Quick Hitches Quick hitch question...
/ Quick hitch question... #1
Get Plowed
Leaburg, OR
Kubota B2650
Well, a couple questions... I bought my new Kubota B2650 with a QH10 quick hitch and grader scraper. I get the way it works. I really like the idea, but it’s a real pain in the you-know-what to unhook an implement!
Question #1:
Will this get better as things wear in a bit? I release the locks, but it often doesn’t want to drop out from under the implement pins.
Question #2:
I just picked up a Woodmaxx flail mower. Their website claims it is QH compatible, but I am unable to figure this out. Doesn’t look like it’s going to fit due to the upper pin height. Am I missing something? I intend to call Woodmaxx tomorrow for their input. Maybe I need to buy another part?
/ Quick hitch question... #2
Pictures are worth a thousand words. QH compatible means they spaced the pins out in accordance with cat 1 QH spacing. Some quick hitches top hook is too close to the QH and needs to be replaced with one that pokes out a bit further to slide on and off. This could also explain why your box blade doesn't release easily. I have a different QH with a bolt on/pin on top link hook that I replaced that stuck out further and it fixed all my issues. My box blade wouldn't release either until I made this change. IMG_20190617_141945.jpg
/ Quick hitch question... #4
1. I have not found that to be the case. I have a QH15 on each of my tractors. I use spacers or bushings on the implement pins to get a good fit so they don't rattle or move around. The 3PT is power up, not power down. I do have to give it a tap occasionally to get it to drop. The more rust on the spacers the worse it gets so I am prepared to replace the spacers. They are pretty cheap at my local TSC.
2. With a good torch and welder you could make every implement compatible with your QH, so you can back up and hook up without leaving the seat. I think the term QH compatible is misleading as even my Land Pride implements have different top hook heights. That is why I bought the QH15 with an adjustable top hook. I hook up the bottom hooks and then get off to set the top hook. I usually have to get off to connect the PTO shaft and adjust the toplink so it is no big deal to me.
Pictures are worth a thousand words. QH compatible means they spaced the pins out in accordance with cat 1 QH spacing. Some quick hitches top hook is too close to the QH and needs to be replaced with one that pokes out a bit further to slide on and off. This could also explain why your box blade doesn't release easily. I have a different QH with a bolt on/pin on top link hook that I replaced that stuck out further and it fixed all my issues. My box blade wouldn't release either until I made this change.View attachment 624920
I’ll get a couple of the QH, but I gave up and removed it so I could install the flail. It didn’t seem like the upper hook needs to move back. Looks like it needs to raise up about 3-4”. The lowers will engage, but the upper hook is too low...
And then I had to fight the **** out of it to get the lower hooks to let go...
Are you using a pair of 'bushings' on the lower implement pins?
No. The pins appear to be the correct diameter. Fill in the gaps nicely. It’s a LP QH with a LP QH-approved grader scraper. Both brand new. Flail is different brand. Website says it should work...
/ Quick hitch question... #7
Which woodmaxx flail is it? There should be an upper pin hole and a lower pin hole. To you a QH in standard height the pin should be in the lower hole on the toplink to line up correctly.
FM62. Only has one upper pin location, which is a horizontal slot that allows the mower to rock.
It looks like it needs the second pin located below it, like my grader scraper has. Just a touch frustrating when the manufacturer claims it fits...
/ Quick hitch question... #9
The general consensus seems to be modify implement to fit whatever configuration your QH is... Most QH have adjustable top hook that should move up or down according to whatever implement you are hooking up... The joke here is having to move hook, it no longer makes it "quick"... I mod all my implements and whatever to fit basic QH configuration for all my CAT 1 implements to this standard.....
Some people have ditched the bolts that hold the top hook to QH frame for pins that can be quickly moved.... If you top hook is rigid mount to frame work you are probably going to have redesign each implement mounting to be compatible or abandon the QH concept and resign yourself to do "hook up" individually for each implement...
Dale
/ Quick hitch question... #10
It's been my observation, both via mounting my own 3PH implements and numerous TBN threads, that the width of/between the bottom two pins are fairly standard (at least for Cat 1). The top-link height and/or position on the implement is the point where the discrepancies occur.
My JD iMatch 3PH quickhitch (2013 purchase) has a rigid, fixed, non-adjustable top-hook and I've had to use an adaptor on several of the implements to get them to fit. The bottom two pins (with bushings) have always fit perfectly.
Adjustable 'quickhitch' top-hooks are now fairly common and have become so because of the variances in top-link height/position.
/ Quick hitch question... #11
After reading a lot about QH "issues" I decided against getting one for my new LS. I am not able to weld or fabricate and I have a mix of old and new attachments. The LS came with telescoping link arms so that helps with hook up. It seemed easier to put the attachments on dollies and make them easier to move. The added advantage is that dollies allow me to move attachments close together to minimize storage space.
I added a hydraulic top link for about the same cost as a "good" QH. (The LS has two rear remotes standard so just the cost of cylinder, hose, fittings) That makes hooking up easier, plus it allows me to adjust the angle of attack of the 3PH as needed from my seat. Much better option for my needs than a QH.
/ Quick hitch question... #12
I think your solution isn't at the toplink after looking at pics on woodmax's website. It's hard to tell from a picture but if you used the upper holes on the lower arms to connect would that resolve the issue?Screenshot_20191016-061822.jpg
I’ll double check to see if that looks like mine, but I don’t believe there were multiple holes for the lowers. I don’t know that there is even enough material to drill an additional set... Good catch on the photo though!
Nope. Only one hole on mine for each lower link. Not enough steel above the holes to make additional....
I see a little bit of fabrication in my future.
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
UTILI TOUGH 48" RAKE (A64277)
UTILI TOUGH 48"...
2006 MACK CHN613 DAYCAB (A65643)
2006 MACK CHN613...
3ft Metal Star (A65583)
3ft Metal Star...
2018 SolarTech Silent Messenger Towable Solar Message Board (A64553)
2018 SolarTech...
NEW Rachet Tie Downs and Flatpack Tool Box (A62679)
NEW Rachet Tie...
