I folded my Quick Tach plate
/ I folded my Quick Tach plate #21
I was referring more to the JD design of the post picture and questioning if it was independant?
I had never looked at how week of a design it really was until it was folded in half! Bobcat has made a change - I'm not sure what it looks like now, and I'm not going to find out. They want over $1700 for the replacement. I know my local welder can rebuild this and make it a LOT stronger for a heluva lot less.
/ I folded my Quick Tach plate #23
In fairness, looking at the pictures on the OPs other thread regarding the same failure, it does look a little better built. Also shows the failure much moe clearly, which I had TOTALLY misunderstood.
My post in the Bobcat forum shows additional pictures from previous failures. The pictures from the latest failure are the same on both posts.
My purpose for the the post in the Bobcat forum was a question on the overall quality of the 7TL loader and if others Bobcat CUT users had experienced similar. This post was simply a frustration post - after reviewing the break and others posts it really pointed out just how poorly the plate was designed.
/ I folded my Quick Tach plate #25
You should never damage a properly made ssqa or loader operating under the pressure relief valve. That didn't look like it's properly made so I would def add more gussets.
/ I folded my Quick Tach plate #26
Give something enough enertia and you can bust anything. I saw commercial forks at a friends that had been folded back 180 degrees over half of their length (maybe four foot forks) and I just thought, how in the world could you even do that?
/ I folded my Quick Tach plate #27
Running it off the end of a loading dock and landing on the forks will do that.
/ I folded my Quick Tach plate #28
No it won't. That's bent forward..meaning curling the bucket would bend it like that.
/ I folded my Quick Tach plate #29
He was talking about the forklift forks mentioned earlier....
/ I folded my Quick Tach plate #30
either its not designed for the power/capabilities of the units its mounted on OR the unit was used in a manner not designed - which happens a lot and why so many like myself have modified things/over engineered them but at some point something more expensive/larger breaks, at least that is what happens to me LOL.
My dad was notorious for such antics like ramming with the blade ( getting a run at things ), going across rough terrain with too much in the loader cracking arms cause he was in a hurry and things got to bouncing, hooking onto something with a chain and then backing up to it and trying to jerk it out of the mud etc.....
i fixed way too many things due to his temper and my stuff gets treated much different - i hate tearing things up !!!
/ I folded my Quick Tach plate #32
Or it's just a lousy design by the low bidder.
and if that is the case, it would be the fault of the owner/operator to decide to purchase it knowing it is of sub part design and then expect it to hold up to HEAVY use - you get what you pay for
/ I folded my Quick Tach plate #33
So when you bought your 4wd tractor with SSQA FEL you carefully studied the design of the SSQA plate to make sure it was built right?
/ I folded my Quick Tach plate #34
Yep, I thought of the same question.
I didn't have to worry about the Toolcat SSQA plate when my wife bought it.
It looks a little stronger than tractor plates:
/ I folded my Quick Tach plate #35
as a matter of fact i did and i determined the needs/work i intended to do would not be suitable for my CUT and I would tear it/implements/loader/attachments of that category up and totally ruin my equipment - i have a skidsteer for the heavy stuff - I have torn enough things up over the years that its pretty easy now to see if something is going to hold up depending on the job, equipment - I have learned to ERR on the side of bigger is better 95% of the time and a lot of time it also becomes a safety issue as well.
UNUSED KJ 20'X30' METAL GARAGE (A62131)
UNUSED KJ 20'X30'...
17109SFL (A61569)
17109SFL (A61569)
UNUSED WOLVERINE MAD-12-12D 12" MINI HYD AUGER (A62131)
UNUSED WOLVERINE...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
UNUSED KUBOTA B2366 PIN ON QUICK ATTACH (A62130)
UNUSED KUBOTA...
UNUSED RAYTREE REDM32-32" EXCAVATOR MULCHER (A62131)
UNUSED RAYTREE...
