Snow Plow, How Big?
/ Snow Plow, How Big? #21
Same here. We got a light snow on Saturday. Didn't stick, ground was too warm. We haven't even had spring yet, let alone summer.
I can wait for winter.
:D
/ Snow Plow, How Big? #22
My vote is 8 foot. I always find anything less a problem when angled
Andy
Better if the whole plow flops over or if the bottom section just kicks back?
Looking for 7.5 or 8, leaning 7.5
Some good deals out there but I don't want to drive 6 hours, if you know what I mean.
/ Snow Plow, How Big? #24
Mine is bottom trip but that wasn't a selection that I made. It just happened to be what was available. It helped keep the mounting frame higher. That helps eliminate dragging the frame on the driveway. Paul Short has a video where he mentions he had to add an extra pair of skid shoes to eliminate gouging the blacktop with the frame. I've only hit a couple things with it and the moldboard remains in the plowing position. I'm guessing that you'd be more likely to ride up over the snow if the whole blade flipped.
Nice rig.
Tempted to get a frame with lights.
Do not know if a frame with lights would work though.
/ Snow Plow, How Big? #26
The first year we were at the new house with new tractor, I borrowed a plow from my father. A 9ft Western Pro. Attached it to a QA plate via welded on tabs and away I went. I have loaded R4s, very flat asphalt drive, but still could push 18" of powder or 12" of wet snow. 6" of heavy slop would stop or slide me around though.
I rebuilt an old Meyer 7.5ST to replace the Western. Replaced the springs (only two) and did some welding to patch and repair some cracks. A new cutting edge is the only real expense. Plow was free. Just had to haul it away. It plows well, but I miss the wide swath that the 9ft plow made.
You guys should be tripping over old Fisher plows up there.
Some old preacher in the 18th century, begging to be brought back to Massamachusetts said about Maine that it was a 'God forsaken land of God forsaken people.'
I love it until it gets too cold.
Just trying to get the plow right, 7.5 to 8', not too heavy a setup but not lightweight either. Hydraulics and maybe lights on a stick.
/ Snow Plow, How Big? #28
Mine is also a bottom trip (like Chims setup) and is 7 1/2'. I ran hydraulic lines from one rear remote to the front to operate the angle.
You mention lights on a stick? If you mean lights on a stick mounted to the plow blade I think that is a bad idea. I've seen lights mounted or attached to the plow and the vibration while plowing shook the bulb filaments loose. Mount your lights to the cab or ROPS.
Yes, planning on running a line from the rear remote.
Agree with your conclusion that the vibration from the plowing will kill the plow frame mounted lights.
Thanks
/ Snow Plow, How Big? #30
There are a couple of threads on here about making an under slung mount for a front plow on a loader frame it shortens up the package nicely and takes a lot of the bounce out of the plow setup.
I have a SSQA plow and it sticks out a long ways in front of the tractor,
I believe I would have been happier with an under slung truck plow setup.
about a 9ft V would be nice.
View attachment IMG_20171108_144953167.jpgView attachment IMG_20171108_144913379.jpg
/ Snow Plow, How Big? #31
.........................and maybe lights on a stick.
I played around with lighting on a total of 5 different tractors over the years and the only setup that has worked on more than one tractor has been worklights mounted high on the cab. Factory headlights haven't worked well any time I had something mounted out in front of the tractor.
View attachment 657457View attachment 657458
Yes, what I have sort of. Does the job but one nasty set of storms a few years ago got me to thinking there has to be a better way.
Got a set of Ghetto Blaster LED's on the Ford, just under the overhead cover, gonna do that again. A smaller set for the rear as well.
/ Snow Plow, How Big? #33
As any of us that use a loader in darken conditions can tell you, lights in the tractor grille are much less than functional with raising the loader arms.
Many of us (self included) have tried mounting lights on the loader in some manner with disappointing results. These work well (LEDS) while the bucket is low working, but if wishing to dump a bucket load in a trailer, well you get well lit tree branches.
Just a bit of word pictures to encourage you to put your lights higher (ROPS or cab mounted) and use multi sets or spots and floods to give good work area coverage.
Fender mounted seem to do ok toward the rear as you lift height is much less to see around, but if possible higher mounting works well there also.
Well, slow as all get out but finally decided and ordered.
Tried to order earlier but out of stock, locally $1,000 more.
Also tried to buy one to fabricate, no luck getting what I wanted.
/ Snow Plow, How Big? #35
Looks good from the photos. The blade is also nice and close to the ssqa attachment point, which is a plus.
Be sure to post a review after some use!
/ Snow Plow, How Big? #36
Super price. I've seen 72" manual plows go for that.
/ Snow Plow, How Big? #37
We didn't get squat this year. Some Winters are really mild, some are more like the real thing and occasionally we get hammered. The last tractor had a rear blower that was fun, but really slow. That was the reason behind going with a blade. It is easier to use and much faster than the blower. I do a couple parking lots at our church, and the front blade has been the best snow removal tool so far. The tractor has plenty of grunt and the grooved tires give it traction. We had a few light snows this past Winter, and I used it without anything on the 3PH. It did OK, but a counterweight is on the list before next Winter.
Post 652 below is from the Winter 2018/2019 and at that time the L4240 was carrying the rear blower that was really for the L3200 we sold earlier this year. Early in the season I snapped a shear pin on the blower. It only takes about two minutes to replace the pin, but the blade worked so well I didn't replace the pin and just kept the blower on for rear ballast.
Snow Equipment Owning/Operating - Cutting / Groving / Siping R-4 for snow
We have been pretty dry this winter in NM and AZ. Snow in the mountains, but not much elsewhere. We had a 5” snow around New Years, and got another 5” last night. Still snowing but I doubt we’re going to get a big dump.
Wish I was in AZ about now, not in the beautiful mountains either, down in the flats with the illegals, scorpions, tarantulas and gila monsters. :cool:
Received the plow, still on the pickup, in the shipping frame, looks good..
Hoses were crushed, called Titan Attachments, parts are on the way.
Actually, might just use the quick release ends and fab up hoses, 3rd function is in the rear. long hoses.
Need to check hydraulic fluid level.
Still undecided on the counterweight. Counter Weight for Snow Plow
Will post pic(s) when it is together and a follow up on how it works.
/ Snow Plow, How Big? #40
I've worked in a bunch of states, and a couple extra countries too. I have often got the response: Maine? isn't it too cold in the winter? I always tell them: If it wasn't for the cold, we would never get you out-of-staters to leave after Labor Day, but now Covid hits and they're even staying here throught the cold :(
NEW Landhonor Diesel Fuel Transfer Pump (A62679)
NEW Landhonor...
2007 International 7500 sba Flatbed 6x6 Truck (A62679)
2007 International...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Mini Skid Steer (A60352)
Mini Skid Steer...
(1) 20 Yard Roll Off Dumpster and (1) 30 Yard Roll Off Dumpster (A65579)
(1) 20 Yard Roll...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
