RX7320 3rd Function
/ RX7320 3rd Function
ok an update. Tractor is suppose to be delivered on Thursday. BUT will not have 3rd function. apparently US Corporate office was mistaken when they said they had some. there are none in the US my dealer told me from what he heard from Kioti. So who knows when it will make it across the ocean.
/ RX7320 3rd Function #22
Covid-19 has messed up a lot of stuff coming from Korea and China lately. Supply chains are slow, all sorts of assemblies are slow because of one missing piece. I have a 7320 with the third function valve and really like it. Well worth the wait.
/ RX7320 3rd Function #23
@cutthroat- Sorry to hear about the delays. Hopefully once those items are back in stock they can get you sorted out. In the meantime I hope your tractor arrives on time and allows you to get to work and enjoy it. You'll be so busy maybe you won't notice the missing 3rd function. Best of luck and do post photos.
Tractor is here! Noticeably larger than the NX6010 coming from. Going to take a little bit to get used to a non-HST. Just waiting for 3rd function to come over from South Korea, no ETA.
Some additional pictures. Only 1 hour!
-Craig
First minor complaint. These handles to remove the loader rattle A LOT. I don't think they were greased by the dealer, maybe adding some grease will prevent the vibration and rattling.
I am also noticing the tire is hitting the hoses for the loader when turning. I'm not sure they are routed correctly. Can someone confirm?
Got Land Pride hitch installed on drawbar, ready for mow season if it ever dries out.
/ RX7320 3rd Function #29
All shiny and new. Looks great. Congrat and welcome to the RX7320 owners group.
/ RX7320 3rd Function #30
I've found a number of things seem to rattle. In particular the draft and 3-pt lift arms like to rattle against their stops. Been thinking of adding some felt pads to the stops to get them to quiet down.
/ RX7320 3rd Function #31
That's different from mine. My 90 fittings point downward (see attached). I don't have any problem with hoses rubbing though my wheels (front and back) are set at widest setting.
/ RX7320 3rd Function #32
What size mower you planning to pull? I've got a 10' Land Pride brush hog I picked up last year. Seems to be a very good match for the machine
It is a 14' flex wing grooming mower.
/ RX7320 3rd Function #36
That should get a lot of work done in a hurry. Depending on hills and how thick the brush is you may need to take it slowly. 14' swath sure would be nice.
Yeah now I can see it. I will see if I can get mine to work that way, might need some turning of the fittings. I did reroute mine for the time being like attached image shows. I am worried about the inside most fitting as it could get crushed by the loader frame if it is able to flex towards the cab, which I'm not sure it can do.
-Craig
/ RX7320 3rd Function #38
I've never had any trouble with my hoses. I've removed and re-installed the loader a couple times and everything seems to work just fine. I'd think those quick couplers should let you rotate any which way you want.
I noticed you've got a black seat. Mine is cream/tan. Wish I'd gotten the black as the tan just gets dirty looking. Is that a standard seat?
Yeah it is the seat it came with. It is a Grammer seat as I got an additional pamphlet that talks about it.
/ RX7320 3rd Function #40
Took some pictures of mine tonight after Meet a the Coach Night for the kids tball, pixie, and baseball.... Tractor is rather dirty from all the mud lately so don't mind that.
They are soft lines running from the 3rd function valve to the loader.
With regards to my wayyy longer, a few seconds longer. Just 'annoying' when comparing it to the Old Man's JD that does open and dump at normal speed at any rpm range. View attachment 643923View attachment 643924View attachment 643925View attachment 643926View attachment 643927View attachment 643928
Thanks for sharing as I've been interested to see what Kioti came up with. I imagine their mounting the valve body on the side to avoid the labor of mounting it on top of the transmission.
UNUSED JCT 2 PRONG BALE SPEAR (A62131)
UNUSED JCT 2 PRONG...
UNUSED WOLVERINE TDB-11-66W 66" QUICK ATTACH BKT (A62131)
UNUSED WOLVERINE...
2006 GMC Savana 3500 Box Truck (A61568)
2006 GMC Savana...
(2) ROW CULTIVATOR W/GAUGE WHEELS (A62130)
(2) ROW CULTIVATOR...
BUNDLE OF ASSORTED, PINE & RED CEDAR (A62131)
BUNDLE OF...
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
