooled engine runs and smokes like that.
Then there's that peculiar "soft" sound as it runs. That is an odd sound. But that could well be a case of having worn and very retarded timing. I didn't mention that and should have. Timing is hard for a novice to adjust, but in this case he might not have to do so. Just rotate the engine by hand and measure the opening of the points, knowing as we do that as the points follower naturarally wears on the points cam the effect will be to ****** the timing. To fix that, adjust how much the points can open so that at full open they are between .012" to .015" ......which is about the thickness of a match book cover = close enough.
If the problem is retarded timing that will make enough of a difference to be instantly noticible.
rScotty
/ Blowing white smoke #24
Hole in a piston
Rings broken
Sucking engine oil in the intake manifold. (leaking gasket, loose manifold)
Check each spark plug for oil soak.
A very significant fault for sure.
/ Blowing white smoke #25
Hole in a piston
Rings broken
Isn't that bad . . . check the head gasket and go on from there if needed.
/ Blowing white smoke #26
If it's air-cooled it's not a head gasket. More like ignition cross firing to another cylinder inside the distributor cap.
Man that thing sounds like it was designed for the movies or TV like Green Acres. Put it for sale on Ebay, make sure to explain how it was built for 60s TV show, you'll make a fortune.
And the answer is... hole in piston! Time to get on the internet and see about doing a diesel repower. Everything else is great so why not. There's a 24hp kubota diesel for $900 not far from me, just going to have to take some measurements to make sure it fits.
/ Blowing white smoke #28
The mystery is solved. That's not a bad price for a 24 hp Kubota diesel. Your old Wisconsin engine probably has some salvage/parts value.
/ Blowing white smoke #29
Lots of internal crankcase pressure there, has to blow out somewhere.
/ Blowing white smoke #30
My initial diagnosis was spot on! (I have seen this before in 5.8 Litre Ford F series)
Looks like the head gasket was blown between those 2 cylinders as well.
I see your inlet manifold is broken as well.
Time for that new donkey....
The gasket is fully intact, it's just the metal clip that goes on the perimiter. I'm not sure if it creates the seal though.
Challenge is the kubota is 22" long, and having to be horizontal, I only have 21" to play with. I need to get the old motor out and see what's what first though.
Brought home a kubota v1200 28hp motor to replace my previously tired and now broken vh4d in my bobcat. Let the fabrication begin!
/ Blowing white smoke #34
Nice! Keep posting your progress!
/ Blowing white smoke #35
Also, please let us know what you will do in your spare time.
Tried to pull the drive sheave today. Wasn't very successful. Made a special puller for it. Ended up shearing the bolt in the sheave.
/ Blowing white smoke #38
If you didn't have bad luck, you'd have no luck at all.
Well, that didn't work. got 1/2" steel, tapped the angle iron for half inch, snapped thte bolt, welded a new bolt on, destroyed the threads, drilled it out even bigger and put my real puller behind it, impact wrench, bent the mfing angle iron. Pretty soon it's going to meet my big sledge. I also put a torch on it for 10 minutes before each attempt.
/ Blowing white smoke #40
If it is being that stubborn I would use a channel or better yet 3 plates welded into a channel shape where the bolt goes thru to eliminate twisting in the puller. Probably a 3/4 bolt too. Oh, and more heat!
New/Unused Quick Attach Skid Steer Brush Cutter (A61166)
New/Unused Quick...
(APPROX.100) 23"X95" EXPANDED METAL (A62130)
(APPROX.100)...
VAN'S 300 GALLON-50' SPRAYER (A62130)
VAN'S 300...
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
2007 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A61568)
2007 Dodge Ram...
JOHN DEERE 6105E TRACTOR (A62130)
JOHN DEERE 6105E...
