Two story Shop on steep grade - Help me Design/Build it!!!
/ Two story Shop on steep grade - Help me Design/Build it!!! #1
dragoneggs
Super Star Member
Seabeck, Washington
Kubota BX-25D, Kubota Z122RKW-42
Okay it is finally time to build my dream shop! Been shoehorned into my two car detached garage for 10 years (both cars parked outside) and I am finally getting to around to 'doing it right!'.
We live on 1.5 acres of beautiful sloping view property. While blessed with a million dollar view, it does create challenges when it comes to construction/landscaping and getting around on the property.
I have finally down selected the build site location from 4 to1. Other three options were... (1) extend the existing detached garage, (2) extend the house (w/daylight basement) on one end, or (3) build a new stand alone structure on the lower part of the property. All had cons that exceeded the pro's. Here is my plot plan to give you a sense of what I am facing.
The chosen site ended being a location that I didn't consider until recently after years of contemplation. It means clearing a steep sloped area full of fir and cedar trees and locating it close to my property line and relatively close to my neighbor's home. Still a bit concerned about that, but it gives me lots of square footage that my #1 and #2 options couldn't provide, and close to my residence, easy road access, and power and water supply that #3 couldn't provide.
I plan to design and contract the major work out myself, DIY a bunch as well. I realistically expect this to take at least a year to get mostly completed. Please help me design and give me inspiration during this exciting project.
Here are my initial plans... again, a two story shop. Bottom floor will be a metal shop. Figuring 12ft ceiling with a concrete slab floor. Top floor will be a wood shop with a 10ft ceiling. Both levels will be accessible by vehicle and will have a 12ft by 10ft roll up door as well as a 3ft 'pedestrian' entry.
I am using Home Designer software from Chief Architect. Very powerful CAD program and I am pretty much a novice with it. Take a look at what I have so far... a 25ft by 40ft footprint meaning 1000 sq ft per floor. Truly looking forward to your comments, recommendations, and advice on this design/build!
All that said... please be patient with me. I do have a day job and I travel extensively on business, so this will take longer than solving such suspense thrillers as Sparc's 'Pallets in the Fields' and Kando's 'Rounded off drain plug'. Surely won't be as entertaining but maybe a few of us can benefit from this thread.
/ Two story Shop on steep grade - Help me Design/Build it!!! #2
Good luck with it, Mark! First question: Why such a big door on the second level? Are you planning on putting a vehicle up there, and if so, how are you going to structure the floor between the 2 levels?
James, these are exactly the questions/comments I am hoping to hear!
My first quick answers to your 3 questions are... 1) I don't know... and I guess... that is the answer to all three.
I do know I want to be able to easily unload a large tool or large pieces of wood/lumber in the wood shop... not through a door. I think it would be smart to be able to drive in with a small tractor to load/unload stuff.
I also know that I like a lot of natural light and ventilation especially when the weather is 'right'. I have yet to design the floor structure and I wasn't figuring on an especially strong/stiff floor for the wood shop but if it isn't a huge delta in cost then, why not?
/ Two story Shop on steep grade - Help me Design/Build it!!! #4
If you were to make the part of the wood shop that's "on grade" a slab, you could concievably do the REST of the upper floor with I-joists - done right (and with lots of planning) the I-joist part of the floor could house serious dust collection piping with ZERO 90's (if there MUST be 90's, two 45's is less restrictive by a little bit) - I saw an upstairs shop (IIRC, on Sawmill Creek) where the guy did that - kept the shop MUCH neater looking, all the piping came up right next to, or under, the major power tools.
My wood shop area dust piping is all overhead, supported by the trusses (open ceiling) with drops (120, 240, air, dust) where necessary - they drop to 6" above head height and are all flex so they can be tied up out of the way if needed. I have specific areas for bandsaw, 2 planers, 2 jointers, 3 router tables, cabinet saw, radial saw, sliding miter saw, disk/belt sander, pocket hole station, and eventually a 4'x8' assembly table with hydraulic height adjustment. Eventually I'd like to replace the 4" piping with 6", and a larger cyclone...
wood shop - with the slab being just inside your big door, that could be your staging area for material unloading/heavy equipment, etc - Also, if you were to forego the hip roof (at least on that end) the ridge line/gable could extend enough to provide a dry parking area without usurping actual shop space.
Lower shop- if you intend any vehicle projects, 12' ceilings would be minimum for a decent hoist, plus MORE planning to make sure said hoist is in the best location for access without being more in the way than necessary. Slab thickness/steel placement would be another thing to plan for.
Floor planning - Grizzly has a shop design app on their site with scaled drawings of most of their gear if you don't already have that available.
Windows - dunno if these are made, but I think I'd look for double pane with outer panes of Lexan - Also, if you can see out, "they" can see in. Either blinds, or better - inside, lockable shutters. Out of sight, out of mind.
Doors - man doors should be steel, framing around those should have extra fire blocking 2 studs each side at door lock height, makes popping a door lock a little harder when they're trying to spread 4 feet of sheathed wall on each side. One man door on each level should be the ONLY doors that aren't locked ONLY from INSIDE.
Don't mean to sound too paranoid, but we had a breakin at my shop about 12 years ago, over $6k worth of tools and an entire summer wasted dealing with insurance. Turned out to be "friends" of one next door neighbor. These days I STILL do multiple rounds after dark, along with both Dobermans, a high intensity light and a .357. (Second reason for the .357 is the cougars that're getting bolder around here)
HTH... Steve
/ Two story Shop on steep grade - Help me Design/Build it!!! #5
Looks like an exciting plan, Mate. I know that you've been 'considering' the placement of this shop for quite a while. (My newest mantra is: 'I'm not procrastinating, I'm thinking.' :)
Maybe it's an Aussie perspective but, I'm uncomfortable with close placement of trees around structures. Mostly it's to do with bushfire danger, no trees within 20 metres is a general rule of thumb, but the other side of trees is that they can come crashing down (wind/sodden ground/age).
Oh, how are you going to handle material disposal? (off-cuts, sawdust, metal shavings, etc...)
/ Two story Shop on steep grade - Help me Design/Build it!!! #6
It's got to have an escalator! AND a freight elevator.
I built my drive shed into a hill and got a really bad low estimate of cost from my dirt contractor. Cost me a fortune, and hundreds of dump truck loads of material I had to find a place for. BUT, I am glad it worked out this way. LOCATION, LOCATION, LOCATION! Now it's where I wanted it and I wouldn't have done it if I knew what it was going to cost. A possible 20 G building ended up costing four times that with all the "little" extras! Oh, Polycarbonate doors are GREAT!
/ Two story Shop on steep grade - Help me Design/Build it!!! #7
I really like this plan. The location makes the most sense and the two levels work well together. I think that you have come up with a very strong solution to where to build it and how to build it!!!
/ Two story Shop on steep grade - Help me Design/Build it!!! #8
It seems odd that the higher ceiling and doors is down stairs and further from the driveway. You don’t show existing driveways so I’m assuming a bit. With that, typically bigger doors would have easier access and the bigger space- so the higher ceiling and door would be upstairs and the lower ceiling and door downstairs.
I see very little advantage to making the downstairs smaller. The planning, engineering, design, permits, excavation and concrete will be nearly the same- so take advantage of that and double your downstairs.
Windows look good on plans but really make work spaces smaller. I’ve had much better luck with an extra row or two of glass in the sectional doors (if needed) and few or no windows on the walls. Shops don’t tend to play nice with glass. Skylights are an option if you are into that type of thing.
My guess on cost- with engineering, permits etc (all in cost). $200k with you doing some of the work.
/ Two story Shop on steep grade - Help me Design/Build it!!! #9
I put no windows in my building only the polycarbonate doors because I realized on other out buildings that they just attract insects and cob webs.
I regret that I didn't build my depth just two or three feet longer. It's never BIG enough in the end. The bigger it is, the more options you have for putting stuff in there. That looks like an expensive building for the amount of floor space you are going to get.
HTH... Steve
Steve, you immediately picked up on one of my design dilemmas and was going to bring it up just as soon I got finished introducing the design. Just how do I design the wood floor to be at grade? I am only familiar with floor joists sitting on top of the foundation thus causing a step, or two up which of course I don't want.
Here is the framing design auto generated based on my floor plan. Obviously I don't want any wood sub grade. A slab for part of the upper floor might be a great idea for vehicles as well.
I do plan to build it securely and will make sure the doors are solid. I will install cameras and alarm. The good thing the shop is at the end of a private shared driveway so we get very little traffic that is not my two neighbors and my neighbor lady above me is a 'hawk'!
I hear ya on the trees. My wife thinks I should not leave any nearby. I am leaving four and taking down a dozen. Three of them are located along the property line and provide some buffer screen between the shop and neighbor house. I am already feeling guilty about building this huge 'wall' so close to my neighbor whose house is about 20ft off the line. My biggest concern is the debris and moss buildup on the roof and gutters making for a maintenance nightmare. Might go with metal roof with a steeper pitch.
Ha ha IT! I have thought an elevator would be nice. I also thought about a trap door in the floor that could allow lowering stuff via gantry. But I'm afraid due to cost, one set of stairs will be all I incorporate between floors.
As far as dirt... no problem. I will need it to build the lower driveway access. Regardless, I can lose it easily on my property if I have excess.
Thanks Eddie... hoping you will be chiming in here.
The 12ft bottom floor height is in part because of the existing grade and wanting a gantry of some sort.
Not sure what you mean about 'making the downstairs smaller. They are both 25ft x 40ft. Here is lower floor plan view...
Yikes on price! I was hoping to get er mostly done at about $100K! :eek: I am trying to design it such that if someone wants to convert some day to some living space, it could be done without major changes other than the addition of plumbing/septic.
/ Two story Shop on steep grade - Help me Design/Build it!!! #15
In our last house we had a very sloped lot. A lot more than your drawings indicate that you have even. We had 10' ceilings in the basement and the deck off the basement was 10' or more off the ground at the back side. The house set on bedrock which we did not know was going to be the case when we started. We had planned on digging footers for the 3 car garage portion but due to the soil type ended up having to dig full walls as the soil (mainly rocks) kept caving in. My dirt person/excavator and I were looking at the big hole under the garage and he commented "That is going to take a lot of fill." I saw $$$ and started researching. We ended up with full basement under the 3 car garage which was right at 1,000 sq ft. Did not cost much more than it would have to have hauled the fill. It made for a nice shop area. We used these to support the garage floor:
Unique Suspended Concrete Flooring Systems | SpeedFloor USA
They were fast to install and worked great for the 7 years we lived there. The basement walls were all ICF and then we spray foamed the ceiling/bottom of garage floor. No heat or AC and the room was always comfortable. We did run a dehumidifier in summer to keep humidity correct.
Slope is much more than shown on my attempt to add the terrain to my plan. It is dropping about 12ft in about 25ft in the middle of the plot.
Thanks for sharing the SpeedFloor link. Will check that out. Any idea on sq ft installed cost?
/ Two story Shop on steep grade - Help me Design/Build it!!! #17
"how do I design the wood floor to be at grade?"
My bad; my first impression was that the lower floor was smaller than the upper, which would've meant that the lower floor did NOT extend fully under the upper - now that I got my "cranius rectumus" under control, I see that isn't so.
Let me revise my answer to say this - looking at your West view, you will need a "basement wall" under the South end of the wood shop (and a DRAIN across that entire end, slightly lower than the slab) so hydraulic pressure doesn't eventually impact your lower floor's usable space :eek: - if the outside slab is tied into that "basement" wall, then the ENTIRE upper floor can be framed the same way - one option would be to cast a ledge into the upper part of the "basement" wall for either wood or steel I beams to rest on - steel if you need to conserve depth on the upper floor frame and STILL support heavier weights near the big door.
That's why, knowing myself, I recommended an EXTENDED GABLE roof to cover the slab on that South side. That would let you load/unload on solid concrete and OUT of the rain. As an added bonus, the extended roof would also keep the shop a bit cooler on the 9 days a year it ain't RAINING :rolleyes:
It sounds like you're wanting a SERIOUS wood shop, so make sure your upper floor can handle it - examples: My PM66 saw weighs around 500#, resting mainly on 4 casters (point loading) - my 6" powermatic jointer weighs about the same, built-in mobile base on THREE casters - 15" planer about 400# on 4 points, 12" Grizzly helical head jointer, just under 1000 lbs on 4 points; by now you probably get my "point" :laughing:
Sooo, I would run floor joists the SHORT way, probably on 16" centers - use 1-1/4" T&G ply over, then whatever SMOOTH floor covering that'll withstand heavy casters rolling around AND sweep up easily - the heavy ply will spread out all those POINT LOADS. You'll still need to calculate dead load based on the ENTIRE weight of ALL MATERIALS used (frame, ply, covering, etc - easiest way is to take a 10'x10' section, count the weight of all joists in that area, add weight of 100 SF of ply, same with floor covering, then divide THAT total by 100 and add AT LEAST 10#, and that's your minimum dead load PSF. If THAT # can't be supported in span calculator with those joists, increase joist size (or re-figure with 12" centers instead of 16, etc...)
Live load includes you and friends, machinery, wood racks, etc - I'm not always sure how to approach that, other than "overbuild and pray" :rolleyes: but I'm pretty sure that you will need to involve an architect in this project anyway; if so, make a list of ALL POSSIBLE stuff you want on that second floor, you're gonna PAY 'EM ANYWAY, one way or another :eek:
'Bout all I got for now, gonna spend today recovering from about 80 trips up and down 3 ladders adding flashing on my shop roof that the roofers apparently didn't think necessary (hopefully it'll stop the need for a tarp INSIDE my studio to keep $25k of music/sound equipment DRY :mad: ... Steve
/ Two story Shop on steep grade - Help me Design/Build it!!! #18
Yes, that is steep. We dropped right at 25' over 50' so the same sounds like. I do not remember the cost for that, just that I was pleasantly surprised that is was not more. The main cost difference was just the speedfloor support beams as they just poured 4 inches of concrete with lots of rebar in it. The setup was a little more but not bad. They used particle board to hold the concrete in place until cured and then popped it off after a week or 10 days. First time I pulled my truck in I was nervous but it worked as advertised. It was nice to have the clear span with no supports in the room below.
/ Two story Shop on steep grade - Help me Design/Build it!!! #19
Oh, when laying out a woodshop floor plan - find out the EXACT table height on ALL (semi) stationary power tools, then do your floor plan such that ALL tools have a USABLE in AND outfeed of at least 10' - example: my bandsaw's table is tall, so it shares "air space" with one of the jointers AND one of the planers - one dust collector drop and 3 separate blast gates, with tools in a triangular pattern - planer outfeed actually passes OVER one end of jointer, bandsaw in/out is above ALL the others.
IME, a shop only SEEMS big enough til you start to USE it... Steve
Next question... I do not want any interior posts. Can I make it work with a 25ft span?
2025 SDLANCH IRET13 Electric Tricycle (A60352)
2025 SDLANCH...
2007 John Deere 644J Articulated Wheel Loader (A61567)
2007 John Deere...
12 in. WRXLS Excavator Bucket (A60352)
12 in. WRXLS...
(2) 13.6-38/12-38 TIRES W/8 LUG RIM (UNUSED) (A62130)
(2) 13.6-38/12-38...
2019 Ford E-450 Shuttle Bus (A61568)
2019 Ford E-450...
2025 JBD 32in. Hydraulic Mixing Bucket Mini Skid Steer Attachment (A61567)
2025 JBD 32in...
