MF GC1720 Hydraulic issue
/ MF GC1720 Hydraulic issue #1
bbradley57
Mount Crawford,VA
MF 1720 TLB
I just changed the fluid and filter now the engine is under a strain...when I cycle bucket it smooths out...stop cycling bucket and it goes back to straining.... ???
Got it....hooked up hydraulic lines to 3 point hitch...cycled it a few times...Bingo ;)
Hooked backhoe up and all is well in Massey land !
/ MF GC1720 Hydraulic issue #3
Good to know, I will be doing the same soon.
/ MF GC1720 Hydraulic issue #5
Had me worried ! I guess the system has to make that loop !
Yes, or you are deadheading the pump.
Which means the fluid has no where to go.
In the future, you should post these kinds of questions in the Massey Ferguson owning and operating forum. That's where all the GC owners are.
If they see your question faster, you may get help faster.
/ MF GC1720 Hydraulic issue #7
Yes, BH is in between PB port of FEL and 3PH.... With out BH connected or hoses being "looped" flow is restricted (non existent) ....
Dale
Dale,
When you loop the flow with BH off, does it matter which female you use with the male? There is two female and one male. I think one and red and the other blue zip ties.
/ MF GC1720 Hydraulic issue #8
Dale,
Yes.... One female is for 3PH and one female goes to "tank".... Connect one combination up if 3PH does not work, switch combination....
Image is backhoe side, but it should be instructive....Once you have correct combination mark them for future...
Dale
/ MF GC1720 Hydraulic issue #9
Dale
Thank you! Very helpful!
/ MF GC1720 Hydraulic issue #10
Welcome to TBN,
If you have a Backhoe Operators Manual, refer to the section "Detaching Backhoe from Tractor", that should explain this very well a long with pictures.
On my GC2410, the "Sump" hose (tank hose) that is left with only the dust cover attached when the backhoe is off comes from the area just below the Hydraulic fluid filler neck is located.
KC
2024 Bobcat T740 Track Loader (A63109)
2024 Bobcat T740...
RIDGID AIR COMPRESSOR (A63569)
RIDGID AIR...
2019 F150 (A61306)
2019 F150 (A61306)
Coyote Renegade Trailer (A63116)
Coyote Renegade...
2021 Jayco Jay Flight 32BHS Camper (A62613)
2021 Jayco Jay...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
