I folded my Quick Tach plate
   / I folded my Quick Tach plate #32
Or it's just a lousy design by the low bidder.
and if that is the case, it would be the fault of the owner/operator to decide to purchase it knowing it is of sub part design and then expect it to hold up to HEAVY use - you get what you pay for
   / I folded my Quick Tach plate #33
So when you bought your 4wd tractor with SSQA FEL you carefully studied the design of the SSQA plate to make sure it was built right?
   / I folded my Quick Tach plate #34
Yep, I thought of the same question.
I didn't have to worry about the Toolcat SSQA plate when my wife bought it.
It looks a little stronger than tractor plates:
   / I folded my Quick Tach plate #35
as a matter of fact i did and i determined the needs/work i intended to do would not be suitable for my CUT and I would tear it/implements/loader/attachments of that category up and totally ruin my equipment - i have a skidsteer for the heavy stuff - I have torn enough things up over the years that its pretty easy now to see if something is going to hold up depending on the job, equipment - I have learned to ERR on the side of bigger is better 95% of the time and a lot of time it also becomes a safety issue as well.
Poly Bristle Sweep, 78" x 8" (A59076)
Poly Bristle...
air compressor (A55758)
air compressor...
2007 PETERBILT 385 CAB AND CHASSIS (A58214)
2007 PETERBILT 385...
2025 GIYI GY-PG72C 72in Dual Cylinder Grapple Bucket Skid Steer Attachment (A56857)
2025 GIYI GY-PG72C...
2022 FORD F-250 (A58214)
2022 FORD F-250...
PALLET OF MISC BOAT MOTOR PARTS (A58374)
PALLET OF MISC...
