Oil & Fuel Home heating oil as tractor fuel
/ Home heating oil as tractor fuel #11
I would call the oil dealer and ask if its Ultra-Low Sulfur Heating Oil , Here in NH they just started using uls fuel last year for heating
/ Home heating oil as tractor fuel #12
If your diesel is a tier 4 machine, I would not use the heating fuel. The new fuel is okay but the tank is not. A little bit of contamination goes a long way with common rail, electronic injectors, DPF and sensors.
Pre tier machines were tough and could digest near anything that burned.
true that.............the old multi/all fuel WWII vintage tractors sang on pretty much whatever you had
/ Home heating oil as tractor fuel #13
Ditto on a good filter. I use Goldenrod Water Block filters on all my fuel tanks. You just never know when a slug of water or crud could show up.
/ Home heating oil as tractor fuel #14
Ultra low sulfur diesel ULSD (<15ppm) has been required in NY since 2012.
I can't tell what you're suggesting knowing this.
I believe ULSD has less (fuel pump) lubricity than it's predecessors and refiners may add additives to meet minimum requirements.
Is it common that some ULSD "heating fuel oil" doesn't meet lubricity requirements because it's not engine "diesel" fuel? Possibly... but more likely it comes from the same tank at the distributors.
If in doubt, and concerned over effects of 100 gallons, add the grey bottle additives. :2cents:
/ Home heating oil as tractor fuel #15
I did not know it was required in NY since 2012 ,If that's the case I would use it ...
/ Home heating oil as tractor fuel #16
Interesting. I also live in NH and most suppliers have been using it for heating for years now. Perhaps the "mandate" just recently occurred. For my supplier, its been ULSD for at least 10 years.
I see you are from Washington County...years ago, I lived in Whitehall...but its a pretty large county.
You are correct about the lower lubricity of ULSD, but all the newer engines are designed to run on it.
/ Home heating oil as tractor fuel #17
I use eastern propane and oil, I called them the winter of 2018/2019 and they asked what state I lived in and said uls heating oil would start July of 2019 It was signed into law 2018 The state of New Hampshire has passed a bill that will transition all heating oil sold in the state to ULS. During 2018, oil dealers will gradually transition from traditional heating oil to ULS heating oil
/ Home heating oil as tractor fuel #18
I have yet to get an honest answer from my heating oil supplier. Every time I call and ask if the heating oil is ULSD, I am treated like a criminal, by wanting to use untaxed fuel in something (my Tractor). Go figure.
/ Home heating oil as tractor fuel #19
The fuel will be fine, it you are concerned run it thru a filter, the higher quality the better.
A filter is always a good idea.
PetroClear - New PetroClear<sup>(R)</sup> 455W-AD 5-Micron Dispenser Filter Protects High-Performance Engines From Harmful Particulates
I learned after moving South that once you leave the Northeast not all home heating oil is ULSD. If your tractor REQUIRES ULSD be sure that your HHO meets that requirement before using it. Beyond that, I agree with Lou.
/ Home heating oil as tractor fuel #20
Interesting. I use Cheshire oil - they have been on ULSD for quite awhile now. I am familiar with Eastern though...
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
2012 DOOSAN G25 GENERATOR (A60736)
2012 DOOSAN G25...
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
CFG Inudustrial MH12RX (A60463)
CFG Inudustrial...
2009 CHEVROLET C8500 DUMP TRUCK (A59823)
2009 CHEVROLET...
Giyi GY-CYHC Mini Quick Attach Side Shift Forks (A60463)
Giyi GY-CYHC Mini...
