MF GC1720 Hydraulic issue
   / MF GC1720 Hydraulic issue #1
bbradley57
Mount Crawford,VA
MF 1720 TLB
I just changed the fluid and filter now the engine is under a strain...when I cycle bucket it smooths out...stop cycling bucket and it goes back to straining.... ???
Got it....hooked up hydraulic lines to 3 point hitch...cycled it a few times...Bingo ;)
Hooked backhoe up and all is well in Massey land !
   / MF GC1720 Hydraulic issue #3
Good to know, I will be doing the same soon.
Had me worried ! I guess the system has to make that loop !
   / MF GC1720 Hydraulic issue #5
Yes, or you are deadheading the pump.
Which means the fluid has no where to go.
In the future, you should post these kinds of questions in the Massey Ferguson owning and operating forum. That's where all the GC owners are.
If they see your question faster, you may get help faster.
   / MF GC1720 Hydraulic issue #7
Yes, BH is in between PB port of FEL and 3PH.... With out BH connected or hoses being "looped" flow is restricted (non existent) ....
Dale
Dale,
When you loop the flow with BH off, does it matter which female you use with the male? There is two female and one male. I think one and red and the other blue zip ties.
   / MF GC1720 Hydraulic issue #8
Dale,
Yes.... One female is for 3PH and one female goes to "tank".... Connect one combination up if 3PH does not work, switch combination....
Image is backhoe side, but it should be instructive....Once you have correct combination mark them for future...
Dale
   / MF GC1720 Hydraulic issue #9
Dale
Thank you! Very helpful!
   / MF GC1720 Hydraulic issue #10
Welcome to TBN,
If you have a Backhoe Operators Manual, refer to the section "Detaching Backhoe from Tractor", that should explain this very well a long with pictures.
On my GC2410, the "Sump" hose (tank hose) that is left with only the dust cover attached when the backhoe is off comes from the area just below the Hydraulic fluid filler neck is located.
KC
UNUSED WOLVERINE PFF1-13-45W PALLET FORK FRAME (A54757)
UNUSED WOLVERINE...
BUSH HOG 2820 LOT NUMBER 125 (A53084)
BUSH HOG 2820 LOT...
2002 CATERPILLAR 938G WHEEL LOADER (A51406)
2002 CATERPILLAR...
APACHE 24' LIVESTOCK FEEDER (A54756)
APACHE 24'...
30pc. 16ft.x 3ft. White Metal Roof Panels (A55758)
30pc. 16ft.x 3ft...
Plasmarc PM150 Plasma Cutter (A54811)
Plasmarc PM150...
