rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,884
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
I'm with those that have suggested doing a compression check. As I work for a diagnostic tool company, everyday I see users of our tool pour money into parts that were not part of a problem. Fatjay, as you are fellow Pennsylvanian living on lock down as am I (I'm from Ambler), I would invest in a compression guage and learning how to use it. That would eliminate problems with the pistons and valves.
The fueling issue can produce white smoke but usually when fueling problems occur in a gas engine, the engine does not run well. Often white smoke when it's a fueling issue would come out the the exhaust because the engine is running very lean.
I'm not saying you won't use your gaskets, but the pressure build-up in the crankcase - that is the concern.. Didn't you write that the oil check dip stick and the oil cap blew off? I think the compression check is the way to go. Find why the engine pressures are not right. Remember, an engine is nothing more than an air pump. It sucks the air in and it has to blow it out. If the air cannot go to the exhaust port, then it goes somewhere else... The question is what is causing the diversion.
All that's worth repeating. I think you might have two problems - one being that a stuck float loaded your crankcase with gasoline...and the other being that it seems (from the sound) to be low on compression. I'd change oil, drain the old gas & put in new, check the carb for a stuck float, clean the spark plugs and check the plug wires to make sure you aren't losing spark (take picture of the dirty plugs first). Now try running it again to see if it makes a difference.
If that doesn't fix it, I'd consider ordering a screw-in compression gauge, because the problem is deeper.
rScotty
