3 inch gooseneck coupler
/ 3 inch gooseneck coupler #1
Hay Dude
Epic Contributor
The Last Red State in the Northeast
Challenger MT655E, Massey Ferguson 7495, Challenger MT555D, Challenger MT535B Krone 4x4 XC baler, 2-Kubota ZD1211’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mower, NH wheel rak
Just purchased new truck rated at 43,000 GCWR. Plan in near future is to also get a 35,000lb gooseneck trailer. Anything over 30k requires a 3 ball, an upgrade from 2&5/16 ball. I am having the new truck upfitted with an aluminum flatbed and 3 ball.
My current gooseneck is 24,000lbs with 2&5/16 ball. Would like to keep this trailer useable behind the new truck, so have to change the coupler on the 24k trailer. Its a square type. I found Bulldog on line for ~ $500.
Has anyone done this?
/ 3 inch gooseneck coupler #2
Bolt and weld it. Grade 8 bolts and multi pass with the welder. Paint it when you get it done - looks better and will rust much slower. I did this on a used trailer I bought years ago. The previous owner had modified the 2" coupler by cutting most of the flange off and butt welding it onto the square tube frame - yes you read that right! I cut all of that off and bought a new coupler and welded and bolted it on - the way it was designed to be installed. I'm a good welder but have nothing to prove so I played it safe. Scary thing about it was they (previous owner) had just used this trailer to haul a Dodge Ram charger about 80 miles
/ 3 inch gooseneck coupler #4
I would think you could just buy a new square inner tube with the 3" head to slide into your existing square outer tube . No need to buy and weld a whole new outer tube on.
/ 3 inch gooseneck coupler #5
That would be my thought as well??
/ 3 inch gooseneck coupler #6
Can the bed not be fitted with a interchangeable ball, just switch it out, for each trailer? Sort of like the B&W turnovers have.
/ 3 inch gooseneck coupler #8
Looks like they are installing a “name brand” set up to achieve the rating I want and have it be certified. I think their shop doesn’t have anything certified over 30k yet since these newer trucks are now getting over a 30k tow rating, but that’s just a guess.
If I can get an interchangeable ball, that would be great! Far cheaper.
/ 3 inch gooseneck coupler #10
Keeping the 2 5/16" or at least having different inner tubes allows you to use the trailer on other trucks with the more common (for now) 2 5/16" ball as well. It would also make it easier to sell in the future.
/ 3 inch gooseneck coupler #11
Yeah, especially if it could be rigged up as a "Quick Change" system that required minimal wrenching!!!
So after a few emails, found out Im getting a BW turnover 45,000lb hitch installed.
With that set up, you can easily interchange a 2-5/16th ball for the 3" ball.
I traded my 550 on the new truck, but still have my '08 F-350 flatbed. The 350 has a B&W turnover with a 2&5/16" ball.
Glad it worked out! Nice setup on that flatbed!
Thanks. After owning flatbeds for last 15 years, I see how useful they are compared to a pickup bed. So much easier to “work out of” than a pickup bed. I really like the F-350. I use it for snow plowing, too. Being a regular cab with a flatbed, its kind of a “throwback” truck back to when 90% of trucks were regular cab.
Besides, it gives you an excuse to buy a gooseneck dump trailer if you need to carry dirt, equipment, etc :)
Now comes the waiting game for the 5500. With everything shut down because of CV, it could be a while :(
So, you are going from a F550 to a gm 5500?
RAM 5500
I wanted the new GM 5500 or 6500 because I like the Duramax/Allison combo, but their towing and GCWR specs were silly low- not much better than my 08 F-550. I need to tow a 33,000lb trailer.
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
Steel Blasting Shed (A62679)
Steel Blasting...
2016 JEEP PATROIT (A59914)
2016 JEEP PATROIT...
43018CFL (A59228)
43018CFL (A59228)
2013 PETERBILT 367 MIDROOF SLEEPER (INOPERABLE) (A65643)
2013 PETERBILT 367...
JLG TELESCOPIC FORKLIFT (A64279)
JLG TELESCOPIC...
