Welding with wimpy little rod.
   / Welding with wimpy little rod. #1
k0ua
Epic Contributor
Branson, Mo.
Kioti DK35se Hydrostat
Look at these guys stick welding with some wimpy little rod:
   / Welding with wimpy little rod. #3
I dont think my little everlast welder has the juice to weld with it!
   / Welding with wimpy little rod. #4
That was interesting didn't know there was 3/4" electrodes, the biggest rod I use is 3/16, even then .045 mig wire is lot faster.
Nope, mine neither. Doubt I could even get it stuck.. :)
   / Welding with wimpy little rod. #6
Well if you did manage you’d have to get the cutting torch out.
Can you imagine the heat coming off of that welding process...
   / Welding with wimpy little rod. #8
I love seeing some of the cool welding processes. A buddy of mine runs a pressure vessel fabrication shop. They welded a vessel a while back that had a 9" shell thickness. It was a 60" diameter vessel and it took over 2200 lbs of filler metal just to weld the head on it, all 304 stainless steel. They used MIG for the weld process.
   / Welding with wimpy little rod. #9
If that’s the wimpy one can’t wait to see the heavy one !
   / Welding with wimpy little rod. #10
I barley keep a 3/32 rod lit with my everlast... tried 6010 and 6011, no difference. I'll take my transfomer machine any day over this everlast
If you're just learning to weld, you sure don't want a machine like this
2014 Ford F550 Crane Truck (A50323)
2014 Ford F550...
hand held concrete saw (A49461)
hand held concrete...
Komatsu PC138 (A50490)
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
1998 CATERPILLAR TH103 TELESCOPIC FORKLIFT (A51242)
1998 CATERPILLAR...
NEW HOLLAND TS6.130 TRACTOR (A51406)
NEW HOLLAND...
