Buying Advice New here, would like to bounce some ideas off ya'll
/ New here, would like to bounce some ideas off ya'll #1
taylorblake
NE Alabama
Nothing Yet
Okay, to start with I'm in the process of finishing a tiny house on a piece of property that's roughly 9 acres. All flat land. It was bush hogged last year so there's some growth, but shouldn't be any trees larger than an inch or so in diameter. I would like to have a small garden to feed me and my family and in the future a market garden (maybe an acre or so in size.) I'd like chickens and goats as well.
So here's my question: Should I go with a subcompact package deal from a dealership or try and search around for a used model?
I've noticed used models are hard to find with a FEL and I would need to buy some implements separately (cheaper with a package?)
For the tasks I'd like to accomplish (bush hog, maintain driveway, move dirt around, etc) what size could I get away with?
There's a dealership about 45 min from me that has a BX1880 with FEL, brush hog, box blade, and trailer for $13,500 cash (I'm just afraid that's not enough tractor for me)
Thoughts? Recommendations? I'd like to get out the door for less than $15,000. Am I reasonable with this kind of budget?
/ New here, would like to bounce some ideas off ya'll #2
When I bought my tractor, the dealer was selling an LS XG3125, which is the same as what is now called the MT225E, for 13,800 with the loader. That combination of size, power and price might do what you want. The only drawback is that it has no mid PTO, so if you were planning to use whatever you buy with a belly mower, this might not work. If you have a Rural King near you, the RK24 is in your price range and bigger than the BX (and the same as the TYM T254, if that dealer is closer). But this all depends on what dealers are near you, or whether you have a way to transport whatever you buy and are willing to deal with the hassle and cost a associated with a distant dealer if you need them. Either way, your budget would make me look at things besides Kubota and Deere, which are excellent tractors, but priced accordingly.
/ New here, would like to bounce some ideas off ya'll #3
I suggest you go to a tractor wed site like Kubota and they have the ability to build your own . This will give you an idea of what you can afford new with whatever attachments you might need . Good luck
/ New here, would like to bounce some ideas off ya'll #4
/ New here, would like to bounce some ideas off ya'll #5
/ New here, would like to bounce some ideas off ya'll #6
Jeff9366, is a long time TBN member who ALWAYS admonishes: "BUY ENOUGH TRACTOR"!
It could not be said better!
T-B-N Members are pretty generous with their time helping neophytes find inexpensive tractors.
Help yourself. Add your LOCATION to your T-B-N PROFILE.
Here is a BX2380:
Thanks for the advice, updated my profile. I'm located in NE Alabama
/ New here, would like to bounce some ideas off ya'll #8
For a family kitchen garden a Kubota BX is fine. I recommend more than 18-horsepower for pulling a Bush Hog over seven acres with brush established.
BX tractors are basically for finish/turf mowing and light yard/landscaping tasks. The Loader on a BX is essentially a powered wheelbarrow. If you are serious about a one acre commercial garden 9" ground clearance of a BX will limit you to tractor cultivation of your crop at 9" of height. Tractors with larger diameter tires have 12" or more ground clearance so you are able to tractor cultivate an additional one or two weeks.
A 48" Bush Hog cutting at 3 mph will take about 5 hours 20 minutes to cut 7 acres without a break for a drink, bladder nor fueling. A Kubota B series tractor, with larger wheels/tires which will not drop into every small hole, burrow and rut like a BX, would allow you to mow at 4 mph.
Mowing Calcuator | How many acres can I mow in an hour
Almost everyone finds more applications than expected when the tractor arrives. Many are ready to buy a heavier tractor within one year. Selling a used tractor is easy. Selling multiple light implements in order to buy heavier, wider implements for a new, heavier tractor requires a lot of time. Depreciation on implements is worse than depreciation on a tractor.
MORE: https://www.tractorbynet.com/forums...9-almost-daily-thread-subcompact-compact.html
VIDEOS: Comparing Kubota's 26hp Compact Tractors - YouTube
*NEW* Kubota BX 8 series (BX238, BX188, BX268, BX23s) - YouTube
DO NOT RUSH YOUR TRACTOR RESEARCH.
BUY IMPLEMENTS ONLY WHEN YOU HAVE A NEED, THEN BUY QUALITY, WHICH IS USUALLY PROPORTIONAL TO WEIGHT.
==BUY ENOUGH TRACTOR.==
/ New here, would like to bounce some ideas off ya'll #10
If you can work on your own stuff, buy used. You can score some good deals. I work on all my own stuff so I dont care if there is a local dealer or not. I can order parts online.
I only have 6 acres but have a 48 hp machine. Why? Weight of the tractor for 1 for picking up stuff. It weighs >6000 pounds and I can lift a lot with my loader and 3 point. 2nd, hp to turn a 7ft finish mower. I can mow my pastures in 1 hour with the tractor vs 4ish on a lawn mower
/ New here, would like to bounce some ideas off ya'll #12
When I was shopping for a tractor, the used ones in my area where either old and beat up or nearly the cost of a new tractor. With a new tractor I could get very good warranty and with many dealers offering attractive financing. Dealer support counts for something too if you cannot do your own work. Nearly every used tractor will need some work...at least the ones I found. After 4 months, I gave up on buying used...but that could be a regional thing.
IMHO LS provides a lot of tractor for the $$. But you want to be sure you have a good dealer for support. I thought RK (Rural King) was a reasonable bargain as well but lack of dealer support near me took them off the list.
I started with an old JD855 that I bought from the widow of my friend. It would be about the right size for your needs. In the first few months I put $2500 into it. One thing I learned quickly is size matters. I went way bigger when I upgraded.
Look at your future needs. Both brush hogging and rototilling will require a fair amount of PTO HP. If you decide on a flail mower, look at the HP needs. BTW, I had a BH included with the JD855 and it can be a dangerous implement. It is also large. I sold it when I traded up. If I had to maintain 9 acres I would use a flail for the safety factor. You do not want anyone within 25 yards of a BH when it is in use. Unless you need a groomed lawn, the flail leaves a decent cut. For me a MMM (mid Mount Mower) is a PITA. I had one on the JD and never used it. If you must have a groomed look lawn around the house, a rider like the Husqvarna is about the same price as a MMM.
/ New here, would like to bounce some ideas off ya'll #13
Something to think about. The used market may change in the coming weeks and months. I bought my tractor in 2008 during hard times and got a great deal on a low hour tractor and implements.
/ New here, would like to bounce some ideas off ya'll #14
I have a BX....and I run out of tractor often. It doesnt look like it on paper - but a B is a pretty decent upgrade over the BX. Id recommend that at a minimum.
I also recommend buying used equipment. Ive got lots of equipment, none of it was new. I got burned on nothing and paid mere fractions of new for great low hours equipment. My BX (tractor, loader, backhoe) has 300hrs on it - gave $8800. Does the same work as a new one :)
Only think I can recommend when looking at used equipment - just figure a full service into the cost. You dont know when/what was done to it.....so just plan on doing all the service and plan for that, its piece of mind. I do my own work - so its just the cost of filters and fluids - usually $200 gets it covered until you start buying big equipment.
/ New here, would like to bounce some ideas off ya'll #15
I also have a BX... absolutely love it on my 1.5 acres sloped property with tight spaces. Also love my backhoe even though many call it a luxury. My back calls it a necessity.
That said with 9 flat acres I would be looking at a CUT not a SCUT or even a bit bigger depending on how much of the land you plan to be working on a regular basis. My forks have been maybe my best addition. I have maxed out the lift though on several occasions (pallets half loaded with pavers for example).
/ New here, would like to bounce some ideas off ya'll #16
Garden cultivation, ground clearance is very important. It would seem simple that 9 inch clearance to the ground gives you that in cultivating, not necessary. Most if not all cultivation runs some what farmers call "trail" sweeps. They plow out the tire tracks to not leave ground packed for weed seeds to sprout. As you do so the furrow the tractor runs in tends to get lowered while often the dirt is moved by the plows often called sweeps to form or enlarge the row or bed the plant is growing on. So not only is the plant growing and often much faster than you realize but the ground the tractor is on is getting lower.
Sometimes farmers in cultivating a crop taller than they wish will run a heavy plastic under the tractor to give the plant a smooth surface to slip on and help prevent tearing.
"IF" you really plan on having a large production garden (what large is depends on your time and crops) you really might do well to look for a really old style farm tractor made for cultivation. At same time if you are the design and build it yourself and have the equipment look at the old style cultivator tractor style that is much like a zero turn mower minus the deck. Look up Allis Chambers Model "G". There were some others and yes there are some of this still out there. Had one locally two years back for sale. Not speed demons but great design for cultivating. Now if your large garden is corn and potatoes not near as much need for a good cultivation tractor. Just run big sweeps "fast" and throw the dirt.
For a garden, herbicides are not as easy to use as some think. You often had such a variety of crops planted in small area you will find it hard to find a herbicide that is really safe to use effectively.
Like your vision!
/ New here, would like to bounce some ideas off ya'll #17
The BX18ish has enough hp but is lacking turning brakes and clearance. I'd go to a B.
My first tractor was a JD 2 series 18.5 hp. First job I did with it was to haul 22 tons of gravel onto my tractor paths. It was fine for the 4' bush hog. Also fine for my MacKissic shredder. A GREAT snow mover with FEL and back blade. Big mulch mover with FEL and carryall half filled on the back.
Sales person sold me a 1025R (like a BX with hydraulic cooling on top where it should be). It was a lemon and not enough clearance.
Went back to a 2 series with the 2025R. Cannot get any lower hp now. A little faster FEL, and the FEL is "goof proof", too, vs. the 1025r's being capable of dumping a load accidently almost any time.
My experience.
Ralph
/ New here, would like to bounce some ideas off ya'll #18
When I was trying to buy a tractor, my experience was similar to shooterdon's. In my local area, the used equipment was either almost destroyed, or it was almost equal to the cost of brand new. I also looked for several months before I gave up and bought new.
A lot depends on your local area's economy, and how much equipment is available on the used market.
I would think a sub compact would do everything you need it to, but certain tasks like mowing the acreage, will take longer because the size of the implements you're using are smaller and can cover less ground in the same time. Same goes for tilling, or even moving dirt around. If your not in a hurry, it will work. Going up in size in your case mostly just gains you speed in getting tasks done via larger sized implements. Since you're not cutting and bailing hay, or moving large hay bales, everything on your list can be done with a sub compact.
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58214)
2011 NORAM POWER...
2016 Ford F-550 4x4 IMT 3203i 2 Ton Crane Mechanics Truck (A61568)
2016 Ford F-550...
2019 GENIE S-60XC TELESCOPIC BOOM LIFT (A62129)
2019 GENIE S-60XC...
MASSEY FERGUSON 255 TRACTOR (A62130)
MASSEY FERGUSON...
2025 GIYI GY-P45 Hydraulic Breaker Skid Steer Attachment (A61567)
2025 GIYI GY-P45...
2006 International 4300 Altec LRV58 58ft Forestry Chipper Bucket Truck (A61568)
2006 International...
