Repower DR chipper shredder
   / Repower DR chipper shredder #1
yardtime
Simplicity legacy. Wheel horse work horse
Need to replace the motor on my chipper . It is a Briggs 800 series . Having a heck of a time locating specs for shaft size , key way etc.. The model numbers on the valve cover does not bring up any luck on all the sites I致e tried . Also can稚 tell if it has gear reduction or do I really need it. The unit belonged to my father-in-law who passed five years ago . The chipper model Is CST 800. Looking for advice on what motor I can put it . Trying to stay low on cost , a new comparable chipper is around $800 . Wouldn稚 be cost effective to spend more than $300 on a motor . I have over five acres so I burn too and chipping/mulching is more of a convenience.
Thanks .
   / Repower DR chipper shredder #2
Have you tried contacting DR directly, they should have those specs, and probably have replacement motors. Good luck
   / Repower DR chipper shredder #3
You can pull the engine off and measure the shaft size . Hf sells cheap engines ...
   / Repower DR chipper shredder #4
X2
"One measurement is worth 1000 expert opinions."
If the output shaft does not align with the crankshaft it has a reduction gear.
So I called dr and they could only give me key way specs , 1/4 x1 1/2 . I’d like to go with an hf motor, cost wise , but it looks like it is too short and squat hitting the mulched hopper chute . I may be stuck with a Briggs replacement. $$$
I checked out the hf motor . I think the 3/4 shaft is a match but the key is 3/8 . Everywhere I turn I may be stuck with $$$$
   / Repower DR chipper shredder #7
Thanks .
Could you post the model type and code from the engine and I will see what I can find for specs. Should be located on the side of the valve cover.
   / Repower DR chipper shredder #8
If it will work just get a new pulley with the correct key way size.......
   / Repower DR chipper shredder #9
Where are you located I can get honda motors at cost.....
It’s an 800 series model #
1263 12 0141 B8
I think the code is
100 805 88
I live in East haddam ct .
Thanks all , you’re awesome with the responses !
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
Hydraulic Radiator (A47477)
Hydraulic Radiator...
1996 Elgin Pelican Series S Street Sweeper (A53421)
1996 Elgin Pelican...
2023 54ft Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54ft Hooklift...
golf cart (A55787)
golf cart (A55787)
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
