Time to convert from small engine to battery tools?
   / Time to convert from small engine to battery tools? #261
If you had taken that wet forlorn tool and tried to dry it out with compressed air, you might have destroyed it. It probably didn't take in any water just sitting there.
Dragons Eggs. Some argue that we live thousands of times, Maybe much more that that. Certainly one of your future lives will find you wealthy enough to buy Stihls system. They may also have far nicer systems in other realities. lol
   / Time to convert from small engine to battery tools? #262
May not have an option going forward... California already has cities with outright bans and the State is planning for zero emission 2022 which either means battery or "Armstrong" powered..
Landscape companies already adjusting to the coming realty.
   / Time to convert from small engine to battery tools? #263
I did not know that but I am sure it is a sign of the times.
Yesterday I was talking to my diesel mechanic about the future of diesel being replaced by electric motors and he said it is sure to happen.
The other day at WalMart I noticed they had a HART? brand line trimmer/blower package with two batteries for $148 the best I remember. I know at my age I am not as big of a jerk so I like starting the Lithium Ion tools and that lead to getting the Leaf car.
As much as I want to argue your point... I can't. But I am lovin' my current life!
Just added to my Stihl battery tool collection. The HLA 65 Pole Hedger. I have the HSA 66 hedger but found myself too high on ladders and too much leaning and bending. Thinking I might sell the 66 and use the pole version for all. There is a longer heavier version but to keep it manageable for the wife, thought this to be the right one for us.
HLA 65 Extended Reach Battery Powered Hedge Trimmer | STIHL USA
I'm now fully committed to the Stihl line and think I need to pony up for a second battery although the run time on AP series is pretty good. But... two batteries means two machines going at once. Wife and I could both be going... notice the theme?
   / Time to convert from small engine to battery tools? #266
I have both pole trimmers and use the short one all the time and I like it a lot...
The extended version is heavy and a work out if using for any length of time but it keeps the ladder in the garage.
There are new additions such as an extended run AP 300 S battery with 25% extended run and two new saws... one is compact arborists in the works for awhile and a more conventional with larger chain 16" bar if I heard correctly.
A little lube on the hedge trimmer does wonders on sappy branches to prevent storage lockup.
Thanks for the reminder... sometimes I get lazy at the end of a job and don't do the little things such as this! Easy to have 'rode hard and put away wet'
   / Time to convert from small engine to battery tools? #268
So far with two batteries running out of charge has never been an issue... plus having two tools ready to go for a helper would be nice.
I don't do enough to warrant a backpack battery string trimmer I can see where it would come in handy as I go for hours at a time...
As luck would have it my 38 year old Echo SRM 300 brush cutter time to be put out to pasture has come... nothing wrong with the motor... all original and worked very hard over the years with blade and heavy nylon... bought it for Dad for Fathers Day in 1982.
Looked at Battery but with thistles and waist high grass on steep hillsides I afraid would come up short.
Checked with several dedicated mower shops and not one had a 30cc brush cutter in stock...
Since the Echo did more than I could ever imagine I decided to get the latest version of the same... SRM 3020u with handle bars... should be in Wednesday.
All the shops had small to medium loop handle machines and monster 41cc brush cutters... but the mid size is rare...
Plus the Echo has a 5 year consumer warranty...
The last few years I have been using 50-1 Stihl premium mix in everything... even the 25-1 Echo and noticed no problems... starter clock spring and ignition coil with integral plug wire conspired to force my hand.
Anyone with a battery brush cutter please chime in...
   / Time to convert from small engine to battery tools? #269
Solved that problem.
My hedges had grown to a little over 6 foot tall and just about as wide. 6 foot step ladder with a 24" cutting bar and 3' extension still couldn't reach all the way across. Over this past winter, I whacked 'em all off down to about 3'. Looked like a bunch of twigs sticking up from the ground. All sprouting well now and I'll be able to neaten them up with nice flattop trims in another few weeks using a single 24" bar trimmer and no ladder at all.
Sometimes a hard pruning while looking ugly initially... is the best remedy especially a couple years later!
   / Time to convert from small engine to battery tools? #271
Sounds like a ladder with this capability could do the job for you 6 foot step ladder with a 24" cutting bar :D.
Gave my Stihl string trimmer a good workout today. I think I can safely part with my last Stihl gasser. Going on Craigslist. Will help me pay for a new drill press I have my eyes on. I do need to get another AP300 battery though.
   / Time to convert from small engine to battery tools? #273
Which AP300 battery are you going to get? Extended run AP300S?
Good question... on my research list now. I have the black AP300 but saw there is an 'S' so now I need to know the difference and pricing.
Looks like 25% more battery life for $30 more and 0.1lb weight. Probably should fork over the additional cash and have the latest and greatest. I will forget the $30 faster than the enjoyment of a high quality battery. This way I will know which is which I guess. Orange vs. Black. :D
   / Time to convert from small engine to battery tools? #276
I’ve got the orange but not the S
The orange are more moisture resistant if memory serves... early on some complaints when batteries got wet...
Which trimmer do you use?
FSA 130R. I really like it. No on board battery makes is easy to swing around. I have some grassy banks that require me to bend over to reach down a ways and having the battery on a hip belt works well. I went that direction because I wanted the highest power blower and that didn't have an on board battery. I was initially concerned about the cord going from the pack would be a nuisance but I don't even notice it during use of either tool.
   / Time to convert from small engine to battery tools? #278
Do you use the Stihl Bump Head on you 130?
The reason I ask is the trimmer is well received but the Bump Head not so much.
Yes, so far... haven't had an issue with it yet but I don't have a ton of hours banging on it either. Are you suggesting there is an aftermarket head that works better?
   / Time to convert from small engine to battery tools? #280
No... at least not one that I know will fit on Stihl.
Hands down my Tanaka Brain is the best trimmer head I have ever used... It is fully automatic... no bumping and hands off and self feeding using centrifugal Force to regulate.
Not sure it is made anymore with changes at Tanaka.
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2018 KOMATSU PC138USLC-11 EXCAVATOR (A60429)
2018 KOMATSU...
2018 CATERPILLAR 323 EXCAVATOR (A60429)
2018 CATERPILLAR...
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A56438)
Magnolia Trailer...
2021 CATERPILLAR 323 EXCAVATOR (A60429)
2021 CATERPILLAR...
2005 WESTERN STAR DUMP TRUCK (A60430)
2005 WESTERN STAR...
