Battery powered grease gun recommendations?
/ Battery powered grease gun recommendations? #81
Does anyone have an idea about the likelihood of that hose blowing up in your hand if the zerk is plugged and you have to really crank down the full 10,000 psi? I had a friend experience that with a pneumatic years ago. Nothing I would want to see again.
I can see the value of the Lock-N-Lube preventing that because you shouldn稚 have to hold the hose after you lock it on. But if you were holding it could that hose blow out. Haven稚 seen this mentioned.
I have had the plugged zerk experience. On the Dewalt there is a pressure relief valve set at about 10,000 psi and grease will come out of that if it won't go into the zerk.
A hose on a grease gun has almost zero volume,, so the high pressure times the volume,, still equals almost zero.
It takes a lot of volume to store energy when compressing a liquid. There is no volume in the tiny hose,,,:eek:
It is like comparing an air compressor tank exploding to a fart,,
both have pressure, the fart has less volume, and less pressure,,, :laughing:
Ya, liquids transmit energy but dont store it. Compressed air is a huge coiled spring waiting to kill you. Grease not so much. Hydraulic leaks are scary, but only when under continuous pressure.
My Dewalt has a relief valve I've popped a few times on a few stuck zerks. Messy as some grease oozes out, but not dangerous.
10,000psi is scary, but the hose is so small there is less total force. It's much easier to make small hoses strong than big ones.
/ Battery powered grease gun recommendations? #84
In 2004 I was about to buy an air compressor grease gun when a friend suggested a battery operated one in lieu of less effort with the air tank. I bought a Lincoln...I believe it to be 16 years old now. I paid $200 for it new and it works very well. I only use it maybe 2-3x a year (1 1/2 tubes average) It has a rechargeable battery. It is a pleasure to use.
/ Battery powered grease gun recommendations? #85
About 40 years ago I had my son in law working for me on a heavy equip. construction job. After the shift was over he would stay late and service all the equipment. One evening he was greasing a FEL and someone had removed the spring that comes on all the flex. grease hoses I've ever seen. He got to a particularly tough fitting and had his hand tightly on the hose when it blew out.It injected his hand full of grease in a second. Luckily we were pretty close to a large hospital and I took him to the E.R. . They called in a specialist who told us that if we hadn't taken him in as soon as we did he could have easily lost his hand. As it was he spent 2 or 3 days in the hospital and never did regain full use of his left hand.
Power grease guns are potentially dangerous and you should always be sure that the spring on the outside of the hose is in place. This is another case where the Locknload could have prevented a serious injury but we had never heard of them back then.
/ Battery powered grease gun recommendations? #88
I am very happy that I bought the Ryobi 18 vt grease gun a few months ago! I have added an extra hose and the Lock & Lube XL long reach and it is very easy to use -- I keep everything well lubed now (quieter FEL, etc.), mostly with the highly rated "virtually waterproof" Lucas 10301 Extra Heavy Duty Grease (green). I found, after removing the zerk grease fitting plastic cap &/or cleaning the zerk tip with a rag, it sometimes is helpful to push the zerk ball bearing in just a touch (1/32") with a small HFT probe/pick to insure it isn't stuck shut. The youtube reviews agree with my experience: Make Greasing Easy Again - Ryobi P341 18V Grease Gun - YouTube
/ Battery powered grease gun recommendations? #89
Deal alert: Milwaukee grease gun
Went to Home Depot to buy m18 grease gun finally, they wouldn’t price march from nearby Acme Tool Crib (missed store hours by 5 mins). So looked online and found it $20 cheaper on Amazon. Not a big fan of online vs local, but HD made that decision easy. Lowest price on the grease gun in a year.
/ Battery powered grease gun recommendations? #90
Great! What was your final cost?
/ Battery powered grease gun recommendations? #91
I have a bunch of Ryobi 18V tools and batteries, so I got the Ryobi grease gun when it came out. I got a LockNLube and added an extension hose. Works well. I like to keep a grease gun in a tool box with some extra grease cartridges. This gun was too long for a regular size toolbox, so I found a Husky brand 26" toolbox at Home Depot.
/ Battery powered grease gun recommendations? #92
I found one unexpected consequence of the Lock-N-Lube and a plugged zerk; I couldn't remove the tip because of the pressure build-up. The DeWalt tool has a pressure bleed screw that did the trick, but it was surprising to try to release the Lock-N-Lube lever and find that wasn't happening!
/ Battery powered grease gun recommendations? #94
$164.98 (prime, ships ‘free’). HD had it at $199. This is for bare tool, I have a few others and didn’t need the battery kit.
/ Battery powered grease gun recommendations? #95
I have the 20-volt dewalt with the lock-n-lube on it, I love it.
/ Battery powered grease gun recommendations? #97
$164.98 (prime, ships �*ree?. HD had it at $199. This is for bare tool, I have a few others and didn� need the battery kit.
I think that was a good price.
I watched, and watched, and bought the DeWalt on E-Bay (with hard case), last Fall for $124.95 and no tax.
Haven't used it yet.
/ Battery powered grease gun recommendations? #98
I have what the OP wanted, a grease gun that runs on Ryobi batteries.
I acquired a used Lincoln grease gun, from a tool repair shop that I was working part time for. It had some minor damage to the case, but only really needed new batteries.
I cut the battery receptacle off of an old Ryobi flashlight, (the kind of flashlight you get when you buy a kit with several tools). The light just happened to be the original Ryobi blue color, which was similar to the blue on the Lincoln grease gun.
I cut off the part of the original handle on the grease gun that held the battery, and sanded the Lincoln battery holder until it fit inside far enough to glue it.
After soldering the power wires, I glued the two parts together with some JB Weld.
This left me with an almost undetectable hack. It looked so good, I took it to the tool repair shop and said, "Hey look, these Ryobi batteries fit on this Lincoln grease gun"!! Had them going with that for a while. :D
Even though the tool originally had 14.4volt batteries, I have run it on my 18 volt batteries for many years. It works just fine.
I can highly recommend the Lincoln grease gun, even without the Ryobi batteries. :thumbsup:
/ Battery powered grease gun recommendations? #99
/ Battery powered grease gun recommendations? #100
You know, I have a grease gun that took some kind of 12 or 14 volt batteries that I picked up off the side of the road. I also have various Ryobi flashlights and stuff that could probably be sacrificed for such a cause...
Aaron Z
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
2007 International 7500 sba Flatbed 6x6 Truck (A62679)
2007 International...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
