bigtiller
Super Member
- Joined
- Feb 1, 2006
- Messages
- 7,517
- Location
- central Iowa
- Tractor
- John Deere 2720 John Deere 3039R John Deere Z545R
Is this for the winter only? What happens next spring/summer? Are you planning on heating the garage/shed? Do you want something solid that will block light or something that will allow light?
Is the gray siding wood or vinyl?
If it were me, I would gut the window and replace it, maybe with a thermal window. At the very least, I'd replace the frame/trim/brick mold. A new brick mold frame outside could have threaded inserts installed to accept bolts for future use if you want to add a storm window/cover in future years. Brick mold is now available in PVC that won't rot.
It's just for the winter/spring.
I'm not "into it" now I would rather put it off until warmer weather to do it again.
For now, wanting a quick easy fix to keep the snow from blowing in.
If you can't replace the window and you can't nail or screw into the siding/framing beside the window, I'd remove the window and cut a piece of plywood a little larger than the opening and use a carriage bolt thru the plywood in each corner so that it is inside the rough opening and use a 1x on the inside in each corner that the bolt goes thru and put a washer and nut on it. If need be, you can also use a foam gasket on the top and sides of the outside plywood for a better weather seal. That way there are no holes in your building and is about as secure as you can make it.
Edit. After posting I thought that you could just tape the glass into place and not cut anything to fit the opening. If the glass is still there and it's not broken, then ZIP tape it back into place an deal with it in the Spring.
