LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,877
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
I have run two kinds of 2 link ladder chains on turf tires.. Both V bar and non V bar.. The plain cross links worked well, the V bar works better..
I got the plain set from John Deere, which fit fine the first use.. The V bar set came from a custom maker who works with lots of logging and mining equipment.. They fit well also..
It is always best to use tighteners on any kind of chain set.. I have had a lot of trouble with bungee and all types of rubber tarp tighteners and chain tighteners.. They seem to want to break and the pieces fly past you head.. My best luck has been with homemade tighteners made from a spring, light chain and S hooks..
Many of the Euro style studded chains do not need tensioners some are even recommended to be run slightly loose.
I have several years use of my Aquiline Talon chains on more then one tractor with no tensioners,
also the traction from this style chain will far exceed any thing from ladder chains.
