Repower DR chipper shredder
/ Repower DR chipper shredder #1
yardtime
Simplicity legacy. Wheel horse work horse
Need to replace the motor on my chipper . It is a Briggs 800 series . Having a heck of a time locating specs for shaft size , key way etc.. The model numbers on the valve cover does not bring up any luck on all the sites I致e tried . Also can稚 tell if it has gear reduction or do I really need it. The unit belonged to my father-in-law who passed five years ago . The chipper model Is CST 800. Looking for advice on what motor I can put it . Trying to stay low on cost , a new comparable chipper is around $800 . Wouldn稚 be cost effective to spend more than $300 on a motor . I have over five acres so I burn too and chipping/mulching is more of a convenience.
Thanks .
/ Repower DR chipper shredder #2
Have you tried contacting DR directly, they should have those specs, and probably have replacement motors. Good luck
/ Repower DR chipper shredder #3
You can pull the engine off and measure the shaft size . Hf sells cheap engines ...
/ Repower DR chipper shredder #4
X2
"One measurement is worth 1000 expert opinions."
If the output shaft does not align with the crankshaft it has a reduction gear.
So I called dr and they could only give me key way specs , 1/4 x1 1/2 . I’d like to go with an hf motor, cost wise , but it looks like it is too short and squat hitting the mulched hopper chute . I may be stuck with a Briggs replacement. $$$
I checked out the hf motor . I think the 3/4 shaft is a match but the key is 3/8 . Everywhere I turn I may be stuck with $$$$
/ Repower DR chipper shredder #7
Thanks .
Could you post the model type and code from the engine and I will see what I can find for specs. Should be located on the side of the valve cover.
/ Repower DR chipper shredder #8
If it will work just get a new pulley with the correct key way size.......
/ Repower DR chipper shredder #9
Where are you located I can get honda motors at cost.....
It’s an 800 series model #
1263 12 0141 B8
I think the code is
100 805 88
I live in East haddam ct .
Thanks all , you’re awesome with the responses !
/ Repower DR chipper shredder #12
It痴 an 800 series model #1263 12 0141 B8 I think the code is 100 805 88 <snip>
The cynic in me suspects that DR (a marketing company) uses enough B&S motors that DR can get B&S to make them to some non-standard spec so DR captures the parts market or can sell more machines when critical parts are unavailable. Have you considered repairing the engine? Internet small engine parts stores can be helpful in finding parts.
/ Repower DR chipper shredder #16
Don't know if this helps or not...
From here:
BRIGGS AND STRATTON 699585 SHORT BLOCK MODEL 12 HORIZONTAL | Lawnmower Pros
Product Description
- Horizontal Shaft
- Uses Crankshaft 699451
- 1" x 2-7/8" with Keyway, Drilled & Tapped 3/8-24
- Mechanical Governor
- Bearing PTO Side: Plain
- Bearing Magneto Side: Ball Bearing
- Pressure Lubrication
- Notes: Supercedes 696316
- Notes: Sleeve Bore
- Includes gaskets needed for short block change over
/ Repower DR chipper shredder #17
You have any pictures of it ? And is it a gear reduction motor ?
I’ll have to take the drive belt and centrifugal clutch off and see what I come up with an actual measurement . Moss road and all sent me some good info . I could have sworn it was a 3/4 shaft till I got everyone’s input. I’ve spent a ton of time online searching and you guys got me a lot further in just an afternoon.
/ Repower DR chipper shredder #19
Its not a gear reduction with a centrifugal clutch, If you can get me the shaft size and hp I can get you a price on a honda....
Hi peter , gear reduction was an option that it may or may not have . It looks like it doesn’t because I don’t see a filler plug for that .
New/Unused 7ft Double Chain Sling (A65583)
New/Unused 7ft...
Schulte SBW800 Rock Windrower (A63118)
Schulte SBW800...
Rut MFG Mini Excavator Brush Cutter (A64126)
Rut MFG Mini...
Land pride RCR1860 (A64126)
Land pride RCR1860...
Two (2) John Deere 4000-Series Tractor Grill Guards (A65640)
Two (2) John Deere...
2017 CATERPILLAR 950GC WHEEL LOADER (A65053)
2017 CATERPILLAR...
