JD2720 Rear wheels configuration
/ JD2720 Rear wheels configuration #21
Kubota does that on all of their R4 wheels.
/ JD2720 Rear wheels configuration #22
That is a good point, I noticed my MX4800 with R1 tires doesn't have the guards.
I'll need to look on my new L60 series. It has R4 tires but also has position-adjustable rims. I can see the guards on the front rims, but on the back it appears the valve stems are on the inside.
No such guards on JD
/ JD2720 Rear wheels configuration #24
That痴 too bad. You could make some I guess.
I wanted to close the loop.
The rimguard dealer ended up ordering an adapter hose and was able to fill the tires mounted as is. All said and done it cost me with tax only $232.
win win.
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
2002 Freightliner FL112 S/A Day Cab Truck Tractor (A59230)
2002 Freightliner...
2001 Pierce Spartan Model Tilt Pumper Fire Truck (A59230)
2001 Pierce...
2006 JAYCO JAYFLIGHT 30' TYPE CAMPER (A58375)
2006 JAYCO...
2017 CATERPILLAR 420F2 BACKHOE (A59823)
2017 CATERPILLAR...
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
