Everything Attachments
Status
Not open for further replies.
/ Everything Attachments #1,861
You bet! I figured a set of Forks would be more useful in the long run and that a Third Function Kit could wait a bit.
I replaced my old forks with a brand new set of the EA forks.
They are FIRST CLASS ........like everything EA makes!
/ Everything Attachments #1,864
Those are some strong words, sir, and we'll continue to do our best to live up to them.
Thanks so much.
Travis
/ Everything Attachments #1,866
I took my Wicked Grapple off to use forks the other day. When I re-installed the grapple today, I could not connect the hydraulic hoses as the grapple side was under pressure. When I loosened a pipe fitting on the grapple, to relieve the pressure I could make the connections.
What is the correct way to relieve the pressure when disconnecting the grapple?
/ Everything Attachments #1,867
Before you take your grapple off, shut your tractor off. Then turn ignition to "on" but don't start. Cycle your grapple open / close electrical toggle a time or two. Then disconnect hoses.
/ Everything Attachments #1,868
The pressure inside the cylinders and hoses on your Grapple is dependent on the outside temperature difference between when you disconnected and when you are trying to reconnect. Hydraulic fluid expands with temperature as do most fluids. So you may need,to relieve the pressure as you mention. On the tractor side, shut down and cycle all the valves to relieve pump pressure to the tank.
I try not to store my Grapples in the sun to minimize that from warming up the fluid.
/ Everything Attachments #1,869
Goeduck in our part of the country storing out of the sun is easier than those less fortunate members living elsewhere.
Now to the problem at hand. Cycling the 3rd function valve with the engine off at disconnect and again at re connect helps a lot but if the cylinders are still under pressure the protrusion from the male fitting can be rapped smartly on a hard surface to relieve the pressure. There is an expensive tool made to do that. Don’t remember the name of it but it was discussed and cussed on this forum a few months ago.
Smilinjak
/ Everything Attachments #1,870
Now to the problem at hand. Cycling the 3rd function valve with the engine off at disconnect and again at re connect helps a lot but if the cylinders are still under pressure the protrusion from the male fitting can be rapped smartly on a hard surface to relieve the pressure. There is an expensive tool made to do that. Don稚 remember the name of it but it was discussed and cussed on this forum a few months ago.
Smilinjak
Very good points :thumbsup: If the pressure is there when you go to disconnect you will not be able to disconnect easily so I would relieve the pressure by shutting down and venting to the tank. No sense disconnecting with pressure in the lines.
/ Everything Attachments #1,872
Hey man, it looks like you've received some good advice.
To summarize. It's a good idea to unhook the grapple in a position with the cylinders either fully open or fully closed. The grapple style will really determine which of those positions is best.
Also, depressurize your hydraulic system before unhooking and before rehooking.
Here is a video with Ted which explains said depressurization..
Travis
/ Everything Attachments #1,873
Any chance you have something for Santa to bring me?
Yes sir. The Custom WR Long 3rd function kit is offered for the 1525.
For installation, you'll need a power beyond adapter from Massey/Agco, which will need to be sourced from a dealer.
Part #s SL103119 and SL103143. They should be inexpensive.
Feel free to call me if you want to order. 828-464-1200.
Travis
/ Everything Attachments #1,874
Travis
Travis nailed it, lots a great advice from all who replied - thanks everyone. So, Travis which position is best for the 60" Wicked Grapple?
It may have been fluid expansion because I am pretty sure that I de-pressurized before disconnecting the grapple. The pressure was definitely on the grapple side of the fittings. We did have some cool weather and now it is warmer again.
Being a chemist, I am very familiar with fluid properties, but did not think that the pressure build up would be that much. However, this is a closed system full of an incompressible liquid - duh. :shocked:
/ Everything Attachments #1,875
If it's a 60" Wicked Root Rake Grapple, I'd store it fully open and face down. Cylinders will be retracted and lid will be bottomed out.
Like this, fully open..
If it's a long bottom 60" Wicked...fully closed.
Those are the positions which will prevent gravity from building pressure. If you're a chemist, I"m sure you've forgotten more than I ever thought about learning concerning expansion due to temperature. :laughing:
Travis
/ Everything Attachments #1,876
/ Everything Attachments #1,877
I have the same issue reconnecting my backhoe. I take a PVC cap, put it over the fitting on the BH and strike it with a hammer. The hammer will pop open the valve on the fitting and release the pressure. The PVC will prevent any damage to the firing. The cap will prevent you from getting sprayed with fluid when the pressure is released. Although your hand will bet a bit wet with hydraulic fluid.
/ Everything Attachments #1,878
Achievement Unlocked! Wicked 60" Root Rake Grapple earns "Old Man" seal of approval!
Got my 3rd function valve from MIE installed today. Hooked my new Wicked grapple onto the tractor, and headed behind the house to clean up some dead trees we had cut down. Judging from the 6 minutes I spent on the machine before being kicked off by my 75 year old father, I think I'm going to like it. Dad definitely likes it! That thing closes with authority. The dead pine tops he was piling up were snapping like toothpicks when he clamped the grapple down on them, and he was smiling the whole time! Its his new favorite attachment! I'll have to sneak out with it sometime when he's not around to get a little playtime with it myself! He was raised on a farm, spent untold time with tractors and implements, so when he brags about any "new" piece of equipment, you must be doing something right!
/ Everything Attachments #1,879
Travis
I forgot the rest of it the day that I retired! :laughing:
Thanks Travis! I should have guessed fully open since that's exactly how I received it!
/ Everything Attachments #1,880
Travis
Does $93.00 for those parts sound right?
Status
NEW Landhonor LHR-AIW1  1" Air Impact Wrench  (A62679)
NEW Landhonor...
16ft T/A Utility Trailer (A64557)
16ft T/A Utility...
2016 Eager Beaver 20XPT 27ft 25 Ton T/A Flatbed Equipment Trailer (A61572)
2016 Eager Beaver...
Ari-Hetra HDML-8 15,000lb Four Post Auto Lift (A64553)
Ari-Hetra HDML-8...
2006 International 4200 2,000 Gallon Water Truck (A64556)
2006 International...
2010 Chevrolet Express 3500 Dive Team Cargo Van (A64556)
2010 Chevrolet...
