2017 LS xu6168 Loader issue
/ 2017 LS xu6168 Loader issue #1
jivey30528
LS XU6168
I have an LS xu6168 with a loader. The loader will raise but stop at about 5 ft. It will not raise any further and sounds strained when I try to get it to raise higher. No issues lifting things that are heavy. I have a grappler that opens, closes and tilts with no issues. The loader will not lift the front of the tractor any longer. Checked fluid levels and they are fine.
/ 2017 LS xu6168 Loader issue #2
Check the quick disconnects. Most likely one for the lift cylinders popped out and it's doing what you describe. Don't just look at them, go ahead pull a bit on the hoses as some quick disconnects may look like they are connected but they aren't.
