Welding with wimpy little rod.
   / Welding with wimpy little rod. #1
k0ua
Epic Contributor
Branson, Mo.
Kioti DK35se Hydrostat
Look at these guys stick welding with some wimpy little rod:
   / Welding with wimpy little rod. #3
I dont think my little everlast welder has the juice to weld with it!
   / Welding with wimpy little rod. #4
That was interesting didn't know there was 3/4" electrodes, the biggest rod I use is 3/16, even then .045 mig wire is lot faster.
Nope, mine neither. Doubt I could even get it stuck.. :)
   / Welding with wimpy little rod. #6
Well if you did manage you’d have to get the cutting torch out.
Can you imagine the heat coming off of that welding process...
   / Welding with wimpy little rod. #8
I love seeing some of the cool welding processes. A buddy of mine runs a pressure vessel fabrication shop. They welded a vessel a while back that had a 9" shell thickness. It was a 60" diameter vessel and it took over 2200 lbs of filler metal just to weld the head on it, all 304 stainless steel. They used MIG for the weld process.
   / Welding with wimpy little rod. #9
If that’s the wimpy one can’t wait to see the heavy one !
   / Welding with wimpy little rod. #10
I barley keep a 3/32 rod lit with my everlast... tried 6010 and 6011, no difference. I'll take my transfomer machine any day over this everlast
If you're just learning to weld, you sure don't want a machine like this
2017 Rogator RG1300B Dry Fertilizer Applicator (A51039)
2017 Rogator...
2016 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51242)
2016 CATERPILLAR...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A51039)
Kubota BX2680...
Small concrete mixer (A49461)
Small concrete...
2018 CATERPILLAR 249D TRACKED SKID (A51222)
2018 CATERPILLAR...
2021 JCB HM180T Hydraulic Breaker Excavator Attachment (A49461)
2021 JCB HM180T...
