Cottage Carport
/ Cottage Carport
A good morning of progress.
Both sides of carport base anchored in.
The additional 5/8 anchors are set in epoxy and will tighten down later. Must remember to tighten the two independent legs as well. Didn’t take up right size socket.
Cottage side
Far side.
/ Cottage Carport #82
Lookin good! Cannot wait to watch the rest go up.
/ Cottage Carport #83
Are you going to dig out the dirt next to it and slope it down some? The way you have it sitting there looks like it's going to get back filled which will likely lead to a metal rusting through and water running into the carport.
Aaron Z
/ Cottage Carport
Aaron Z
At this point something of a toss up. Either 1/2 sheet of corrugated metal against the bank or 2-3 courses of block. Yup, the metal will rust, likely get water either way. Water less a concern as it would be coming down the drive anyway. Not making any attempt to keep it dry. Main concern is a stable bank for mowing.
/ Cottage Carport #85
Now is the time to dig a trench, install a drain tile and backfill with gravel. You will be glad you did. Even if you don't care about it rusting out, in short order water will start seeping in and you will have mud inside you building all the time.
/ Cottage Carport #86
I might put a piece of corrugated pipe at the bottom and then fill the space between the dirt and the metal with washed crushed rock. That way water can go in and flow out without staying next to the metal and rusting it out as quickly.
or if you have much of a slope uphill from that, you might want to dig a second trench out 2-3 feet and do the same thing out there so that any water gets caught out there.
If you do that, you could also put the dirt that gets dug out between the building and second trench so that there is a slope away from the building and towards the second trench.
Aaron Z
/ Cottage Carport
30 nuts and bolts, 816 self drilling screws later - 6 31ft trusses
All in all, a pretty good day. Impressed with how well it went together. Basically check a couple of measurements, find center, make sure collar tie is straight and it went together easily.
/ Cottage Carport
Rain coming in, but managed to get corner brackets installed. Actually been sprinkling on and off most of the morning.
Next step is to mark locations for the purlins. Easier on the ground and will aid getting trusses in proper alignment. Challenge is my marker doesn’t work well on wet metal.
Will transport trusses individually via tractor. Don’t have flat area of sufficient length for leg installation at the cottage. Current thinking is to install legs temporarily here at tractorshed, uninstall for transport, reinstall at cottage. More work, but I think actually easier.
/ Cottage Carport
Rain held off long enough.
A few paper towels later and I was able to get trusses marked for purlins. Also played with positioning leg support brackets. All in all, a good day.
/ Cottage Carport #90
There is a lot more to those kits then I realized
/ Cottage Carport
There appear to be different levels. Mine is more substantial than the smaller unit at our local HD. I admit to being quite impressed.
/ Cottage Carport #92
It sure does look to be more substantial than the ones I have looked at. Very nice.
/ Cottage Carport
Hope to get started erecting wall today. Slow and easy. Will report back.
/ Cottage Carport
The erection has started
First, getting the wall piece up to Cottage
Fit into place to determine mods for laundry structure
Put base in place
Move a truss to cottage
Maneuver into place
One up, ready for number 2
Two trusses set.
Tomorrow’s another day.
/ Cottage Carport #95
Sodoma: your carport is shaping up nicely. best of luck tomorrow.
thanks for the 411 on your property and it sounds and looks like a dream. we are getting rained on so hard it's hard to believe there is any left to rain on you.
love watching guys work in flip flops and good to hear you have some help!!
cheers and good luck
/ Cottage Carport #96
Looks good. Dont drop anything on your toes. :eek:
/ Cottage Carport
All trusses in place, taking a break. Just Canada Dave and I today. Only about 1 1/2 hours to place.
After break will work on truing and stabilizing.
/ Cottage Carport
Three rows of purlins and 1 row rat track installed significantly stabilizing structure. The bracing back to cottage will hold it true and then we can finish the purlins, rat track, and corner bracing then hundreds more screws in the slip joints.
No new pics, just nothing that notable.
As for the roof metal, that is coming from guy I bought my house material from. 12 ft lengths and some custom cuts. I could have ordered from local building supply that makes own roofing but at 2x the cost.
/ Cottage Carport #100
Not to rush ahead. How are you going to deal with the water coming off the roof at the cottage side? Maybe you already talked about this, sorry if so.
Thanks for the updates and pics!!!
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
1828 (A61574)
1828 (A61574)
Challenger MT800 Tractor Service Manuals Vol. 1 and Vol. 2 (A63117)
Challenger MT800...
2013 29ft. Larson LXI292 Boat with 30ft T/A Loadmaster Boat Trailer (A61574)
2013 29ft. Larson...
Volvo SD100D Single Drum Vibratory Soil Compactor (A61572)
Volvo SD100D...
300 GALLON HYD OIL TANK (A64280)
300 GALLON HYD OIL...
