JD2720 Rear wheels configuration
/ JD2720 Rear wheels configuration #21
Kubota does that on all of their R4 wheels.
/ JD2720 Rear wheels configuration #22
That is a good point, I noticed my MX4800 with R1 tires doesn't have the guards.
I'll need to look on my new L60 series. It has R4 tires but also has position-adjustable rims. I can see the guards on the front rims, but on the back it appears the valve stems are on the inside.
No such guards on JD
/ JD2720 Rear wheels configuration #24
That痴 too bad. You could make some I guess.
I wanted to close the loop.
The rimguard dealer ended up ordering an adapter hose and was able to fill the tires mounted as is. All said and done it cost me with tax only $232.
win win.
New Holland TC21 (A62177)
New Holland TC21...
QA Sweeper (A64126)
QA Sweeper (A64126)
2015 Ford F-450 Crew Cab Mason Dump Truck (A61573)
2015 Ford F-450...
1990 John Deere 4455 (A64119)
1990 John Deere...
2015 Ford C-Max Hatchback (A61574)
2015 Ford C-Max...
Timpte 720 All Aluminum 7000 Tilt Trailer (A63689)
Timpte 720 All...
