3 inch gooseneck coupler
   / 3 inch gooseneck coupler #1
Hay Dude
Super Star Member
A Hay Field along the PA/DE border
Challenger MT655E, Massey Ferguson 7495, Challenger MT535B, Krone 4x4 XC baler, (2) Kubota ZD331’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mowers
Just purchased new truck rated at 43,000 GCWR. Plan in near future is to also get a 35,000lb gooseneck trailer. Anything over 30k requires a 3 ball, an upgrade from 2&5/16 ball. I am having the new truck upfitted with an aluminum flatbed and 3 ball.
My current gooseneck is 24,000lbs with 2&5/16 ball. Would like to keep this trailer useable behind the new truck, so have to change the coupler on the 24k trailer. Its a square type. I found Bulldog on line for ~ $500.
Has anyone done this?
   / 3 inch gooseneck coupler #2
Bolt and weld it. Grade 8 bolts and multi pass with the welder. Paint it when you get it done - looks better and will rust much slower. I did this on a used trailer I bought years ago. The previous owner had modified the 2" coupler by cutting most of the flange off and butt welding it onto the square tube frame - yes you read that right! I cut all of that off and bought a new coupler and welded and bolted it on - the way it was designed to be installed. I'm a good welder but have nothing to prove so I played it safe. Scary thing about it was they (previous owner) had just used this trailer to haul a Dodge Ram charger about 80 miles
   / 3 inch gooseneck coupler #4
I would think you could just buy a new square inner tube with the 3" head to slide into your existing square outer tube . No need to buy and weld a whole new outer tube on.
   / 3 inch gooseneck coupler #5
That would be my thought as well??
   / 3 inch gooseneck coupler #6
Can the bed not be fitted with a interchangeable ball, just switch it out, for each trailer? Sort of like the B&W turnovers have.
   / 3 inch gooseneck coupler #8
Looks like they are installing a “name brand” set up to achieve the rating I want and have it be certified. I think their shop doesn’t have anything certified over 30k yet since these newer trucks are now getting over a 30k tow rating, but that’s just a guess.
If I can get an interchangeable ball, that would be great! Far cheaper.
   / 3 inch gooseneck coupler #10
Keeping the 2 5/16" or at least having different inner tubes allows you to use the trailer on other trucks with the more common (for now) 2 5/16" ball as well. It would also make it easier to sell in the future.
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
2014 Dodge Ram 5500 4x4 Bucket Truck with Altec AT40M - 45FT Boom, Jib Winch and Utility Bed (A52748)
2014 Dodge Ram...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2007 Eager Beaver 35 GLB Lowboy, Tandem Axel (A52384)
2007 Eager Beaver...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A52748)
2016 Ford F550 4x4...
