I folded my Quick Tach plate
/ I folded my Quick Tach plate #32
Or it's just a lousy design by the low bidder.
and if that is the case, it would be the fault of the owner/operator to decide to purchase it knowing it is of sub part design and then expect it to hold up to HEAVY use - you get what you pay for
/ I folded my Quick Tach plate #33
So when you bought your 4wd tractor with SSQA FEL you carefully studied the design of the SSQA plate to make sure it was built right?
/ I folded my Quick Tach plate #34
Yep, I thought of the same question.
I didn't have to worry about the Toolcat SSQA plate when my wife bought it.
It looks a little stronger than tractor plates:
/ I folded my Quick Tach plate #35
as a matter of fact i did and i determined the needs/work i intended to do would not be suitable for my CUT and I would tear it/implements/loader/attachments of that category up and totally ruin my equipment - i have a skidsteer for the heavy stuff - I have torn enough things up over the years that its pretty easy now to see if something is going to hold up depending on the job, equipment - I have learned to ERR on the side of bigger is better 95% of the time and a lot of time it also becomes a safety issue as well.
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
John Deere 6110M (A60462)
John Deere 6110M...
2016 KENWORTH T880 TRI-AXLE DUMP TRUCK (A62130)
2016 KENWORTH T880...
CATERPILLAR 299D2 SKID STEER (A60429)
CATERPILLAR 299D2...
36"x12' Stacks of Sheet Metal (A60463)
36"x12' Stacks of...
1988 Ford 8210 (A60462)
1988 Ford 8210...
