Broke Down and Got One of those Fake Drawbars :-(
   / Broke Down and Got One of those Fake Drawbars :-( #41
I have a "store-bought" version of the same thing for moving trailers and such. Converting the splitter to work with a ball hitch would allow safer travel over uneven ground.
I fail to see were a ball mount would allow safer travel over uneven ground,
ag implements used continuously on uneven ground have been primarily clevis style for as long as I can recall.
A pin going thru a clevis with a drawbar in the middle is quite secure,
in my mind much more so then a ball hitch.
   / Broke Down and Got One of those Fake Drawbars :-( #42
Yep. Only thing that might be a bit better is Hammer Strap drawbar and pintle loop. Plus being the Pintle loop can rotate.
   / Broke Down and Got One of those Fake Drawbars :-( #43
Quality Farm Supply, Agrisupply, Tractor Supply and others have these "drawbar locks" for around $21. Maybe what sixdogs is referring to.
I've had one for 25 years. Haven't looked at the ones available today, but mine is quite sturdy. For more strength you can always use two, one for each link arm.
These don't work, though, if you want to use a 3pt cross drawbar in a "quick hitch". Here's one solution that I posted last year to pull a manure spreader.
https://www.tractorbynet.com/forums/customization/404937-adapting-3pt-drawbar-generic-quick.html
Indeed, that's the one I'm referring to. The extra wide tolerances to allow universal fit on anything and gives so much "slop" in operation that the metal easily tears. Maybe not if you're hauling around cupcakes, but if used in the woods or for really heavy or awkward items, I have not found the store-bought ones satisfactory. Maybe the older ones are OK but the newer import ones seem to me made of thinner metal. I just threw out my last torn one a few weeks ago. Quoth the raven "Nevermore".
Post #20 by RJCorazza looks like a winner to me.
Here is his pic
   / Broke Down and Got One of those Fake Drawbars :-( #45
It's worth noting here that using the drawbar between the links has potential drawbacks. If you raise the 3PT hitch and that drawbar gets caught on the real tractor drawbar, it will easily be bent into a pretzel. Here's a pic of a CAT II drawbar that came with a tractor I bought. The fellow said it just got caught by " a little bit". I guess close only counts in horseshoes.
Hydraulics are pretty powerful.
   / Broke Down and Got One of those Fake Drawbars :-( #46
I take my stationary drawbar out except when I have the BH on.(To stabilize the pump, and keep it from spinning on the PTO.) Otherwise it seems like just something else to get hung up or caught. This is also the first tractor I've used which had one, even my 275 came without it.
Maybe I'm wrong, but you really aren't paying attention to be able to bend it like that while raising the lift.
   / Broke Down and Got One of those Fake Drawbars :-( #48
Ha! Looking at that drawbar makes me want to put it on my HF 20-ton shop press and straighten it right out! :laughing:
I'm always on the lookout for uses to make it pay for itself again, other than cracking walnuts.
   / Broke Down and Got One of those Fake Drawbars :-( #49
Of all the different tractors that I have worked I can't recall any that the fixed drawbar extended out further back then the lift arms.
   / Broke Down and Got One of those Fake Drawbars :-( #50
^This. On both my tractors there's at least 6" between the drawbar and the end of the lift arms. And that's with the drawbars set out as far as they can go.
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A55758)
Year: 2017 Make...
2003 Ford Pressure Digger Truck (A55973)
2003 Ford Pressure...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A56858)
2014 Ram 1500 4x4...
1605 (A57192)
1605 (A57192)
2023 John Deere 333G for Parts (A56435)
2023 John Deere...
