Repower DR chipper shredder
   / Repower DR chipper shredder #12
It痴 an 800 series model #1263 12 0141 B8 I think the code is 100 805 88 <snip>
The cynic in me suspects that DR (a marketing company) uses enough B&S motors that DR can get B&S to make them to some non-standard spec so DR captures the parts market or can sell more machines when critical parts are unavailable. Have you considered repairing the engine? Internet small engine parts stores can be helpful in finding parts.
   / Repower DR chipper shredder #16
Don't know if this helps or not...
From here:
BRIGGS AND STRATTON 699585 SHORT BLOCK MODEL 12 HORIZONTAL | Lawnmower Pros
Product Description
- Horizontal Shaft
- Uses Crankshaft 699451
- 1" x 2-7/8" with Keyway, Drilled & Tapped 3/8-24
- Mechanical Governor
- Bearing PTO Side: Plain
- Bearing Magneto Side: Ball Bearing
- Pressure Lubrication
- Notes: Supercedes 696316
- Notes: Sleeve Bore
- Includes gaskets needed for short block change over
   / Repower DR chipper shredder #17
You have any pictures of it ? And is it a gear reduction motor ?
I’ll have to take the drive belt and centrifugal clutch off and see what I come up with an actual measurement . Moss road and all sent me some good info . I could have sworn it was a 3/4 shaft till I got everyone’s input. I’ve spent a ton of time online searching and you guys got me a lot further in just an afternoon.
   / Repower DR chipper shredder #19
Its not a gear reduction with a centrifugal clutch, If you can get me the shaft size and hp I can get you a price on a honda....
Hi peter , gear reduction was an option that it may or may not have . It looks like it doesn’t because I don’t see a filler plug for that .
2015 Peterbilt 567 Wet Kit T/A Day Cab Truck Tractor (A55973)
2015 Peterbilt 567...
Jacobsen three wheeler mower (A56857)
Jacobsen three...
12V 20GPM Gasoline Fuel Transfer Pump (New/Unused) (A59225)
12V 20GPM Gasoline...
Hydraulic spike driver (A56435)
Hydraulic spike...
1328 (A58374)
1328 (A58374)
Case 621D (A57148)
Case 621D (A57148)
