AZ ranch
/ AZ ranch #1,161
My house flooring is 3/4 plywood on 16” OC joists and then 2x6 on top of the plywood.
But then I tend to overbuild everything. :)
How’s the weather back there in Ohio? I haven’t been back there for a couple years.
Mr Bo,
Is that tongue and groove 2x6s or 2x6 boards?
hugs, Brandi
/ AZ ranch
Update. I have about 2/3 of the floor done. Well, not completely done. I still need to go back and put in a lot of screws, but I am making progress.
I ran out of lumber, so I will have to wait a week or so to finish. I have been buying it in increments so it is not laying around long enough to warp and twist.
/ AZ ranch #1,165
That does look really nice. I hope you are sealing those cut ends!
/ AZ ranch #1,167
Whatever finish is used on the rest of the board. If they are pressure treated/prefinished and come that way, ask the lumber yard what to use. They should have it on hand. The treatment doesn't get to the inside nowadays... If they don't have anything then just ask for the general pressure treating stuff they should have in the paint dept. by the gallon.
/ AZ ranch
Still have not finished, but my better half could not wait, so we had our breakfast out here.
/ AZ ranch
I am starting my guard railing this week. My plan is to put a 4x4 as an upright every 4 ft. Then I will put a 4x4 as a bottom plate, with a hole drilled every 4 inches, about 1 1/2 deep, and stick a piece of 1/2 inch rebar 30 inches long in every hole. Then I will make a top rail identical to the bottom rail, except turn it over and wiggle the rebar into the holes in the top rail. Maybe some liquid nail or something in the holes, but I want them to be snug, so the adhesive may not be necessary. I will drill the holes smaller than the rebar and pound them in. I think it should work.
/ AZ ranch #1,173
While you still have access to the under-deck area....
Bruce
/ AZ ranch
Bruce
Yes, the front and ends will be open - easy access.
Currently my only access to the basement is through the outside small door, so I will have to crawl under the deck to get to the door.
Eventually, i want to put a trap door and stairs inside.
/ AZ ranch #1,175
In the bottom rail, after you drill your 1/2" holes, I would recommend coming back with a smaller bit and drilling through the center of your 1/2" hole through to the bottom of the rail so water has a better chance of getting out and doesn't get trapped. Don't glue the bottom either. The hard part in assembling will be that you have to line up all 1 million rods into the top rail holes simultaneously to get it together. It ain't fun...
/ AZ ranch #1,176
I wouldn't worry about a weep hole on a house in Arizona.
I like the idea of using the 4x4's. I've never seen that before and it should look very substantial. Will you raise the bottom up off of the deck?
A random thought that I just had was to wonder what your 4x4's would look like if they where installed at an angle with the pointed edge at the top?
/ AZ ranch
The bottom rail will be about 3.5 inches off the floor (height of 4x4). Diagonal sound interesting but i like the idea of a little edge on top, for coffee cup or whatever.
I have not decided on method of securing horizontal 4x4 to the vertical 4x4. Bolt to one side (inside), or notch part way, or cut to 4 ft lengths and put exactly between the uprights with angle brackets.
/ AZ ranch #1,178
/ AZ ranch
There are also "timberlok" screws in various lengths that will go thru the 4x4 horizontal and well into the 4x4 vertical. It will give it a cleaner look, but you'll need to put the bottom rail and posts together before placing the railing in position.
https://www.homedepot.com/p/FastenMaster-14-6-in-External-Hex-Flange-Hex-Head-Wood-Screws-12-Pack-FMTLOK06-12/202284481
I have a box of 6 inch timber locks that I bought for something else and then did not use them. i will try those. Yes & no of the pre-assembly. I am going to lay a 4x4 on the deck and then put another one, which will be my bottom rail, on top of that, and then drill and pound and attach.
/ AZ ranch
Second thoughts on the timber looks. A cleaner look maybe, but this is not a Martha Stewart home. It is a log cabin and I think I like the look of bolts instead.
Mini Skid 6 Way Blade (A56438)
Mini Skid 6 Way...
2017 PJ TRAILER 20' T/A TRAILER (A58214)
2017 PJ TRAILER...
2016 Ford F-150 Pickup Truck, VIN # 1FTMF1C85GKE26496 (A61165)
2016 Ford F-150...
2012 TEX MEX TRAILER LOW BOY GOOSENECK (A58214)
2012 TEX MEX...
WOODS 3120 BATWING MOWER (A60430)
WOODS 3120 BATWING...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
