Chain Grade
/ Chain Grade #21
A 5/16” grade 70 chain can be bought for less than $40. How much cheaper can a lesser grade be bought for?
5/16” grade 30 has a WLL of 1,900 lb
5/16” grade 43 has a WLL of 3,900 lb
5/16” grade 70 has a WLL of 4,700 lb
All would be adequate for that light of a tractor but the corrosion resistance of the grade 70 and just the added piece of mind are likely worth it. One chain cut into four (or three) pieces will likely be long enough to do what you want. Even if the lesser grades are half the cost which I doubt they are is it worth saving $20? Securement devices are one area where I think overkill is a good thing.
You can buy a 5/16 20’ grade 70 for $28. Even a 1/4 grade 70 would be plenty strong enough at 3100 WILL but I don’t know where to get it for cheaper than $28
/ Chain Grade
Thanks for the lead, that's the best price I have seen on 5/16 G70.
/ Chain Grade #24
I use 3/8 grade 70 and ratchet binders, u use the grade 40 junk to rip stumps out
/ Chain Grade #25
If done properly you can use 2 chains and 2 binders to get 4 attachment points if done properly. The loader should be tied down to the trailer as well as any attachments on the 3pt have to be tied down. Over a certain weight, the loader/boom has to be tied down. This is more a precaution to prevent the loader from lifting while traveling or in case of an accident.
/ Chain Grade #26
There’s nothing wrong with using 2 chains if it’s under 10,000 pounds. I think it’s easier to use 4 chains anyway since you can hook them all from the ground.
/ Chain Grade #27
If you go to flea markets, you can often find used 5/16" or 3/8" G70 chain in 14' lengths for $20. $40 new at HF, with coupon.
I lost count of how many times that I have broken cheapo G30 and G43 chains pulling logs. When they break, the piece(s) shoot like bullets. On the G30 chains, it is the weld that fails, after the link bends where the grab hook attaches. And my tractor is not very big.
I replace all my grab hook cotter pins with a small weld, since I have lost several hooks in the forest.
I will never buy anything less than G70 chain again, tho cheaper chain may be adequate for load binding. The tiny price diff is just not worth it.
/ Chain Grade #28
Are sure that's correct? Even if it is, I still tie down all attachments, FEL or 3ph.
/ Chain Grade #29
The cost of the machine versus the cost of chains to hold it on a trailer...? I'd buy Grade 70 chains. Then when my tractor is stuck and I need to have my neighbor pull it out with his 100HP tractor he doesn't walk thru my chains like a knife thru butter. :)
For towing and retrieval from mud holes and snow banks I quit using chains, there have been several farmers here killed when they break.
I have a nylon retrieval strap that is much safer, designed to allow you to start with slack, get rolling and when the slack is taken up it stretches a bit and tugs them out of the mess.
Kind of off topic (sorry) but it might save a life.
/ Chain Grade #30
That goes back to the trash grade 40 chain. Using pickups and small tractors there’s pretty much zero chance of breaking a 3/8 grade 70 chain.
/ Chain Grade #31
....until the strap/clevis/hitch breaks and creates a missile on a big rubber band.
/ Chain Grade #33
....but if I can get my 3 ton truck up to about 60mph before the slack runs out....that’s a lot of pulling power!
True, you can maximize the power the pulling vehicle can otherwise deliver....until you reach the maximum load the rope, cable or strap can take, then all the stored energy of those stretching types comes right back at you. Usually in line with your head.
Chains store little energy (relatively), that’s why you can’t use them to smooth out running starts.
As a general rule, I would never do running starts with anything unless I was 100% sure the rope or strap had a rating with a LOT of safety factor.
/ Chain Grade #34
My old '75 F100 4X4 had a nice set of chain imprints across the rear of the drivers side bed. This was about '81? and a buddy got stuck with his GF out on a road building site. He walked to a farmhouse and called me. I pull him out and then had the genius to go through a mud hole myself. Well in trying to pull me backwards the chain snapped. Moments later the sheriff shows up. :) At the powerplant we hardly used chains relying mostly on cable slings and before I left switching many slings to nylon slings.
/ Chain Grade #35
That goes back to the trash grade 40 chain. Using pickups and small tractors there痴 pretty much zero chance of breaking a 3/8 grade 70 chain.
You just haven't tried or you haven't been really stuck.
/ Chain Grade #36
They’ll hold a pretty good jerking. The hook point is the more likely breaking point. Have you ever broke one with a pickup or compact tractor?
/ Chain Grade #37
Actually... I've broken more then one & stretched a few doing things my poor 3/4 shouldn't have been doing.
It got elected because it was the heaviest thing I had & it hasn't broken beyond what I can fix yet.
/ Chain Grade #38
You’ve broken a 3/8 grade 70 chain with equal rated hooks and no repair splices already in it with a 3/4 ton truck? My 17,000 pound full size backhoe won’t break one with traction alone. With a 20 foot running shot you might be getting somewhere. I’ve pulled stuck bobcats with my loaded dump truck jerking on 3/8 chain and never broke one. My buddy has broken some but they have 200 hp 6 wheel tractors.
/ Chain Grade #39
^^^^^ best advice!
Chain versatility.
/ Chain Grade #40
I don't even want to be around if one of my 3/8 grade 100 chains go. :eek:
2024 JCB 270T Compact Track Loader Skid Steer (A66734)
2024 JCB 270T...
2019 Nissan Kicks Hatchback (A66738)
2019 Nissan Kicks...
2019 Autocar ACX Xpeditor T/A New Way 31ASL 31yd Side Loader Garbage Truck (A66736)
2019 Autocar ACX...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
2016 Chevrolet Suburban 4x4 SUV (A66738)
2016 Chevrolet...
2016 CARGO CRAFT 16 FOOT ENCLOSED TRAILER (A67714)
2016 CARGO CRAFT...
