Well pump/generator question
/ Well pump/generator question #1
1930
Brandon/Ocala Florida
Kubota B6100E Kubota L 2501 Kubota T1460
Can someone tell me which side of the generator I should be plugging in my well pump. Id assume the left. That where I get the power for my camper a/c.
/ Well pump/generator question #2
It depends on the voltage your pump uses. 120 or 220 and the amps it pulls
No idea. 1.5 h.p pump. I was told 220. No booklet no nothing
/ Well pump/generator question #4
For that size pump, 220V makes sense, Wire colors for a three wire Pump are usually Red, Yellow and Black. Two wire Pumps have a Red and a Black. If you have a Yellow and a Red, you have probably not yet located the Black wire. It may be broken off in the Well. So chances are you will have to pull the Pump to make repairs anyway.
I hope this helps
Only 2 wires and a ground attach to pressure switch
/ Well pump/generator question #7
Control box is for 220V....
AIM Manual - Page 54 | Single-Phase Motors and Controls | Motor Maintenance | North America Water | Franklin Electric
Will wire to the 220 Volt twist lock on generator.....
You will need a L14-30P (plug) for end of cord at generator...
You will ignore White Neutral and just connect to Line 1 and Line 2 and safety ground...
Pressure switch it should just be wired in series between generator and pump controller...
index.php
IF you don't have complete understanding of this, get help....
Dale
You will ignore White Neutral and just connect to L1 and L2 and safety ground...
Dale
Ok so outlet on the right. I was wrong.
Ignore the neutral. Thank you for the help
Very little signal. If it hadn't been for dl I wouldn't have water. Above and beyond. Have no idea how much appreciated
/ Well pump/generator question #11
If there is still a question, look in your circuit breaker panel. If the breaker powering your well pump is a double breaker, then your pump is 220V/240V
/ Well pump/generator question #12
If you can't figure out the voltage to your pump and don't have a cheap VOM meter you shouldn't be messing with a generator. Get some help.
12V YARD SPRAYER (A64278)
12V YARD SPRAYER...
2024 FORD F350 4X2 CREW CAB & CHASSIS PICKUP TRUCK (A67148)
2024 FORD F350 4X2...
2012 HINO 268 4X2 S/A BOX TRUCK (A59914)
2012 HINO 268 4X2...
2019 Ford F-150 4x4 Pickup Truck (A64556)
2019 Ford F-150...
2005 SUPERLINE DO20T192ALP T/A 20FT TRAILER (A66091)
2005 SUPERLINE...
2005 Anderson 24ft T/A Dovetail Tag Trailer (A64556)
2005 Anderson 24ft...
