Time to convert from small engine to battery tools?
   / Time to convert from small engine to battery tools? #271
Solved that problem.
My hedges had grown to a little over 6 foot tall and just about as wide. 6 foot step ladder with a 24" cutting bar and 3' extension still couldn't reach all the way across. Over this past winter, I whacked 'em all off down to about 3'. Looked like a bunch of twigs sticking up from the ground. All sprouting well now and I'll be able to neaten them up with nice flattop trims in another few weeks using a single 24" bar trimmer and no ladder at all.
Sounds like a ladder with this capability could do the job for you 6 foot step ladder with a 24" cutting bar :D.
Gave my Stihl string trimmer a good workout today. I think I can safely part with my last Stihl gasser. Going on Craigslist. Will help me pay for a new drill press I have my eyes on. I do need to get another AP300 battery though.
   / Time to convert from small engine to battery tools? #273
Which AP300 battery are you going to get? Extended run AP300S?
Good question... on my research list now. I have the black AP300 but saw there is an 'S' so now I need to know the difference and pricing.
Looks like 25% more battery life for $30 more and 0.1lb weight. Probably should fork over the additional cash and have the latest and greatest. I will forget the $30 faster than the enjoyment of a high quality battery. This way I will know which is which I guess. Orange vs. Black. :D
   / Time to convert from small engine to battery tools? #276
I’ve got the orange but not the S
The orange are more moisture resistant if memory serves... early on some complaints when batteries got wet...
Which trimmer do you use?
FSA 130R. I really like it. No on board battery makes is easy to swing around. I have some grassy banks that require me to bend over to reach down a ways and having the battery on a hip belt works well. I went that direction because I wanted the highest power blower and that didn't have an on board battery. I was initially concerned about the cord going from the pack would be a nuisance but I don't even notice it during use of either tool.
   / Time to convert from small engine to battery tools? #278
Do you use the Stihl Bump Head on you 130?
The reason I ask is the trimmer is well received but the Bump Head not so much.
Yes, so far... haven't had an issue with it yet but I don't have a ton of hours banging on it either. Are you suggesting there is an aftermarket head that works better?
   / Time to convert from small engine to battery tools? #280
No... at least not one that I know will fit on Stihl.
Hands down my Tanaka Brain is the best trimmer head I have ever used... It is fully automatic... no bumping and hands off and self feeding using centrifugal Force to regulate.
Not sure it is made anymore with changes at Tanaka.
2002 TOYOTA 7FDKU40 FORKLIFT (A57880)
2002 TOYOTA...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 TROXELL 130BBL STEEL (A58214)
2015 TROXELL...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
Willmar 4550 Wrangler Articulating Loader (A56438)
Willmar 4550...
