Ethanol Free Gas
/ Ethanol Free Gas #81
^^^ I can't speak for everywhere, but the station I got mine from is the only one for many miles, at least that I know of. They use a surface tank that can't be more than 500 gallons. First time I saw the place, there was a fancy bass boat guy pulling up to it. I'm not sure how much he took, but probably more than I use in my mowers in several months. Based on that, I'd say their fuel is reasonably fresh during summer months.
/ Ethanol Free Gas #82
I buy over 200 gallons of non ethanol myself a year.
Every time I make a purchase it is 3 - 6 gallon jugs.......
/ Ethanol Free Gas #84
I don't understand what you are trying to say??
He's showing that there's a separate hose for the ethanol-free gas, so unlike the post he was referring to there is no ethanol contaminated gas in the hose as you start to pump the ethanol-free stuff.
/ Ethanol Free Gas #85
In my state, there is no provision to purchase E free at the pump. I can buy a 5 gal. jug of it for $80 at the outdoor shop. Hmm...$16 a gallon.
I do believe ethanol is a scam in a modern day fuel injected engine, much like fluoride being dumped into our drinking water. Then you wonder how our elected officials become millionaires while sitting in congress.
Perhaps they should put statins in our drinking water next.
/ Ethanol Free Gas #86
Same here in Nevada. Ethanol-free gas comes from its own nozzle.
/ Ethanol Free Gas #87
Got it... I have it either way, buy it at the regular pump OR pay at least 50 cents a gal. more, to go down the road to the next station to a dedicated E free pump.
I don't mind putting a gallon in my pu's tank, OR I have a dedicated can where E fuel doesn't matter and I fill that one first.
SR
/ Ethanol Free Gas #88
I have never seen a separate nozzle, I really wish we had those here rather than getting a hose full of ethanol before the non ethanol gets to the can. When mixing 2 gallons of 2stroke fuel, a hose full is significant. Having to drive a gas vehicle to the station just to be able to run the first gallon or so into the vehicle is a pain.
/ Ethanol Free Gas #89
I had a 2002 Mercury outboard and in 2012 had carb problems....little black bits of fuel line.....I ran ethanol the 10 years I had it.
This summer I bought another boat, also with a 2002 Mercury and the PO only used non-ethanol. I was servicing it recently and ran a swap down a couple of fuel lines.....spotless....Guess what this owner only uses!
/ Ethanol Free Gas #90
I buy mine from a station that has 4 pumps; 2 full service and 2 self service. In both service bays one pump only distributes 87 gasoline and the other pump only distributes 91 gasoline. I use the premium with the outboard and my small engines and it was $2.87 when I filled up a couple of days ago, about 20 cents more than the 93 octane at the ethanol pumps elsewhere.
/ Ethanol Free Gas #91
There is a Co-Op not too far from home that has 90 octane ethanol free gas. The price not that much higher than all the rest. It's a 20 mile round trip out of the way going to and from work so I don't use it in my cars/trucks. I do buy this ethanol free for my 2 cycle chain saws and weed whackers. The 2 cycles start and idle nicer with ethanol free provided I replace with fresh every 30 days.
/ Ethanol Free Gas #93
I read somewhere that the gas pumps that share a common hose/nozzle between the different grades of gas are designed to clear the leftover contents from the hose back down to the underground tank. It would be nice if that were true but I kind of doubt it.
It would be nice, but I don't think that is the case.
If you are getting 8+ gallons, a quart of a lower grade isn't a big deal. Not so much if you are filling a 2 gallon gas can.
Aaron Z
/ Ethanol Free Gas #94
I don’t see how that would work. For the most part I doubt the suppliers care if a few quarts of different fuel remain in hose.
/ Ethanol Free Gas #96
I picked up 10 gallon of 91 octane today at the only place in town that sells it that I know of. They have an above ground tank, not sure how big, maybe 1500 gallon.
Asked he guy when I paid if.they sold much. He said they sold quite a bit, probably 3 to 5 sales a day. I would guess most buy more than my 10 gallons.
Price was $2.81 today.
/ Ethanol Free Gas #97
The only distributor near me has a monopoly, charges $4.30 per gallon. I use it in my Tecumseh powered DR field and brush mower.
/ Ethanol Free Gas #98
A lot of landscapers use it and trailered boats around here. Vintage cars, etc.
2018 John Deere UTV Blade (A63116)
2018 John Deere...
2024 ANKONA 54" HANG-ON WHEEL LOADER FORKS (A62129)
2024 ANKONA 54"...
UNUSED PEANUT WAGON QUICK HITCH (A62131)
UNUSED PEANUT...
UNUSED ATS CMR1280 ELE.CEMENT MIXER (A62131)
UNUSED ATS CMR1280...
LMC Nitrogen Applicator (A62177)
LMC Nitrogen...
UNUSED IRGC40 HIGH-END ELECTRIC MINI GOLF CART (A62131)
UNUSED IRGC40...
