Anyone Using a Puma 80" or 84" Snow Blower?
   / Anyone Using a Puma 80" or 84" Snow Blower? #1
Hilbilly
Barriere, BC
Kubota Grand L6060HSTCC
Looking for anyone with experience with these blowers and what size tractor you are using it on.
   / Anyone Using a Puma 80" or 84" Snow Blower? #2
All I can tell you is... Your 6060 don't have the balls to run an 84" blower, single or 2 stage.. 60 maybe, 72 at the most in light powder only. I have a Lucknow 84 I run with a Kubota M9000 and it is all the tractor can handle and sometimes too much for it. With 84 pto horsepower. Blowers are wicked power eaters. You'll be much happier with a front blade versus a blower. I have them both and I use the blade 95% of the time.
   / Anyone Using a Puma 80" or 84" Snow Blower? #3
Amen!!
   / Anyone Using a Puma 80" or 84" Snow Blower? #4
I call a bit of BS... My 25hp PTO L3200 ran a 60" just fine in packed Colorado drifts. A L6060 with double the HP & probably HST can easily do a 72", probably in the 80" range if you're fine going slow. HST means you can dynamically adjust your speed vs load. I agree plowing is faster 90% of the time, but there are lots of cases ot doesn't cut the mustard.
Does going beyond 72" buy you much? 2 passes with a 60 was plenty for my driveway. Wider wouldnt have opened any more useful area. My parking area might have been able to drop from 6 100' passes to only 5 with a wider blower. Not a huge win.
Looking for a 72" blower now to match my 72" wide L4060HSTC. The 60 got sold as it was to skinny for my new machine.
   / Anyone Using a Puma 80" or 84" Snow Blower? #5
Have an 84 inch, 20 inch fan, blower on my Massey 1742. Works for everything I need to clean up. Hst makes a big difference in operational capabilities. Previous land owner had an 84 inch Allied blower on a Massey 1105. That blower was also a foot higher in the body and had a much larger fan, used all the power the tractor had. Need ro match the blower to the tractor.
   / Anyone Using a Puma 80" or 84" Snow Blower? #6
Not sure I agree with this. I have a buddy with an LS XR4155 easily blowing through 2ft of snow with a 96" blower. Another buddy with an 84" on a 35HP Kubota and loves it. Around here I see many 60" to 84" blowers hanging off the back off 30 to 60hp machines. We get lots of snow here in Maine, wet, dry, you name it. I am about to get a Woods 74 inch for my 36HP machine and the dealer says it will run it easily.
   / Anyone Using a Puma 80" or 84" Snow Blower? #7
X2
I have a 78" Lorenz and 32 hp at the PTO. Sure, I can bog it down if I ram into a plowback, but with the HST, creeping into the plowback is not a problem. Tractor Data says your tractor is 67" wide; 72" blower would be the bare minimum I would mount.
   / Anyone Using a Puma 80" or 84" Snow Blower? #8
X2
I measured my rear tires and they are about 70 or 71" outside to outside. I'm thinking 74" will be just wider than my rear tires so it should work.
   / Anyone Using a Puma 80" or 84" Snow Blower? #9
I won't tell my L6060 you said she has no balls:D. My 79" snowblower is coming any day now. This tractor had better perform well or I will be extremely bummed out. Not sure how the HST makes things better for snow blowing but glad I have it.
   / Anyone Using a Puma 80" or 84" Snow Blower? #10
My old B2150 only had 18 HP at the PTO and had no trouble at all running my 60" blower thru a 30" snowfall.
Mini John Deere Truck (A55853)
Mini John Deere...
2016 Bobcat E85 Midi Excavator (A59228)
2016 Bobcat E85...
2016 KOMATSU PC240LC-11 EXCAVATOR (A60429)
2016 KOMATSU...
WIGGINS 5K FORKLIFT (A58214)
WIGGINS 5K...
ExMark Vantage 48in Stand-On Commercial Mower (A59228)
ExMark Vantage...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
