3 inch gooseneck coupler
   / 3 inch gooseneck coupler #1
Hay Dude
Super Star Member
A Hay Field along the PA/DE border
Challenger MT655E, Massey Ferguson 7495, Challenger MT535B, Krone 4x4 XC baler, (2) Kubota ZD331’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mowers
Just purchased new truck rated at 43,000 GCWR. Plan in near future is to also get a 35,000lb gooseneck trailer. Anything over 30k requires a 3 ball, an upgrade from 2&5/16 ball. I am having the new truck upfitted with an aluminum flatbed and 3 ball.
My current gooseneck is 24,000lbs with 2&5/16 ball. Would like to keep this trailer useable behind the new truck, so have to change the coupler on the 24k trailer. Its a square type. I found Bulldog on line for ~ $500.
Has anyone done this?
   / 3 inch gooseneck coupler #2
Bolt and weld it. Grade 8 bolts and multi pass with the welder. Paint it when you get it done - looks better and will rust much slower. I did this on a used trailer I bought years ago. The previous owner had modified the 2" coupler by cutting most of the flange off and butt welding it onto the square tube frame - yes you read that right! I cut all of that off and bought a new coupler and welded and bolted it on - the way it was designed to be installed. I'm a good welder but have nothing to prove so I played it safe. Scary thing about it was they (previous owner) had just used this trailer to haul a Dodge Ram charger about 80 miles
   / 3 inch gooseneck coupler #4
I would think you could just buy a new square inner tube with the 3" head to slide into your existing square outer tube . No need to buy and weld a whole new outer tube on.
   / 3 inch gooseneck coupler #5
That would be my thought as well??
   / 3 inch gooseneck coupler #6
Can the bed not be fitted with a interchangeable ball, just switch it out, for each trailer? Sort of like the B&W turnovers have.
   / 3 inch gooseneck coupler #8
Looks like they are installing a “name brand” set up to achieve the rating I want and have it be certified. I think their shop doesn’t have anything certified over 30k yet since these newer trucks are now getting over a 30k tow rating, but that’s just a guess.
If I can get an interchangeable ball, that would be great! Far cheaper.
   / 3 inch gooseneck coupler #10
Keeping the 2 5/16" or at least having different inner tubes allows you to use the trailer on other trucks with the more common (for now) 2 5/16" ball as well. It would also make it easier to sell in the future.
2014 Ford Explorer Sport AWD SUV (A51694)
2014 Ford Explorer...
KUBOTA SVL-75 SKIDSTEER (A52472)
KUBOTA SVL-75...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
2018 KOMATSU D51PX-24 CRAWLER DOZER (A51246)
2018 KOMATSU...
2013 FREIGHTLINER M2 TANDEM AXLE DAY CAB (A52576)
2013 FREIGHTLINER...
2011 ORTEQ ENERGY SERVICES 40 MANIFOLD TRAILER (A52472)
2011 ORTEQ ENERGY...
