3 inch gooseneck coupler
/ 3 inch gooseneck coupler #1
Hay Dude
Epic Contributor
The Last Red State in the Northeast
Challenger MT655E, Massey Ferguson 7495, Challenger MT555D, Challenger MT535B Krone 4x4 XC baler, 2-Kubota ZD1211’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mower, NH wheel rak
Just purchased new truck rated at 43,000 GCWR. Plan in near future is to also get a 35,000lb gooseneck trailer. Anything over 30k requires a 3 ball, an upgrade from 2&5/16 ball. I am having the new truck upfitted with an aluminum flatbed and 3 ball.
My current gooseneck is 24,000lbs with 2&5/16 ball. Would like to keep this trailer useable behind the new truck, so have to change the coupler on the 24k trailer. Its a square type. I found Bulldog on line for ~ $500.
Has anyone done this?
/ 3 inch gooseneck coupler #2
Bolt and weld it. Grade 8 bolts and multi pass with the welder. Paint it when you get it done - looks better and will rust much slower. I did this on a used trailer I bought years ago. The previous owner had modified the 2" coupler by cutting most of the flange off and butt welding it onto the square tube frame - yes you read that right! I cut all of that off and bought a new coupler and welded and bolted it on - the way it was designed to be installed. I'm a good welder but have nothing to prove so I played it safe. Scary thing about it was they (previous owner) had just used this trailer to haul a Dodge Ram charger about 80 miles
/ 3 inch gooseneck coupler #4
I would think you could just buy a new square inner tube with the 3" head to slide into your existing square outer tube . No need to buy and weld a whole new outer tube on.
/ 3 inch gooseneck coupler #5
That would be my thought as well??
/ 3 inch gooseneck coupler #6
Can the bed not be fitted with a interchangeable ball, just switch it out, for each trailer? Sort of like the B&W turnovers have.
/ 3 inch gooseneck coupler #8
Looks like they are installing a “name brand” set up to achieve the rating I want and have it be certified. I think their shop doesn’t have anything certified over 30k yet since these newer trucks are now getting over a 30k tow rating, but that’s just a guess.
If I can get an interchangeable ball, that would be great! Far cheaper.
/ 3 inch gooseneck coupler #10
Keeping the 2 5/16" or at least having different inner tubes allows you to use the trailer on other trucks with the more common (for now) 2 5/16" ball as well. It would also make it easier to sell in the future.
/ 3 inch gooseneck coupler #11
Yeah, especially if it could be rigged up as a "Quick Change" system that required minimal wrenching!!!
So after a few emails, found out Im getting a BW turnover 45,000lb hitch installed.
With that set up, you can easily interchange a 2-5/16th ball for the 3" ball.
I traded my 550 on the new truck, but still have my '08 F-350 flatbed. The 350 has a B&W turnover with a 2&5/16" ball.
Glad it worked out! Nice setup on that flatbed!
Thanks. After owning flatbeds for last 15 years, I see how useful they are compared to a pickup bed. So much easier to “work out of” than a pickup bed. I really like the F-350. I use it for snow plowing, too. Being a regular cab with a flatbed, its kind of a “throwback” truck back to when 90% of trucks were regular cab.
Besides, it gives you an excuse to buy a gooseneck dump trailer if you need to carry dirt, equipment, etc :)
Now comes the waiting game for the 5500. With everything shut down because of CV, it could be a while :(
So, you are going from a F550 to a gm 5500?
RAM 5500
I wanted the new GM 5500 or 6500 because I like the Duramax/Allison combo, but their towing and GCWR specs were silly low- not much better than my 08 F-550. I need to tow a 33,000lb trailer.
2011 Ford F-750 Water Truck, VIN # 3FRPF7FA5BV653152 (A65563)
2011 Ford F-750...
2020 Bobcat MT85 (A62177)
2020 Bobcat MT85...
Landhonor Quick Attach Hydraulic Pallet Forks (A66408)
Landhonor Quick...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
New/Unused CFG Industrial H12R Mini Excavator (A65579)
New/Unused CFG...
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
