JD2720 Rear wheels configuration
/ JD2720 Rear wheels configuration #1
suburbanfarmer
Western NY
JD 3238e & 3228e
Hi All,
Still going the through the paces with my JD2720 and was able to get a good price to get the rear wheel filled with rimgard.
The challenge is that the valve stems are in the inside.
If i take the tires off, then I cant put them back on with the additional weight.
Can i reverse the tires to have the valve stem on the outside. Will that make the stance narrower?
/ JD2720 Rear wheels configuration #2
That depends on the offset and wheel design. Just measure the offset on both sides and you will have your answer.
The stock wheels on my 4310 places the valve stem in with them on the wide setting. I bought a set off eBay that have a greater offset that places the stems out in the wide setting. Sorry not to answer with any more specifics. Without pics I don't know the design of the wheels you have.
Thanks, just measured and the difference in offset is only 0.5 inch. Seems it wont matter too much if i swap sides. Maybe spacers are next on the list
/ JD2720 Rear wheels configuration #4
Why do you care if the valve stems are to the inside? Once the tires are filled, you'll likely not need to access the valve stems again for years.
Yes you can move the tires around once they are filled. Just be very careful to make sure the tire stays "upright" as you roll it around. If it starts to go over, it may be too heavy to stop. Getting them back upright again might require mechanical assistance.
/ JD2720 Rear wheels configuration #5
Some wheels are not designed to be reversed. When they are you will have twice as many holes as you have lugs. One set will be tapered on one side and the other on the other side.
Make sure and use the holes where the taper matches the lug bolts/nuts. Also remember to retorque after a few hours and periodically. They CAN come loose.
The rimgard company needs the valve stems on the outside to pump the fluid in. As for rolling the tires, there is still going to be the need to lift it back on the lug nuts.
I dont think I have rims that can be separated.
Also if you notice in this video the valve stems are on the outside with the spacers
/ JD2720 Rear wheels configuration #9
Tractorguy isn't talking about adjustable wheels that the rim unbolts from the center. He's talking about the lug bolt holes being designed to tighten one way using a taper in the center bolt holes.
/ JD2720 Rear wheels configuration #10
That's the most pointless video I've ever saw. :D
Got it, i guess will be taking the tire off to see if the lug bolt holes are tapered or flat.
/ JD2720 Rear wheels configuration #13
I just linked it to show that the rims have valve stems on the outside.
You can tell by the centers that they are reversed from yours. The question is what that does to tread width?
That can be best answered by removing one and doing some measuring? Or you might find something in the owners manual that tells you?
The offset is only different by 1/2 inch and i have the owners manual and it doesnt say anything about flipping the tires :(
/ JD2720 Rear wheels configuration #15
I believe I'd have to double question the rim guard company on that; as to why they can't fill them the way they are now. Seems as if it might be a tad more work to fill from the inside but I don't see how it would be impossible. You might have to remove or loosen the fender some but....it seems as if could be done. As long as the valve stem can be reached it seems as if they could be filled. I don't know your tractor but I filled my own and it's doable.
They came over today and they have an adapter that connects to the valve stem and it extends out over 6inches and needs to be hooked up with the fluid pump. So they cant do it in the current config as it hits the main hub assembly.
/ JD2720 Rear wheels configuration #17
/ JD2720 Rear wheels configuration #18
You can still get the wheel back on after taking it off, even when filled. I've done it on tractors with larger tires than yours. Roll the newly filled tire back up to the wheel studs as close as you can get it, then use the jack to gently lower the tractor down to the level where the studs will slide back through the holes in the rim. I've taken completely filled tires off, moved them aside, then installed 3" spacers, then put the tires back on. It really isn't so bad to do.
/ JD2720 Rear wheels configuration #19
When trying to switch loaded wheels from side to side to gain width, my 3720 wheels could not be turned around because there were dimples that would not allow be to seat the wheels fully, I found out later. It did work for a while.
The valve stems were on the inside and I thought that didn't matter much anyway. That was until I was pulling dirt and brush with my box blade. Some sticks got jammed between the wheels and then tractor frame and as the wheels rotated it sheared a valve stem off, then the fun began.
To make the wheel stance wider I needed to put on spacers and leave the wheels on the same side of the tractor to keep stems on the outside. I still need to take care in heavy brush, but not as much.
/ JD2720 Rear wheels configuration #20
Kubota has a little half metal circle guard for the valve stems; does Deere do something similar? See pic. By the way, I love your signature. IMG_5216.jpeg
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2021 Chevrolet Silverado 2500 HD Single Cab Royal Service Truck (A64194)
2021 Chevrolet...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
Case 590 SUPER M SERIES 2 (A65053)
Case 590 SUPER M...
New Holland TC21 (A62177)
New Holland TC21...
4ft Mini Skid Quick Attach Rotary Cutter (A63689)
4ft Mini Skid...
